1 members (Buckets),
1,995
1,534
Posts: 8,215 Likes: 235
I need to replace the drive belt on my mates Anniversary model up the bush and I need to work out what size belt it is. On the manufacturers plate it says GT 1985, does anybody know how many inches this is in an "A" section belt
Posts: 113 Likes: 2
Thanks Buckets I have seen that, it gives me the inside measurement, the outside measurement but it doesn't actually give me the actual belt size. I need the belt quickly because I picked the new motor for it today and as soon as I get a belt I will head up the bush with it
Posts: 113 Likes: 2
I'm sure you have much more experience with mowers than me, but for my own experience could you explain why you can't just buy a GT 1985 or SPA850 belt.
I had to call into my local mower shop this morning for some other stuff and it intrigued me enough to ask about these belts, he said that he had both in stock and were around $20 & $30 bucks respectively.
I also asked about the A section belt and he said that they don't recommend them for this machine, as the V section of the belt (can't remember which)was either too shallow or too deep and prone to slippage.
Again I'm sure you have your reasons but I'm intrigued.
Ended up doing just that buckets, just meant I had to drive to the Greenfield dealer when the bearing joint is just around the corner
Posts: 113 Likes: 2
Aahhhh, now I can sleep tonight
Posts: 407 Likes: 2
I've noticed the general A section belts of the same size don't last long on John Deere mowers compared to the genuine Kevlar John Deere belts. There's a $40 price difference though!
Posts: 113 Likes: 2
LTR, I put one on my evolution and found I had to tighten it too the second last ratchet slot to get traction, where as the genuine greenfield belt let me with 3 spare slots for future tightening, but again the price difference was similar to yours.
I remember from a million years ago there was a product called "belt grip?" to stop belts from slipping, not sure if it is still available
Posts: 1,842 Likes: 14
Yep, it's a CRC aerosol product - bearing services have it, and even SuperCrap Auto list it.
Cheers, Gadge
Posts: 407 Likes: 2
LTR, I put one on my evolution and found I had to tighten it too the second last ratchet slot to get traction, where as the genuine greenfield belt let me with 3 spare slots for future tightening, but again the price difference was similar to yours. This A section belt came off a John Deere LA115 mower deck. It's interesting how long it lasted in that condition! ![[Linked Image]](https://www.outdoorking-forum.com.au/forum/uploads/usergals/2017/06/full-6946-34747-image.jpg)
Posts: 407 Likes: 2
Yep, it's a CRC aerosol product - bearing services have it, and even SuperCrap Auto list it. This is it: I don't think it would last long on a mower deck exposed to all the dirt though.
I fitted a 13hp Chonda in this mower yesterday but I'm in a bit of a pickle as to what to do about a fuel tank. Anybody have any pics of what they have done or any suggestions. I only rant the motor for a minute because the original throttle cable was too short, but what I don't get my head around is the way the throttle works. It is under spring tension which holds the butterfly fully open so what that means is if the throttle cable should break or dislodge the motor will go full throttle? Any thoughts?
Posts: 407 Likes: 2
I fitted a 13hp Chonda in this mower yesterday but I'm in a bit of a pickle as to what to do about a fuel tank. Anybody have any pics of what they have done or any suggestions. Maybe a tank in front of the firewall like a Viking mower? Otherwise, a fuel pump would be required. what I don't get my head around is the way the throttle works. It is under spring tension which holds the butterfly fully open so what that means is if the throttle cable should break or dislodge the motor will go full throttle? Any thoughts? The governor spring should hold the throttle butterfly wide open when the motor is stopped. There should also be a slide mechanism that the hand throttle cable connects to in order to regulate the revs. What happens when this motor is running? It depends if the throttle cable slide boss moves without the cable on. Usually they have some resistance. Depends on how it's all been put together I guess! If possible a picture of the control mechanism would be helpful. (I presume it's a clone of the Honda GXV390)
Sorry LRT, no pics as it is at my mates place out of Ballarat which is always a problem for anything I have to make for it. The spring tension holding it full throttle is fairly strong, but I was running out of time and it was getting dark and I just wanted to get it fired up before I came back home. I have to make up a petrol tank and lengthen the exhaust manifold pipe so the muffler clears the bonnet. When the motor is running I have to hold the lever where the cable connects to back hard under this spring tension otherwise it will go full throttle. I'm thinking the spring may be somehow connected to the wrong side. I will go back up once I have made up the bits I need and see what I can work out. It is one of these motors http://www.ebay.com.au/itm/13hp-rid...tart-vertical-shaft-petrol-/281070932761
Posts: 407 Likes: 2
Sounds like the governor mechanism has been assembled incorrectly. Some of the Millers Falls Chinese go carts are linked up directly to bypass the governor.
