0 members (), 7,737 guests, and 434 robots.
Hi guys,
Trying to get one of my mowers up n running and wanting to rebuild the carb, but having trouble figuring out what carby I have so I can find a rebuild kit.
The mower says
VICTA TVS90 - 46114E
[Linked Image from i998.photobucket.com]
Stamped on the carby it reads: 1651F8C ... but I can't find anything on a 4 digit carb.
http://www.tecumsehcarburetorguide.com/carburetor-identification/
Reading through here, http://www.mymowerparts.com/pdf/Tec...YCLE-L-HEAD-FLAT-HEAD-ENGINES-692509.pdf
there seems to be a few versions, though I think this is closer to a series one.. then again my carb seems to have a removable plastic cap covering an adjustment screw.
Any help would be super smile
Here's a list that includes the higher four digit model codes - http://outdoorpowerinfo.com/engine_specs/tecumseh_carb_mfg_no.asp
But it only brackets your model! However, it's pretty likely that the part number listed for both #1650 and #1652 will fit.
That's P/No 632795A - so just search for 'Tecumseh 632795a' on FleaBay. Plenty of cheap clone carbies out of Hong Kong and China there.
Thanks Gadge smile
Looks like that P/no is for a whole carb replacement, though I think I only need a few bits for it, such as rubber seals/o-rings, washes etc.. i did come across this though,
http://www.ebay.com.au/itm/Carburetor-Carb-Repair-Rebuild-Kit-632760B-For-Tecumseh-HMSK-HSSK-LH-OH195-OHH50-/141952857816?hash=item210d0cb6d8:g:uyoAAOSwz2lXByq0
Looks like it has much of the pieces I need, though not 100% sure if the main Float Bowl Gasket is that same circumference.. thinking I'll grab that being 1/4 the price of the carb.. thoughts ?
Well, the carby is really the 'Achilles' Heel' of Tecumseh engines. And OEM parts are very thin on the ground now.
If you read a few of the threads in this section of the forum, the prevailing ODK attitude is to just replace the entire carby. Just watch the fuel inlet elbow material on the aftermarket carbies - I'd avoid the plastic ones.
That kit doesn't look like the right one for a TVS90 engine. This webpage has useful info on OEM/aftermarket part numbers for these kits: http://www.psep.biz/store/tecumseh_carburetor_kits.htm
Originally Posted by Widget
Hi guys,
The mower says
The carby part number is 632795A below is a breakdown of it which you could order the parts from the [b][color:#FF0000]ONLINE STORE[/color][/b] cheers2 :
Tecumseh Carburetor 632795A
18,214 Registered Users
Posts106,871
Members18,214
