1 members (Red Rum), 717 guests, and 697 robots.
by NormK - 01/12/25 05:15 PM
by NormK - 09/12/25 09:14 AM
Victa 24 with PT fitted
by NormK - 05/12/25 09:55 PM
Lectron Generator Fuel Pump
Greetings all.
New member here, have been lurking for while and I have been inspired by all the "reel Mowers" on your wonderful forum. Was stalking Gumtree waiting for a good buy and was able to snap up a (correct me if i am wrong) SB45 17" series 2 twin rail with what i think could be the original motor. She Starts and runs nice but the land roll clutch seems to stuck and engaged. The plan is to strip her down and paint/replace anything that needs it and use as my daily driver.
Hi "dingaling" ??
Well that's an unusual user ID. Oh well horses for courses I always say.
Welcome to the forum and it seems you've already been well versed in the Scotty lingo. Yes it's correct that you have obtained a Model 45 17 inch Series II mower. It's a tad unusual that it's fitted with a HK30 as most of the Kirby powered 17 inch machines had HK25's which is what the sticker on the tank actually states it has but the ID label says it's a HK30. The HK30 was a 3 HP engine and not a 2.5, so either someone has changed the tank or the air cowl has been substituted at some point. It should have a Kirby engine mounted from original as the Briggs power plants didn't come online until a bit later. I would check very closely around the engine mounting area for fine line fractures in the paint which would indicate stress fractures underneath the finished surface in the rails. If there are any fractures I would get those repaired before you go too much further as the problem is terminal if not corrected and the sooner the better.
Once again congrats on a superb new lawn ride.
G'day Dingaling and welcome aboard. It would seem a lot of the members spent some time lurking in the shadows before deciding to join, I know I did. I went through the history pages and read a LOT before signing up. 'Tis an interesting choice of name and a nice looking machine you've got there.
This
G'day Dingaling! Welcome to the Out Door King!
I got my first Reel mower just the other day 2, got 2 at the same time. One has been moved on now, keeping the other. Just happened to get it of Gumtree as well laugh .
Hope you have a great time on ODK mate, its a great page!
Cheers Mate!
Thanks for reading!
Hello from me too!
BB, I have found other examples labelled as 2.5 but fitted with the HK30.
These include 45 62273 and 45 65020 (from my records). So, I feel it is
all original kit. Perhaps it was governed to a lower rpm?
It should be a nice project and one to follow. There would be plenty
of life in this one, and should serve you well.
Thanks for the warm welcome.
I thought the name would get a few comments, wasn't my first choice. Comes from the banter at work.
Apologies for the rotated pics, couldn't work out how to rotate. (first ever forum)
If proven to be original engine, I would lean towards keeping it. As long as it up to multiple mows a week. (i have Kikuyu)
Anybody had any experience with removing rust with electrolysis as opposed to sandblasting. I don't know average sandblasting cost but could set up an electrolysis bath very cheaply.
Hello dingaling
'dingaling' may also mean an 'eccentric' - a compliment in my view.
I'm confident the engine is original [I hope BB agrees].
Here's another 450423 with a HK30:-
https://www.outdoorking-forum.com.au/forum/u..._BONNAR_-_Model_45_Restor.html#Post68140
There has been some discussion on electrolysis for cleaning.
Just type that key word in the blue search bar and you will find it.
I guess you know powder coating is out when it comes time to repaint.
I've had a play with electrolysis. I was impressed and plan to set up another bath soon. Just don't forget to use mild steel in it and NOT stainless or gal as it will produce some horrid chemicals that you REALLY don't want to be around. I didn't get my first choice of handle either but here I am!
This
Hi All,
I'd be inclined to say that it's the original power plant (as Mod CJ has suggested).
I would strongly recommend you look for any stress fractures radiating from the mounting holes in the chassis. My reasoning for saying this is that the clutch has been at some stage replaced to the current style unit with the 2 90 degrees opposed grub screws. When these clutches are fitted it is for a reason, and that is the previous clutch half was flogged out and in the process would've induced some vibration into the chassis. The twin railers were so prone to suffering from this issue and thus why I'm suggesting you have a good look before going overboard. This isn't a hard thing to solve but it must be done as it will lead to terminal failure in the long run.
Evening all,
I think I will go down the electrolysis path when the time comes.
So I spent a couple of cold hours in the shed tonight, Started by removing the handle bars and cables then grass deflector. Then proceeded to remove the engine bolts and undid the grub screws on the clutch. No trouble removing the engine but the clutch decided to come off with it. It should of stay on the PTO right? Inspection of mounting holes look promising from the top anyway, have not removed rollers yet. Please leave opinions on mounting holes. Light is not the greatest in my shed so I so I'll take another set outside if inconclusive.
