3 members (NormK, Bruce, archernar),
2,663
1,451
Posts: 282 Likes: 1
Greenfield Enthusiast
Posts: 988 Likes: 7
Your engine is a 75cc Suffolk, your machines serial number should be on a plate that is attached to the deck front. Have a look over it to see what you can find.
Posts: 6,938 Likes: 322
Hello gml and Paul. Yep, I guess on these '70s machine there is a plate on the front:- I fear it may have been removed ... ![[Linked Image]](https://www.outdoorking-forum.com.au/forum/uploads/usergals/2016/01/full-7392-26456-2015_03_ebay_atco_04.jpg) It is the mower model, not the engine that will determine the parts. But, the Suffolk engine may be relevant as an identifier if the plate is missing. Hope this helps.--------------------------- Jack
Posts: 282 Likes: 1
thank you jack and paul yes plate is gone,do either of you have a pic of what clutch should look like assembled with coupler,i found one on ebay but not sure if it is for my model
Posts: 988 Likes: 7
Posts: 282 Likes: 1
thank you paul, i just purchased it,question if i may,what holds them on/in?
Posts: 282 Likes: 1
thanks jack just seems a bit strange to me but i am new at this,it must be held in place by tension,i have it put back together(except block of course)cheers
Posts: 988 Likes: 7
When putting it back together you might find it easier to remove the engine from the base, only 4 bolts. Don't remove it all together, take out the bolts and slide it across enough to work.
Posts: 282 Likes: 1
how to tighten sprocket's on drive please,cheers
Posts: 282 Likes: 1
Posts: 988 Likes: 7
Time for some pictures please, I am not sure what the end of the shaft looks like. If it has a key to align the sprocket or a taper on the end of the shaft.
Posts: 282 Likes: 1
i will get some pics tomorrow,it has key way, it undoes the same way as motor turns,so how does it stay on ?
Posts: 988 Likes: 7
It may require a lock nut or a fold over lock tab, pics will help :-)
Posts: 282 Likes: 1
Posts: 988 Likes: 7
Should work OK as the whole assembly is rotating together. Tighten it up as hard as you can with a socket and bar then give the bar a tap with a hammer to finish. If you can work out a way to hold the shaft while tightening even better. Have you got the chain ?
Posts: 282 Likes: 1
yes i have chain,will post again when i have coupler thank's
It's Deluxe B14 -the brass plate is on the back bolt of the mower . I can see it in the pics!!! It's pretty non descript ! It's under the bolt near the starter at the back . It should have the model stamped on it . It looks like it's been painted . It's under the bolt near the starter . Do you know where I mean?? It's oval shaped .
Off topic a bit but saw an ATCO childs car on the Antiques Roadshow the other day It looked like they had just taken the cutter off one of their mowers and put it in the back of the car to drive the wheels. Apparently they were made right through to the 50's and could manage 8 MPH.
Posts: 988 Likes: 7
Geez!! A beauty!!! They loved green didn't they ?
Topics12,743
Posts106,754
Members18,039
