1 members (Bruce),
3,163
902
Testing
by Bruce - 03/05/26 03:39 PM
The photo in the previous reply is one of the two gearboxes. I assume that they are from a deutscher ride on. There are no markings on the housings and one has a slightly different axel but I suspect the gearboxes are still the same. i'll get some better photos. I've got no use for them as I am downsizing due to lack of space. If you want them we need to work out a price and and how to get them to you. I live in Geelong. I don't know if Terry is getting you the housing only or the complete box including gears.
"you can never tell how many Duetschers a man could end up with" At a quick count, I have 3 h26s , a G26, and about 3 other older models in different state of disrepair. And other bits and pieces.
Posts: 8,184 Likes: 232
At this stage all I need is the housings that Terry is supplying but who knows what the future holds so it always pays to have spares on hand. No problems for me to slip down to Geelong and pick them up at anytime that suits you. The one in the pic looks to be correct. I'm happy to help you with the ones in disrepair if you would like,I don't have any grass to cut but a man has to have reason to get out of bed every day.
Moving forward slowly on this and I have now realized that I am missing the levers that operate the clutch,brake and the gear lever. There is a missing plate on the side of the housing that I assume is where they were mounted. I see no difficulty in making these bits up to make them all work but I would like it to sort of operate as per the original. If anybody has any photos or diagrams as to how it all works it would be much appreciated otherwise it is just going to be a version according to Norm
Posts: 1,842 Likes: 14
Are you watching that 360 in Hoddle's Creek on FleaBay just now? Still under $200 with two and a bit days to go...
Cheers, Gadge
Yes thanks Gadge, watching that one, if I got that one I could see hoe all the levers work.
Given up on that one Gadge, be interesting to see how high it goes, at $320 now. Anyway I have been able to come up with ways to make up all the bits needed to get everything to operate. I wanted the clutch lever on the left side, so you can disengage the drive belt when you push the start solonoid on the right side. I also wanted the brake lever on the right and also the gearshift. No idea how the original was setup but to me this is how it should, makes everything simple 2 handed operations
Posts: 310 Likes: 1
$300 if you're interested, has a broken front wheel (as per photo) runs & cuts well even on 3 wheels. lol ![[Linked Image]](https://www.outdoorking-forum.com.au/forum/uploads/usergals/2016/04/full-9138-28000-20160414_131945_1280x1196.jpg) ![[Linked Image]](https://www.outdoorking-forum.com.au/forum/uploads/usergals/2016/04/full-9138-28001-20160414_131920_1110x1280.jpg) ![[Linked Image]](https://www.outdoorking-forum.com.au/forum/uploads/usergals/2016/04/full-9138-28002-20160414_131905_1280x967.jpg)
Regards, Paul
Such is life....... Nothing better than a "GreenField" just mowed..
Hi Paul, where about in this big state are you situated? In that last pic can I see another set of duell wheels? I guess it could always be made into a trike
Posts: 310 Likes: 1
G'day NormK, I'm in se melbourne, near Berwick.. that's another R360 I have..
Regards, Paul
Great Paul I'm in Hampton Park 10 mins away, let me know when it suits you for me to pick it up. Cheers Norm
Posts: 310 Likes: 1
Regards, Paul
Now that I have a pair of these (thanks Paul) I think I might see if we can organize a bit of Deutcher racing. We can test out the Honda against the Briggs  Might help put my mates place up at Culgoa in the Mallee back on the map
Hi Paul, that front wheel with the broken out center, ended up a 5 min job, so easy when I really looked at it, cleaned it up moved the broken away holes around a bit, drilled new holes and job done
Posts: 310 Likes: 1
Too easy Norm, glad it's all worked out for ya..  & thanks for the tip..
Regards, Paul
Does anybody have any knowledge about the strength of the gearboxes in these machines. A mate of mine has a few acres in Pakenham (Vic) and it is on the side of a hill that is fairly steep. He has a rideon that he paid $8000 for and he tried using it on the weekend on one section and it spooked him enough that he won't be trying that again.  . The Deutscher being low and flat will be stable enough, I'm just wondering if the gearbox/diff will be able to handle it. Any thoughts? I guess there is only one way to find out
Posts: 6,938 Likes: 317
Hi Norm
Deutscher has a solid name for reliability. They have been - for decades - a popular choice for municipal councils and contractors.
So ... my answer would have to be that gearboxes are solid. Any failure should be attributed to a specific cause.
Hope this helps. ---------------------- Jack
Thanks Jack, this one is the ride on R360, I just replaced the gearbox housings on it, it isn't a big gearbox, just not sure if it will handle the hilly stuff.. Knowing my mate he will want to put a 20hp motor on it to get up the hills and I can see the gearbox as being the weak point. The beauty of them is they are low, flat and wide, and if you fit a flat ride on seat you can drop your body height by a couple of hundred millimeters, all helps
Hi NormSorry mate - stuffed that up then  I guess the issue is how heavy duty is the gearbox, and will it take more horsepower? I suspect you're the better judge of that. ----------------------- Jack
I keep looking at these and I have one here that needs a complete new top fitted to the deck, it is completely rusted out. I might be crazy but I keep looking at it and thinking that seeing the top needs replacing, should I go the hog with it and add an extra 18" cutter to each side and then it would have a 72" cut. Would be a great machine for my mates property which is reasonably steep but a fairly big acreage. The fact the Deutscher is low and flat makes it suitable and the extra width would certainly prevent any potential roll over problems. The bigger cutting deck will obviously require a bigger hp motor. Am I crazy?
Posts: 310 Likes: 1
Set up two back ends with a Cat/center steer 4Duel wheel drive
Regards, Paul
Paul I did give this idea some serious consideration welding the 2 R36's together but I am not sure how the side by side diffs would work, might have to speed one motor up and slow one down so you could turn it. At least it should get plenty of traction
Posts: 310 Likes: 1
make it steer from the middle. center steer or each end turns like 4wheel steer
Regards, Paul
Sorry Paul, not following you on this, center steer using the standard R36 steering is no problem, my problem is what happens with the 2 gearboxes and are you thinking of using the 2 existing motors to drive each gearbox in its standard form. I think it gets far two complicated, building a wider deck seems a lot easier and when you think about it it only brings the deck out the width of a Victa Toecutter on each side. Might be easier to just mount a Toecutter out on each side
Posts: 310 Likes: 1
rear gear box runs in forward the front runs in reverse, all linked up. The Forw/Rev levers linked up would do the Forw/Rev as normal ( front Diff/Box runs reverse when rear Diff/Box is in forward) The Gear shift levers give drive to both boxes, having adjustment at each linkage connection is to fine tune the engagement points..
Regards, Paul
Paul, discussing it with Terry Scanlon his concern is the one B section cutter belt might not be up to it so his suggestion is to use the R36 as is and build a tow behind that has 2 cutters spaced apart to give us the 6 foot cutting width we are chasing. This seems a much simpler way to go and Terry says the Deutscher will pull it, no problems at all
Posts: 310 Likes: 1
LOL... I had that thought, Tow my connected up push mowers
Regards, Paul
Topics12,726
Posts106,648
Members17,956
