1 members (Nappy12),
7,112
316
I hope someone could help me with a problem I've got with my Victa 18 Special Toe Cutter. Its an old mower that was used up until about 3 years ago as a working mower. When I got it I cleaned the carby and connected a clean temporary plactic fuel tank. The mower now starts first pull when its cold but if I stop it or it cuts out the mower wont start again when its hot. If I just leave it alone and come back a few hours later it starts first pull. Also it doesn't seem to want to idle really low although it will idle but if you try to idle it really low it wants to cut out. Does anyone know what the problem might be?
Thanks vortex_vulture
could be well down on comp' if you can ? pull off the exhaust have a look for scoring and rings condition . they never did idle too well at low end . easy enough to rebuild though . does it lose power when it warms up too ?
Thanks for that, the compression seems good and the mower doesn't lose power when it warms up but if I stop it, it won't start back up. But say 2 hours later it starts first pull when its cold.
might be a condenser too . but have a sneak peek inside though , its free and still might be a problem , easy and cheapest place to begin  cheers , Dave i take it it is an 18 ? alloy exhaust ??
Yes it is an 18 with the original alloy exhaust fitted. I'll take the exhaust off and check it
goodo mate , easiest place to start , push rings gently with a small falt screwdirver , see how much they move , if stuck ? might be a problem and a good look for scoring move piston down out of the way and see inlet side too , if allgood ... then let the fun begin
Posts: 4,291 Likes: 4
Sounds like she could be wearing out.I had one not so long ago did exactly what your is doing.What I found was due to the heat of the engine it was evaporating the fuel in the carby and couldn't and wouldn't run when hot.I also had another with similar problems but it had very worn rings. One way it could solve the problem was a part Victa made for them was this. ![[Linked Image]](https://www.outdoorking-forum.com.au/forum/uploads/usergals/2015/06/full-5048-22569-carby_extension.jpg) It pulls the carby any from the engine as well as putting a little barrier between them.I'm not saying it will fix the problem but it did help in my case.
Thanks for the responses so far. I pulled off the exhaust and the piston looked alright to me but I'm no expert so I will post up the pics. Today I mowed a fairly large section of the lawn with it. It started first pull but what I found was it didn't want to run in the run position (choke off) so I had to cut the grass with it in the choke position the whole time. After about half an hour it cut out when i hit a section of long grass and i had no luck starting it back up.
One thing i forgot to mention.... when i had the mower running and turned the filter into the run position the rpm would go up a lot and then want to cut out.
Posts: 1,391 Likes: 4
Sucking to much air....As previous members have stated the engine sounds low on comp. The hot start issue, again as stated is a common issue. And in most cases Evaporation is the culprit. The heat shield may help so may over fueling on a full thottle start to get you by, but Id say its probably just tired. A strong engine should have a good idle and a nice smooth progressive throttle range with no backfires or flat spots. Close of the choke if it splutters under acceleration, this may also help temporarily.
After youve done all your engine checks, clean and reset your electrics, before you go any further and see if it helps.
You mentioned sucking in too much air. When I fitted the car by back on I noticed there was no sealing washer... It was just relying on the screw clamp. Is that OK?
Sucking to much air as in through the choke. Remember its just brass gauze , not a filter like later mowers. If its fully open and you hit full throttle it will bog or flat spot, then rev, then possibly die until you close the choke to suit or decrease the throttle.
The carby has no seal, it only relies on the clamp as you noted, it is rarely if at all a problem, as it seals well.
Basically your trying to find the best air fuel ratio by adjusting the choke, not just by the throttle alone. When new, you would have started it on choke, warmed it then set to run. Then you would increase the throttle to suit....But its old and tired and needs fine tuning to get it to run well.
piston looks ok but i little hard to tell , did you give the rings a little push too ? they shouldnt go it much really , from memory they didnt have any sealing on carby just make sure its on all the way and tighten . but its sort of pointing to wear though , getting too hot , vaporising . some of the later machines had a thin plastic type insulator , fitted over the inlet and carb' over that . carb could also be a little blocked that would account for running better on choke too
Hi again, i gave the rings a gentle push and they definitely have movement. I put a brand new spark plug in it this afternoon and gave it another test on the lawn. As usual the mower started first pull and i was able to mow with it. It was hard trying to get it to work in the run position but i was able to fiddle around with it and bring the throttle nearly all the way back and have it fully in the run position. I also had no problems hot starting it today. Is there any little trick that could make it run better. ATM i'm tossing up whether to restore it or not?
to be honest mate , i think before you do too much damage it might be time to do a restore or just an engine rebuild ? by the sound of it seems maybe too much movement in rings ' for the cost of a rebuild (if no piston needed) just rings bearings and a few gaskets maybe$30 /40 depends on where the bits come from , online here is a good place to begin though , in the store . they ask all the right questions too oh yeh , and top n bottom seals too while your at it , not a hard job and the pleasure you will get out if it is a great feeling and i bet as soon as you see the base engineless the bug will bite  Dave
Could some please help with how you set the magneto and adjust the timing on these victa 18s. I pulled the flywheel cover off but I'm unsure how to set it. http://i57.tinypic.com/svml4l.jpg[/IMG]
0.020 in' is the points gap . check its at TDC look feel or use a screwdriver , but if head is off then beaut' ! then rock gently to make sure its at top dead centre . then at 1/8 in before tdc points should just begin to open o.001 to 0.002 if adjustment is needed loosen the 2 screws , one has a slotted hole adjust until points do as required and should be alldone ! simple huh  and be sure to clean points when your done (to be sure to be sure) nothing worse that go through all that and got a spot of dirt in there  . hope that sorts it for you . or i can quote it from the book ? oh yeh , how does the spark plug look after all this ???
Sorry about the late reply. I adjusted the points and now the mower will run in the run position and has not bad throttle control. It also seems to want to run when hot so good news. I was thinking about decarbonising the engine to help it idle a bit better down low. Is that a good idea or will i risk losing compression if i do that?
Posts106,896
Members17,604
Most Online16,069 Sep 18th, 2025
