0 members (), 1,450 guests, and 2,040 robots.
#122445 02/07/26 11:19 AM
Friend renting a rural property invited me to have a look through a big junk pile left behind by a previous renter and about to be taken to the tip by property owner.
Got myself several chainsaws and "cough" a couple of other things, and down near the bottom found a brushcutter which was complete and had good compression..
Once home squirted some fuel down the plug hole and it fired up. Put half a tankful in and although in need of some TLC it seems in good nick.
There's no numbers or marks anywhere and the original motor label is long gone, the label on the drive shaft is generic, obviously a very cloney clone.
Anyone able to let me know what it may have been branded or what it looks to be a copy of ?
Hi MM,
I've had a heap of these .Those generic, unbranded Chinese brush cutters are incredibly common, they almost all use the exact same blueprint, parts, and plastics whether they are branded as a "Demon," "Timbertech," "Trueshopping," or any of the hundreds of random names on Amazon and eBay.
While they don't have a single "brand" model name, in the small engine and replacement parts world, they are almost universally classified by their engine family/base design.
Here is what you would call it depending on who you are talking to:
1. The Industry Standard Names (For Parts and Manuals)
If you are looking for replacement parts (like a carburetor, pull start, or clutch), searching for these terms will bring up exactly what you need:
CG430 / CG520: This is the most common designation.
CG430 usually refers to the 43cc variants.
CG520 refers to the 52cc variants (which covers that 48cc to 54cc range ).
BC520 / BC430: "BC" simply stands for Brush Cutter, followed by the approximate engine size.
There are a few different displacements of this Line Trimmer.
2. The Generic Description
"Generic Chinese 52cc 2-Stroke Brush Cutter" (or 43cc, depending on the exact displacement , I just find displacement and search ?? cc line trimmer online ).
3. The "CE" Sticker Meaning
That "CE" sticker isn't a model number; it stands for Conformité Européenne. It just means the manufacturer is claiming the tool complies with European health, safety, and environmental protection standards so it could legally be imported.
💡 Quick Tip for Finding Parts
Because these tools are all cloned from the same classic Japanese designs (mostly old Komatsu/Zenoah or Mitsubishi blueprints), the parts are wildly interchangeable. If you ever need to fix it, just type "52cc brush cutter [part name]" or "CG520 [part name]" into eBay or Amazon, and 95% of the time, it will bolt right on!
Thanks for all that helpful information Max.
Over the years I have either wrecked or given away various 2 stroke brushcutters which came my way, My current brushcutter fleet are three Hondas and a BBT 4stroke. Hate the noise, the smell and the need to constantly pfaff around with the throttle of two strokers.
This clone is now running perfectly.
Judging by the force needed to pull on the rope it is likely to be a 50cc job. When it is being given away to someone in need of a brushcutter your info will be included.
Hi MM,
It sounds like it could be The 1E44F-5 is a common 52cc, Engine Specifications Displacement: 51.6cc to 52ccPower Output: Typically ranges between 1.4 kW and 1.8 kWOperating Speed: Max engine speeds of 6,500 to 8,500 RPM, with an idle of around 3,000 RPMFuel Ratio: Requires a 2-cycle oil to gasoline mixture, commonly at 25:1
I usually keep them as they use them in a ton of equipment and are a handy motor for a lot of projects.
Lawn & Garden Equipment
Heavy-Duty Brush Cutters / Whipper Snippers: This is the absolute "sweet spot" for this engine. It is the default motor for almost every unbranded, budget straight-shaft brush cutter on the market.
5-in-1 Multi-Tools: The exact same power head paired with quick-release split-shafts to switch between a line trimmer, pole chainsaw, hedge trimmer, and brush blade.
Mini Garden Tillers / Cultivators: Because the 51cc motor is lighter than the 61cc, it’s the most popular choice for those small, lightweight tillers used to churn up garden soil and flower beds.
Lawn Edgers: Dedicated wheeled or stick edgers used to cut clean lines along sidewalks.
2. Recreation & Gas Toys (The "G-Scooter" Engine)
Stand-Up Gas Scooters: If you see a generic Chinese gas scooter (often called a "Stand-Up Extreme" or "Mach 1"), it almost certainly has this 51cc/52cc engine bolted to a small chain-drive gearbox.
Gas Skateboards / Motoboards: Off-road skateboards with hand-held throttle cables and a 51cc engine mounted over the rear trucks.
Pocket Bikes & Mini Dirt Bikes: Small "pocket rockets" (like the generic MTA2 or X1/X2 styles) and 50cc-class kids' dirt bikes.
Drift Trikes: Custom or factory-built three-wheelers with slick PVC rear tires for drifting on asphalt.
3. Farm & Construction Tools
One-Man Earth Augers (Post Hole Diggers): While the 61cc is used for heavy, two-man augers, this 51cc engine is the go-to for lightweight, one-man post hole diggers.
1-Inch Water Transfer Pumps: Lightweight, portable pumps used by farmers and homeowners to move water out of flooded areas or trenches.
Gas-Powered Fence Post Drivers: Handheld pounding tools used to drive T-posts into the ground using a heavy internal piston slammed by this motor.
Portable Winches: Small, gas-powered capstan winches used by hunters to drag game or loggers to pull small trees.
4. Marine & Special Applications
Kayak & Dinghy Outboards: Extremely popular for budget, air-cooled 2.5 HP to 3 HP outboard motors used on small fishing boats and inflatables.
Gas-Powered Concrete Vibrators: Used on construction sites to settle wet concrete and remove air bubbles.
The Secret to this Motor
Whether the sticker on the plastic shroud says 51.2cc, 52cc, 517, or has a brand name like Demon, Texas, Viron, or Timbertech, if it has a 44mm cylinder bore, it is the exact same engine. Parts are universally interchangeable, dirt cheap, and available everywhere.
18,141 Registered Users
Members18,141
