0 members (), 6,608 guests, and 1,445 robots.
#766 20/06/00 03:42 AM
A
Anonymous
My old Poulan 306A runs ok until it gets hot. After hot it quickly dies out after started and needs choke to keep it running. I also have a 245A which runs very good until it runs out of gas. After refillng, it is very difficult to start and doesn't even fire. It acts as if it is flooded. I heard the coils on these older models sometimes quit working when hot. Any suggestions on my problems. I have a new stihl which I use for general purpose, but use these old saws on my chainsaw mill.
Thanks in advance.
#767 21/06/00 08:02 AM
on the 306 I would change the fuel
line, most common problem that caues
this problem is the plastic in the line
as it ages, tends to collapse,
on the 245, just check for fire at the
plug when it refuses to fire, and go from
there.
Bill Greer
#768 21/06/00 02:17 PM
Good advice Bill ,I work on just Stihls but
their all basic the same.Cory when they run out of gas they all are hard to start. I would hate to tell you to start changing parts as in fuel lines , but that sounds like the problem.
#769 08/07/00 07:37 AM
Yes , an old fuel line could be causing "VAPOR LOCK" but afew other things you need to check is 1 take the muffler off and see if the exhaust port is plugged or restricted at all. Also see what condition the piston and cylinder walls are in. 2 check the crankshaft seals,one behind the clutch/sprocket and one behind the flywheel. and 3 check to see if the cylinder gasket is leaking, and also the intake and insulator gasket behind the carburetor. mk.farnam@gateway.net
#770 12/07/00 04:10 PM
Cory,
Everyone has given you good advice but forgot to tell you to replace the fuel filter in the tank. I would be doing that first then try the rest.
Moderated by  Bruce, Mr Davis
18,156 Registered Users
Members18,156
