1 members (1 invisible), 1,340 guests, and 848 robots.
by Bruce - 07/04/26 03:39 PM
Atom Spare Parts For Sale
by Bruce - 07/04/26 03:24 PM
Ryobi Spare Parts
by Bruce - 07/04/26 12:00 PM
by Bumps - 19/03/26 10:57 AM
Mower wheel ID.
Ryobi Spare Parts
Royal Enfield Mower
by Bruce - 05/04/26 03:47 PM
by Bumps - 01/04/26 04:37 PM
Mower wheel ID.
Eaton Model 6/7
#72152 03/02/16 04:52 AM
Hi there guys,
I need a bit of Yelp finding a coil for my 1968 14" Scott Bonnar. I have had it running for a couple of years. Now the coil is going any ideas where to get one cheap. My local mower shop have been great helping me restoring the motor but I can't afford the $85 for a brand new one at the moment
Thanks in advance
Joeyvek
Joeyvek #72176 03/02/16 12:46 PM
Since this is posted under Briggs heading I assume you have a Briggs engine that may need a coil. Can you post the engine numbers? Being this old it either need converting to the Magnetron ignition coil or an ignitor installed as it may be just the point system dying and not the coil itself.
A lot of the older can be converted and you should get a use one from a donor engine but need those engine number to see what might fit your engine's setup.
Joeyvek #72177 03/02/16 04:48 PM
Thanks Avb you are right I do have a Briggs engine on it sorry I forgot to mention that
The engine number is 61202 0144 01 6808053. That is all the numbers on the cowelling
Joeyvek #72179 03/02/16 06:43 PM
An oldie actually a 1968 model. Any of following Megatron coils should for the conversion. PNs 398593/395489/793281/793281/591420 are used on 2hp to 4hp engines, such as 60000, 80000, 90100, Quattro, and Classic. You find one a donor engine quite easily.
Joeyvek #72180 03/02/16 11:35 PM
I did the conversion on a 5HP B&S on a Gilson Rotary Hoe I got from the tip shop. I used a coil out of a 375 sprint off an old Rover mower. It was identical except for the mounting hole spacing. Luckily I have a mill in my workshop so a few minutes with a carbide burr to slot them a little and varoom, away it went.
aussietrev #72185 04/02/16 02:15 AM
Here is a list of the conversion coils.
There are three coils used on aluminum, single cylinder Briggs to convert from breaker point condenser to electronic as follows:
397358/697037/395490/395491 are used on 5hp engines such as 130000 series flat heads
398811/395492/398265 are used on 7hp to 16hp single cylinder engines, such as 170000, 190000, 280000, and 310000
Joeyvek #72187 04/02/16 02:29 AM
Bit off topic but on my Greenfield B&S ride on I just used an early Holden coil and run it as coil/points ignition because I have a battery in it for the starter motor, and just because I could. Not suited to a push mower though, sorry to digress
Joeyvek #72224 05/02/16 07:25 AM
Do I have to replace the points of i put a different coil on
Joeyvek #72236 05/02/16 10:30 AM
Joey If your replacing with of Magnetrons (electronic triggered coil) then no you don't need to replace. All though it advisable to remove the points and plug the activator pin hole you don't even have to do that. You would need to cut wire points trigger wire and tape as it would ground out the Magnetron coil.
Now if you putting back a points coil then renewing or replacing the points and condenser is advisable.
Magnetrons are more reliable than the point system as there is no moving parts other than the flywheel. Only one slight draw back and that is it takes slightly more rpms at start up to get things going but the other benefits out weight this. This starting rpms difference is usually not even noticeable.
Joeyvek #72240 05/02/16 06:50 PM
Tha you very much Avb you have been a great help. I can get the magnetron coils pretty cheap so I will go that way. Thank you again guys for all your advice. Will post with an update once I have changed the coils over
17,924 Registered Users
Topics13,080
Posts107,356
Members17,924
PHP: 8.3.30 Page Time: 0.048s Queries: 34 (0.041s) Memory: 0.6666 MB (Peak: 0.7185 MB) Data Comp: Zlib Server Time: 2026-04-17 03:30:41 UTC