Yes travelling long distances certainly makes it hard sorting out all the little difficulties. Even more so when you realise you've forgotten to pack the part or special tool you need!
Certainly didn't feel like the governor was working, but I didn't have time to really look at it too much but I would say you are on the right track
Posts: 407 Likes: 2
Hopefully it's got a governor mechanism inside!
Hi Fellas, been a while, haven't been well but you push on. Anyway back to this Anniversary model, motor is running well but my mate says that when he has the cutter deck in the lower positions it cuts much better in reverse than in forward motion. Before I head up there does anybody have any idea as to what could be causing this. Without looking at it I'm a bit stumped as to a cause.
Can anybody tell me if the cutter belt adjuster on the Anniversary is the same as the 5XL, using the right hand rear pulley as the adjuster. My problem is this mower is a 3 hour drive away and I'm having trouble explaining it to my mate. The next issue is the belt he has taken off it is 2 inches shorter that the one listed for the Anniversary but this is still too long. My problem is that for the shorter belt to have been operating fine previously then some previous owner must have altered something. Is there adjustment on the rear right hand pulley as it is on the 5XL?
Posts: 567 Likes: 2
MOD & GREENFIELD TECHNICIAN
G'day Norm,
These 'newer' models are definitely not my strong suit- if fact all I've ever done to them is part them out.
I tried to have a bit of a look at the IPC in the manuals section (finally found it) but it wouldn't open properly.
I've got one out in the shed. Let me have a look at it today.
......belt adjustment on these newer machines is a bit of a constant. Would be good to get to the bottom of it all.
G'day prd, I think I have worked it out,sort of, going back through some old posts it seems there could be 2 belts for these, no idea why, but there was talk of an A100 belt and the A102 belt which is the GT120 belt that is supposed to fit. On googling around the only one I came up with was the 5XL but I have since found out the adjuster is not the same. The anniversary has 3 holes on both the rear idler wheels,( the pics I was looking at seemed like the hole was slotted but my mate has confirmed that the have the three holes. Hopefully he will be able to get the belt on so I don't have to drive up and do it. Cheers Norm
Ok just as an update on this cutter belt problem, ended up using the shorter belt which I think is an A100 and had to slot out one of the holes one one of the rear idler pulleys to get the belt tension right and now it is mowing as it should and my mate is a happy chappie. No idea why the original belt ended up going loose, as it had been working fine before we fitted the new motor.
Posts: 567 Likes: 2
G'day Norm,
'A' member of an elite 'team' used to say, "I love it when a plan comes together!"
Hope the drive was pleasant.
Ok so I am back to my mates Greenfield that has somehow chewed up the drive belt again. I have to explain to him how to release the tension on the spring tension ratchet rod so he can fit a new idler pulley and belt. I remember last time I did I dismantled half the bodywork to get to the rod to release it but from what I remember it was simpler than that but I have forgotten how it was done. Once the spring is removed somehow you can move the rod backwards over the ratchet but I can't remember how I did it. Anybody got any tips and if it can be done without pulling the bodywork around the steering off because we can't remove the steering wheel? Trust me I tried that some years ago when I had it in the press and the only thing that was going to happen was the steering wheel was going to break.
Posts: 567 Likes: 2
G'day Norm,
Sorry, meant to reply earlier but needed to look at the Anniversary in the shed first as I've never done a belt change on one of these before. Unfortunately there is not enough of the drive tensioner left for me to look at in order to help with your question. I notice there is an owners manual for the Evolution in the manuals section and it seems to be a similar setup (?).
Sorry I can't be more help.
Thanks prd all good, my mate took the spring off and he was able to move it in and out but mine is rock solid and I guess I will have to remove the bodywork to free it up. Not sure if it is rusted or stuck on the ratchet
Members18,145
