1 members (AMP), 2,653 guests, and 1,616 robots.
Masport Shitemaster 720 blade
Victa Twin for Sale
by benn22 - 02/07/26 05:59 PM
#69427 31/10/15 03:27 AM
So here it is, I believe I paid a fair price but with the intention to undertake a restoration & repower to have a practical mower. Little did I realise how hard parts and service info is on these. I'm super happy with the quality of the machine.
Everyone loves a picture or 2!
No can you ID the mower from the mower number, I cant find any other marking on the frame.
Good looking model, open chain ? Did they have a chain guard, I wouldn't be surprised if they didn't. Is it a runner ? A few more pics of the engine please. Congratulations!
Hi magic1 and paul_c,
Yes they most certainly did have a guard covering the chain as I'd hate to get hit by one if it broke, chain that is. If I recall correctly the earlier machines had SC on the ID plate while the later ones had 17 in the same place which stands for model 17.
I can't understand why your ID plate has had such a hiding. As far as any identification is concerned I feel that it may have originally been fitted with a Villiers 412 Engine being that it's an 8 blade reel and 20 inch machine and also has the extra mounting on the chassis. I have a 20 inch unit here that originally had a BSA 2 stroke on it and used a different engine mounting arrangement altogether.
BB
Cheers BB, I don't know why its so beat up but once it is back together she will be well cared for.
I have a donor supercut with the chain guard so this will go on mine. the motor runs but is going in the bin, leaky junk. I have a new 5hp B&S
Here it is currently.
Two things have got me stumped and I hope team ODK can offer some advice
1. how do I separate the clutch outer drum from the gear? Note the bad wear pattern on the drive gear, see point 2.
2. this bearing is FLOGGED out and needs replacing, how does this come apart?
Any help would be very helpful.
Looks to be all go, don't be to hasty to bin the old engine. It may be of use to someone, looks like a Villiers unit ?
Tacoma (spelling). It uses oil and is not original. I will just give it away.
I have a mark 10 villiers on my donor mower that will be worth something to someone
The engine is in fact a Tecumseh unit. The newer ones aren't that bad as the older versions.
As far as disassembling the clutch set up on a SC is concerned I haven't gotten to that point as mine is fine so I can't really offer much help in that area.
The 5 HP Briggs engine will do rather nicely I'd say.
BB
The motor is pretty old and not worth me fixing.
This bearing is FLOGGED out and has caused a large amount of wear to my drive gears, it needs replacing, how does this come apart?
any help would be great
Hello Magic1 and Mod BB
Great photos for the record there. Really appreciated!
The Supercut are the Penfold's Grange of AUS lawnmowers.
I do not have direct experience with the clutches on these either.
It is of the expanding shoe variety (obviously).
Hopefully, a member will shed some light here.
well i managed to replace the flogged out bearing the crank handle socket is effectively the nut (59) on above once this was undone. was able to replace the bearing. For others bearing part no 64 is a bearing no.6203 40mm x 17mm x 12mm.........and cost $4.20 from veales.
this pic is part '59'
everyone likes pics and i think it is beneficial to other supercut owners to document this!
And here is my donor machine. PM me if you're chasing parts.
any info on this mower would be appreciated.
Hi magic1,
Hows your 20 inch SC project going ?
I must admit that it's sad to see that 18 inch SC wrecked as it's 99% all there and fully restoreable.
Is there anything specific that you need to pull from it as I have one in a far worse state than that and thus would be a better parts donor than a machine that could once again be in a useable condition.
BB
BB, the project is going well, there unfortunately is a massive knowledge gap with these mowers. frown
Currently the mover is looking like this
Totally stripped down and going through replacing all the bearings, which are std off the shelf at auto parts stores and CHEAP, about $4 each.
the front roller takes 6101
the drive shaft takes 6202
the rear drum takes 6303
While i don't want to pinch bits from such a complete mower it does have a few issues including no catcher.
I needed 1x clutch arm from the donor and all of the drive gears. Due to not replacing the bearings in my 20" frame the gears have worn down.
Let me know mate and i appreciate your help.
Any tips let me know.
Rear drum bearing carrier
almost complete and back together.
Hello M1
More great photos for the record on this mower.
SC0408 seems to be an early production number too!
The bearing numbers are most helpful for the record.
Had the previous tenant done regular maintenance the gears
would have been perfect.
p.s. You might find this of interest:-
https://www.outdoorking-forum.com.au/forum/ubbthreads.php?ubb=showflat&Number=71423
The Maestro BB will reply in due course.
Hi magic1 and Mod CJ,
I must admit I'll be very excited (in an interested way ofcourse) to see how this mower works for you once it's all back together and any teething problems are sorted out.
Just wondering if you could get someone to do a video of this "Supercut" doing something for what it was built for, and that's cutting superb lawn surfaces.
BB yay
the final piece of the puzzle arrived yesterday and it is running.
I have spent about $850 in total and im happy.
Photos to come.
Hi all, Just wondering how you removed the reel on the Supercut? I have read the manual and it does not say anything about removing the drive sprocket but I can�t see any other way to remove it. It appears the drive sprocket maybe screwed on? If so it is supper tight and does not want to budge. Any help appreciated.
Also my drive sprocket has lost a tooth. Does anyone have a spare?
Drew
Hello drew2229au
The sprocket will be screwed-on and it will be a LH thread.
A swift shock with softwood and mallet in a clockwise direction
should release the thread.
You can 'lock' the reel when doing this by placing a similar
wood block in the reel spirals.
Thanks Jack, LH thread, no wonder it was tight. Is the other end the same?
Hello drew2229au
Yes, these had reversible reels, so the other end will also
have a LH thread.
If you have the reel ground, the important thing is to fit the
reel to accommodate the direction the reel was sharpened.
This is just a stab but I would assume the other end would be R/H thread, could be wrong but that would be my guess
G'day Norm
Yes, that was a stab in the dark smile
By engineering definition, the thread must be the same.
Reason: when you reverse the reel the driven-side remains the same.
[The sprocket is removed and placed on the other side].
Thanks Jack,
Good to know and didn�t even think about that. The leading edge would be the lower side of the two?
Hello drew2229au
The leading edge will be the higher side, with a relief angle going
to the backside face of the reel.
When you have a reel ground, the vast majority of sharpeners will
relief grind. You would need to specify a flat grind to get otherwise.
The reversible reel was an attempt to get extra life out of a reel
between grinds. As such it favours a flat grind.
I do not recommend reel reversal on any reel mower used for domestic
purposes. The better approach is seasonal back-lapping.
Success. Managed to get it apart after the excellent advice.
Now the reel and sole plate are submerged in molasses.
Anyone who has a spare reel drive sprocket, could you pm me? smile
You got me there Jack, I never thought about being able to reverse the reel
too late to weigh in with any new information.
All that has been stated is correct.
Just waiting on my lawn coming up to a respectable level and will get a video of her in action.
I do have a spare drive sprocket. $30 + Postage. Let me know.
Hi all, I have been trying to remove the front drive shaft. I have removed the drive gear assembly and want to remove the reel drive sprocket. Problem is the drum wants to come with it. Obviously the drum transmits drive to the sprocket. I can't see any grub screws and I'm guessing it maybe splined?
Hi drew2229au
I need a bit of clarification here.
What do you mean by 'the drum'?
July
6 7 8 9 10 11 12
13 14 15 16 17 18 19
20 21 22 23 24 25 26
27 28 29 30 31
Nickb89, rhino343, Josh1234, Lawncutter45, NickAus2050
18,055 Registered Users
Topics12,746
Posts106,765
Members18,056
