0 members (), 10,139 guests, and 1,423 robots.
Hi Everyone,
Is there a guide for removing the whole suspension assembly (front and back) for a 80's-90's rover mower?
Also how do you remove the catcher cover? The rod that it's on seems to have two bushes each end but I don't want to break anything.
Hi SuziRova,
There is a YouTube video showing removal of front axle , in the video he uses long nose pliers to remove the clips but I
use a flat blade screw driver.
The back axle (depends on Rover model) usually has two pop rivets that you drill out at the rear sides to remove a metal
bracket that holds the axle in.
The catcher cover also depends on model ,if there are no locking parts on the ends of the cover hinge rod you just use a hammer
and a small punch to hit the hinge rod out ,once it moves out a little you can use vice grips on that end to wiggle the hinge rod out
but this can slightly damage the hinge rod so you just file it before a refit.
Neill M, Peenuke1, Purgeboi69, JackFlyers, Baga
18,240 Registered Users
Topics12,778
Posts106,882
Members18,241
