0 members (), 1,571 guests, and 2,170 robots.
#5215 22/02/02 05:48 AM
Aloha, the machine that im working on consist of a two piece flex shaft, is there any way i could use a steel shaft instead,due to several flex shaft snapping in middle area. If no steel shaft can be used is it possible to use a single length flex shaft which might be a little stronger,also why did they use a flex shaft in a strait shaft trimmer. any knowledge on this will be appreciated thanks, SHANE
#5216 06/04/03 10:01 AM
Shane,
The reason for the shaft breaking would be because when you are using the machine you are reving it up and down a lot. In order to reduce the problem I suggest that you run the machine at full RPM'S as that is how it was designed to run.
I hope that this is of some help to you.
Bruce [Linked Image]
BeardedBiker55, odkmower, luddite dave 01, Flanderino, 4x4stretch
18,069 Registered Users
Topics12,747
Posts106,768
Members18,070
