1 members (Ritcho),
3,445
1,717
Posts: 715 Likes: 1
seanw
motorwannabe
should be allgood , just take care changing the crank pulley , might be hard to replace it . pretty sure they the same length though , got both cranks here if you like me to measure ? tad dark now though but im sure you can do it there ?
Posts: 715 Likes: 1
seanw
was going to leave the engine on and replace all the parts as i have kept this piston in oil and seems to have great compression, but i may change it out with this as i like the carby ![[Linked Image]](https://www.outdoorking-forum.com.au/forum/uploads/usergals/2015/07/full-9141-22740-dscf4716.jpg) ![[Linked Image]](https://www.outdoorking-forum.com.au/forum/uploads/usergals/2015/07/full-9141-22741-dscf4739.jpg) the 160 in the pic powers. this is one of the first i found and the old self propelled deal is cool want to make it work.
motorwannabe
aaaah ok , then you might find the adapter for the carb is screwed on , no need to pull barrel ? or is it scored up too much . explain a little more mate what you like too do , makes it easier
Posts: 715 Likes: 1
seanw
i have what i believe is a victa powertorque super 600 ![[Linked Image]](https://www.outdoorking-forum.com.au/forum/uploads/usergals/2015/07/full-9141-22742-dscf4755.jpg) The 160 goes great so i was going to put all the parts from it on the 600?. this is it so far ![[Linked Image]](https://www.outdoorking-forum.com.au/forum/uploads/usergals/2015/07/full-9141-22743-dscf4757.jpg) The g4 carbies suck. What can i use these on? ![[Linked Image]](https://www.outdoorking-forum.com.au/forum/uploads/usergals/2015/07/full-9141-22744-dscf4737.jpg) . Mate thannks
motorwannabe
what you have is a 550 fullcrank selfdrive , hava a good close look at it for damage/cracks in the base they normally get a beating and not a really strong body super 600 is a lot bigger again . powertorque is in your other post , with the flat top and big boxy muffler at front . love the swamp tyres though
Posts: 715 Likes: 1
seanw
no damage at all vccomm. can i get it going using the other two 160s? thanks for the identification. i would love to get this going
motorwannabe
you could just change it with the storebrand you have , take it complete just change the crank pulley (if its a 160 not 125) 125's had the spark plug offset not in middle . g4's arent that bad , and seems your gunna need to learn soooo , why not now ? just slow n easy and a few there to compare if you get lost in plastic parts . hardest part is the cutout i think , getting them to work can still sometimes be tricky as the odd one just wont play the game !
Posts: 715 Likes: 1
seanw
can i run it with any of those other carbies
motorwannabe
maybe the amal but i think the '18' type are a smaller inlet port
the rain eased up enough just now hahaha , yeh seems the early carb will fit , might havto open up the main jet a little though and needs the plastic insert/insulator . i never tried it
Posts: 715 Likes: 1
seanw
Failed, I left the plastic carby on changed the coil pack . good spark compression fuel. When i go to turn it over with the drill it coughs and splutters and sounds like it is going to explode. as it is the self propelled type cant just change engines as they have no pully and are not long enough. But i have 2 of the same engines that power. I am stummped
motorwannabe
cleaned out the float chamber and jet ? really small hole into the carb body where the jet screws into , clean it out too . really fine wire/tip cleaner or carb spray and air best i can see both cranks are same length on two 160's i have here one with and one without pulley. a good spark plug that you KNOW runs well ? might just be a little water in there somewhere . you set the airgap too ?
Posts: 715 Likes: 1
seanw
I think the engine may be cactus. the sound it makes when turned over sounds like something is broken with a loud metalic banging sound. how would i swap a motor over and get the pully in the same spot ![[Linked Image]](https://www.outdoorking-forum.com.au/forum/uploads/usergals/2015/07/full-9141-22750-dscf4760.jpg) ![[Linked Image]](https://www.outdoorking-forum.com.au/forum/uploads/usergals/2015/07/full-9141-22751-dscf4763.jpg) cheers vccomm
motorwannabe
just pull the barrel n have a looksee , but not hard to change , no need to be in same spot too as no keyway on these cranks bottom end , just put on a hard surface (vice old rail track something hard , or just a hard steel block one side , hit the other side sharply and it should pop off . just be carefull with the pulley , practise on a couple of old duds 1st . a taper fit so no need to locate anything , the nut will do the job and make sure its tight
Posts: 715 Likes: 1
seanw
So i can put the engine from this ![[Linked Image]](https://www.outdoorking-forum.com.au/forum/uploads/usergals/2015/07/full-9141-22752-dscf4764.jpg) Onto this ![[Linked Image]](https://www.outdoorking-forum.com.au/forum/uploads/usergals/2015/07/full-9141-22753-dscf4765.jpg) ?
motorwannabe
that or the storebrand you had up in other post yes , just change pulleys
Posts: 715 Likes: 1
seanw
Sweet, I will get onto it. Will let you know how i get on Cheers mate
motorwannabe
Posts: 715 Likes: 1
seanw
Will buy bearing puller asap ![[Linked Image]](https://www.outdoorking-forum.com.au/forum/uploads/usergals/2015/07/full-9141-22754-dscf4766.jpg)
motorwannabe
put it on a vice or something solid , give a a sharp hit with a decent size hammer shock it off , vice anvil really solid , these things can break pullers ! i mean the blade boss (rusty looking part) a good sharp hit and off she comes might take 2 or 3 though practise on something you dont need before you try the pulley to get the feel for it 1st . dont forget to change the spacers too or the blade plate will be too low (little alloy things you see on the pullyed engine above the nuts in pic')
Posts: 715 Likes: 1
seanw
I have no vice, they can break pullers?
motorwannabe
they can yes , a taper fit , easiest way is just shock . put on a vice not in it , or something hard steel anvil an old piece of steel really just something solid mate , then hit it with a decent hammer eat will ruin the seal most times so just easy to hit it sharply . not enough to damage but it will leave a bruise
Posts: 715 Likes: 1
seanw
motorwannabe
lift the whole engine . place the boss (rusty looking thing the blade plate fits onto)on something solid ...... then strike the other side of boss with a hammer it should pop off it is a taper fit not pressed on the crankshaft. sort of like a big V inside and end of the crank is too on the outside . i have done it often just putting a sledge hammer on a steel bbq plate on concrete put the boss on sledge hammer and hit the side facing you not the thread though with a smaller ballpein hammer
Posts: 715 Likes: 1
seanw
motorwannabe
yujp . the thing with 2 sort of pins on it they just cover the thread a little . that is the blade boss it comes off , same with the pulley same way to remove it
Posts: 715 Likes: 1
seanw
so if i clamp the boss to something solid and put the nut on and give it a belt with a hammer?
motorwannabe
![[Linked Image]](https://www.outdoorking-forum.com.au/forum/uploads/usergals/2015/07/full-5264-22755-002.jpg) not a great photo but you get the idea ? nooooo , never hit then on the end
Posts: 715 Likes: 1
seanw
sorry mate i am a bit slow on the uptake. shock it. 2 big hammers one under the boss on concrete one to hit the other side. is that right?? thank you for your patience
motorwannabe
hahaha . PHEW no worries , was a reason i dont teach , bad at explaining but you got the idea ??
Topics12,743
Posts106,754
Members18,040