Spent more time on my SB. closer look tonight at the rails and the rear rail has sagged. I'm guessing this is easy fixed.
Also removed Chains and Sprockets tonight, My novice eye tells me they need replacing. Can't seem to upload photos at the moment.
Tried to remove the reel, got one of the bearing caps off, but on the other side all I managed to do was chew out the screw heads which was a bit annoying. Anyhow will attack it again tomorrow.
Hi,
Wow, rear rail sag without evidence of fracturing ? well that's a new one to me. Normally when a rail has sagged it will have a fracture in the vertical section of the rail, but I will say with those shots you provided it looks pretty good. I guess you'll have to strip more paint around the engine mount area so as to reveal what's really going on. If nothing then you are going to require the services of a press and reverse the bending process. One thing that I must stress and that is the bed knife will have to remain in the chassis when doing this procedure as it will hold the chassis rigid and stop the side plates from folding inwards.
To remove those screws one has to use the exact size screwdriver that completely fills the slot and then with solid downward force tap the back of the screwdriver while applying a twisting force. The impact will shock the screw loose.
You really don't want to bugger up a carrier as they can be quite expensive to replace, depending from where you buy it from.
if you not got press block of wood and heavy hammer will do the job, metal very easy to bend. soft blows first check top of rail with straight edge ruler till straight, repaired a few like this
Hey BB could he just use an impact screwdriver? I'm thinking the old school ones that are metal and you hold a little pressure in an undoing motion while striking with a hammer while your mate backs you up with a dolly? Or perhaps a cordless impact driver? Just thinking. I've never had anything to do with a reel mower.
This
Hi Slashburn,
I must admit I've had an impact drive for well over 35 years now and in the days when I bought it I never experienced any joy with it and did nothing more than tear open the slot. I find that a correct sized screwdriver is far more controlled for me, but who am I to say it doesn't work for anyone else ??
and for Freebird, once again a press is far more controlled than a blow with a hammer, hammers don't get used much on my bench apart from plastic assembly hammers such as a Thor 412 Plastic unit.
BB
Thanks for the input BB and Slashburn. Didn't make it to the shed tonight but I fear I may have to use another method than the trusty screwdriver. I really did make a mess of the heads, I did oil them up and tried to shock them to no avail. I'm going to have to replace them anyway so if the screwdriver still fails, I'm thinking of using an ez out.....good idea?? Still having internet issues so no pics. Must say i am having fun and look forward to being in the shed.
Till next time,
Dingaling
Hi dingaling,
An ezi-out of that smaller size may just snap off giving you even more dramas as steel into alloy (diecast) can be a real bugger.
What I would do at this point is accurately centre drill the set screw only as deep as the head and then increase drill sizes until the head drops off. This way you'll be able to release the bearing cap up releasing the reel and you'll still have enough screw shank to put into a vice firmly and manually twist the carrier which will then set you free !!!, so to speak LOL.
I'm with BB there. I have had more luck breaking easy outs than getting bolts out with them. My favourite trick is to weld a bolt to the mashed head of the stuck bolt. The heat from welding helps to loosen the stuck bolt and the new bolt is easy to get a spanner onto. I weld on an oversized bolt if possible.
This
Took your advice BB, worked a treat! thank you very much for the idea. So tonight I removed the rear roller had a look under the rails, haven't scrape the paint off yet, but I think I'm good.
How much sag in the rail is acceptable if any at all, will upload pics
Also what is your opinion on my sprockets
Have a good one
Dingaling
Hi dingaling,
I'm glad that you managed to get the bearing carrier apart without doing any irreparable damage.
On to sprockets, it's certainly done quite a bit of work to wear all those teeth like they have been and also a tad unusual in profile, but on the other hand I have seen far worse than what you have there so it's not all bad news. Much of the wear has probably been more of a case of poor chain adjustment and letting them run too slack.
I don't think you will be able to purchase the land roll clutch sprockets, so you might just have to stay with those but all the others are still available.
As far as the amount of rail deflection that is evident it will most definitely have to be corrected to get correct primary clutch alignment.
Again as I suggested I would be using the services of a press and thus you'll be able to chock the rail in the correct places and only put the pressure on the specified section and not have an effect on the side plates. Hammers should not be used for this type of corrective action, well not in my opinion anyway.
I note that you are also in Adelaide and as such if you don't have access to a press I can help you out as I have one on hand.
17,714 Registered Users
Topics13,031
Posts107,112
Members17,715
PHP: 8.3.27 Page Time: 0.080s Queries: 55 (0.069s) Memory: 0.7401 MB (Peak: 0.8635 MB) Data Comp: Zlib Server Time: 2025-12-10 23:56:36 UTC
