1 members (Bruce), 2,729 guests, and 1,088 robots.
GXV160 clutch
by NormK - 11/05/26 08:45 PM
by Bumps - 09/05/26 02:09 PM
Image Upload Issue
by Bruce - 03/05/26 04:45 PM
Sanli height adjustment knob
by Bumps - 28/04/26 05:22 PM
Victa Powercut design flaws
GXV160 clutch
by NormK - 12/05/26 05:58 PM
by NormK - 09/05/26 08:01 PM
by Bumps - 09/05/26 01:34 PM
by NormK - 07/05/26 10:15 AM
by NormK - 07/05/26 08:42 AM
Image Upload Issue
Testing
by Bruce - 03/05/26 03:39 PM
#5255 16/04/03 06:21 AM
I own a Ryobi 725r trimmer 7+ years. Normally to start you use two pulls on full choke, start and run on 1/2 choke with full throttle for about one minute, then no choke and it would trim and edge all I want (I have several attachments).
Last season it would only run on 1/2 choke position (or a little between 1/2 and no detent position). Now it will only run between the full and 1/2 position, and not enough power to really do any good. When I go to 1/2 choke it speeds up and dies. Won't run at all on no choke. I have cleaned spark plug, and looked at the zama carb ( I have not fiddled with any of the adjustments just looked inside from breather end and took off the side plate) and it looks clean.
Does anyone have any suggestions?
#5256 17/04/03 07:30 AM
jav8r,
On the carby side with one screw remove the fine wire mesh filter and replace it. Problem should be solved.
Bruce [Linked Image]
17,955 Registered Users
Topics12,726
Posts106,648
Members17,955
(Release build 20251126)
PHP: 8.3.30 Page Time: 0.035s Queries: 18 (0.030s) Memory: 0.6198 MB (Peak: 0.6371 MB) Data Comp: Zlib Server Time: 2026-05-12 14:09:14 UTC
