Posts: 715 Likes: 1
seanw
hello. was given this mower today ![[Linked Image]](https://www.outdoorking-forum.com.au/forum/uploads/usergals/2016/11/full-9141-31303-dscf7604.jpg) owner unable to start upon inspection found slight anomaly ![[Linked Image]](https://www.outdoorking-forum.com.au/forum/uploads/usergals/2016/11/full-9141-31304-dscf7607.jpg) would i have to replace the engine with the same 190cc or could i use smaller? maybe rebuild thank you
motorwannabe
Posts: 1,548 Likes: 25
Why replace it that is perfectly fine just well ventilated.  Actually it beyond hope except for the spares. I usually try replace with the same size engine or slightly larger.
Posts: 4,675 Likes: 165
Can't you just rivet some tin with over the crankcase? Only two strokes need an air tight seal.
Hmmm, spoke too soon. Get another engine!
Posts: 8,215 Likes: 235
Briggs do that Sean, base looks ok, wheels are good,handle fold down bolt look good, great score
Posts: 715 Likes: 1
seanw
thanks lawnmower aficionado's although i like the idea of tin and pop rivets. and i could not find any pop rivets. had a bit of a look round and found this ![[Linked Image]](https://www.outdoorking-forum.com.au/forum/uploads/usergals/2016/11/full-9141-31308-dscf7608.jpg) seems to be in disguise. ![[Linked Image]](https://www.outdoorking-forum.com.au/forum/uploads/usergals/2016/11/full-9141-31307-dscf7609.jpg) would this be a suitable donor motor? Thankyou Sean
motorwannabe
Posts: 4,291 Likes: 4
Now there's your problem.You forgot to check the air cleaner.I have to ask though.Is it worth fixing?
That motor will fit straight on Sean, best to make sure it runs before you bother swapping it over
Topics12,767
Posts106,834
Members18,193
