1 members (1 invisible), 2,043 guests, and 207 robots.
by Bumps - 19/03/26 11:57 AM
Mower wheel ID.
Shout Box
by geobee - 14/03/26 08:36 PM
Victa Super 24/600
by Doug - 07/03/26 07:07 PM
Eaton Model 6/7
by Bumps - 01/04/26 05:37 PM
Mower wheel ID.
Eaton Model 6/7
by Bruce - 20/03/26 09:50 AM
by Bruce - 19/03/26 11:52 AM
Shout Box
by Bruce - 16/03/26 08:10 AM
Early Morrison rotary mower
#96608 25/02/19 08:51 PM
I'm having a problem with the later current rounded style of Victa catchers that are almost always missing the inside plastic screen. This was always a problem with the Rover catchers. I bought a sheet of perforated metal and started making screens for the Rovers, mainly because Rover catchers were a bit hard to come by. I kept putting the Victa catchers to one side as I always had a reasonable supply of them. I have made up a pattern for the Victa ones but now I am running out of the perforated metal, I should have bought more sheets when I had the chance. Anybody have any thoughts on what else I can use?
NormK #96613 26/02/19 12:28 AM
Hi Norm, i too repair the rover catchers but don't bother with the victa ones.
i've never bought mesh/perforated metal; What i use is the aluminium mesh from the large satellite dishes. Come hard garbage season I reckon i see 2 or 3 dishes on the curb and just go out and cut the panels out using a decent knife.
NormK #96615 26/02/19 05:49 AM
Thanks BT, I haven't bothered repairing the Victa ones before but the pile I'm ending up with is getting a bit of a problem. Once you split the catcher it is quite straight forward to make up a screen. As for satellite dishes, can't say I have seen any of those on hard rubbish around here, but I will keep an eye out. Also BT was it you who pointed out to me that a catcher I have on Gumtree is an early Morrison 3 in i? Not sure if anybody would ever want one but it saves me cutting it up and putting in the rubbish bin. I try and get rid of a couple of catchers each week in the bin
NormK #96629 26/02/19 01:57 PM
BT, if you can cut that mesh with a knife then it can't bee too rigid, how do you get it to hold in place?
NormK #96639 26/02/19 10:12 PM
Hi Norm and all,
I've had a few catchers with wire mesh cable tied to the outlets of the catcher and a few had plastic gutter guard instead
of wire mesh.
The gutter guard could be cable tied together so it's the correct size for Rover catchers etc.
NormK #96641 26/02/19 11:52 PM
i use a 5 mm diameter rivet and a washer to secure the mesh.
It's aluminium mesh, so it's soft enough to cut with a knife or scissors but far stronger than the plastic rubbish that rover used in them originally.
Ohh, and yes that was me that messaged you on Gumtree.
NormK #96648 27/02/19 08:43 AM
Thanks BT, I had one of those Morrison mowers and it had the wood chipping chute on it. Never tried to see if that worked or how effective it was. At least with all the old Victa catchers I am chopping up I get the old steel screens so I can make them fit the later catchers, problem is I have more of the newer catchers without screens than old catchers with screens.
Hi Max, I don't think I have seen the micro screen, I will have a look and see what I think.
This stuff might work, pity it is only 200mm wide
www.ebay.com.au/itm/10M-20M-30M-Gut...-Mesh-Home-Silver-100x20cm/263818365707?
NormK #96658 27/02/19 01:14 PM
I did see this 300mm mesh at Bunnings it may be another option Norm.
The Rover catcher mesh is under 300 mm,
NormK #96659 27/02/19 01:53 PM
That looks good Max, even if I had to put one layer above the other to reduce the hole sizes. I will check it out. I need 320 for the Victa ones, but I might be able to sneak it in with 300mm
17,902 Registered Users
Topics13,076
Posts107,348
Members17,902
PHP: 8.3.30 Page Time: 0.076s Queries: 36 (0.066s) Memory: 0.6593 MB (Peak: 0.7267 MB) Data Comp: Zlib Server Time: 2026-04-01 11:13:48 UTC
