0 members (), 887 guests, and 1,629 robots.
Masport Shitemaster 720 blade
#5215 22/02/02 05:48 AM
Aloha, the machine that im working on consist of a two piece flex shaft, is there any way i could use a steel shaft instead,due to several flex shaft snapping in middle area. If no steel shaft can be used is it possible to use a single length flex shaft which might be a little stronger,also why did they use a flex shaft in a strait shaft trimmer. any knowledge on this will be appreciated thanks, SHANE
#5216 06/04/03 10:01 AM
Shane,
The reason for the shaft breaking would be because when you are using the machine you are reving it up and down a lot. In order to reduce the problem I suggest that you run the machine at full RPM'S as that is how it was designed to run.
I hope that this is of some help to you.
Bruce [Linked Image]
hughyy, Shehdhhe, Bigredmowerguy, astfgl, Bendhaven
18,061 Registered Users
Topics12,746
Posts106,765
Members18,062
