3 members (Tool, Buckets, 1 invisible), 4,611 guests, and 1,117 robots.
by NormK - 01/12/25 05:15 PM
by NormK - 09/12/25 09:14 AM
Victa 24 with PT fitted
by NormK - 05/12/25 09:55 PM
Lectron Generator Fuel Pump
micka #63894 25/04/15 10:32 PM
Hi micka,
please post a picture of the governor linkage and spring. It sounds as if there is an assembly error. No big deal to put right unless you allow it to over-rev before you fix the governor problem.
micka #63901 26/04/15 02:37 AM
hi grumpy this is what I have, if they turn out
micka #63909 26/04/15 04:42 AM
Thanks micka, Here is the Illustrated Parts List for your 11 hp engine:
http://bsintek.basco.com/BriggsDocumentDisplay/Z6lttJVJ1DajI.pdf
Here is the diagram showing how your links should be set up:
Your engine is shown in Fig. 106. Your links seem correct to me.
You haven't said that you set up the rack and pinion governor control correctly. Here is the Operator's Manual:
http://bsintek.basco.com/BriggsDocumentDisplay/msoBGL-K_ny7tH217FzoPu.pdf
Refer to Page 7 of the Operator's Manual. Here is what it tells you to do to adjust the setup so the governor can work correctly:
micka #63914 26/04/15 08:31 AM
will try thanks grumpy
micka #63927 27/04/15 02:13 AM
hi grumpy I done the adjustments, also I think because I was using the governor spring of the old 12.5hp I used the governor arm off the 12.5, everything looked a lot better and worked, there was a difference in the two arms
micka #63930 27/04/15 04:20 AM
Usually you can tell whether the tension on the governor spring is about right, micka, but not until you've been through all this a few times. I'm glad you've got it running properly, and haven't broken anything or wasted a lot of money along the way.
I'll close this thread.
Blakewell26, Aaron., Peter1162, usher, Sdjr
17,717 Registered Users
Topics13,031
Posts107,112
Members17,718
PHP: 8.3.27 Page Time: 0.058s Queries: 27 (0.053s) Memory: 0.6502 MB (Peak: 0.6878 MB) Data Comp: Zlib Server Time: 2025-12-12 00:13:22 UTC
