2 members (Bruce, Gizmo), 6,188 guests, and 1,806 robots.
by nath - 16/10/26 10:48 AM
#65804 14/07/15 08:46 AM
hello everyone
ive just got a rover ranger 27 with a kirby motor model VK60B my problem is i disassembled the motor to check the ring gap and a general inspection of the motor but on removing the rings i failed to notice that the rings have a groove on the inside edge next to the piston and i'm not sure if the groove should be facing up or down so any help and advice on this would be much appreciated.
all the best mehead
mehead #65810 14/07/15 09:39 AM
Damn I just did one lols....Ill check tommorrow if you dont get an answer. Pretty sure the chamfer is skirt side
mehead #65811 14/07/15 09:49 AM
Hello mehead and HT6,
A Ranger with a Kirby. That's an old beast.
This is from my Tecumseh manual and should assist here:-
mehead #65813 14/07/15 09:55 AM
Yep, just checked. Chamfer is uppermost, as per Jacks Diagram. Check ring gap does not exceed 0.020 or you will need to fit a new set. Also make sure your ring gaps are staggered and dont line up with each other when you put the piston in. Eg top ring at 12 o'clock, next ring at 4 oclock and the oil ring at 8. Plenty of oil between the rings also.
Good luck...
mehead #65815 14/07/15 10:05 AM
Hello Mal,
thanks for that confirmation - most helpful.
CyberJack #65822 14/07/15 04:13 PM
thank you jack this info was very help full yes it seems odd but ti's origanal as far as i can see it's an old ranger one of the one's with the triangular tiller steering i think it's from the 60s with the friction drive to axle via chains not a gearbox it should be an interesting ride
all the best mehead
HT6 #65823 14/07/15 04:15 PM
thanks junior technician for your verification of info
Ricko, mreddie, Matfew, Grahamp, ttvgcm
18,162 Registered Users
Posts106,819
Members18,163
