1 members (bigted),
7,556
336
Hi, the +1 snapped the starter cord on our old but reliable mower (at least 15 years old). When attempting to replace the cord i noticed that the cord winder cannot be turned (clockwise) to re-tension. However, if I remove the starter unit from the mower, the cord winder turns freely to tension the spring - the spring seems to be functioning okay. But on refitting the starter unit, it still cannot be be turned so as to tension the spring. Maybe the engine seized & the cord snapped when trying to restart? Should I be off to get a new mower? Thanks.
Does the engine turn if you disconnect the spark plug lead and tuen the blade plate from underneath?
Just checked, the plate won't turn clockwise, there's a hard stop. (Should I push it harder?) You can spin it freely in reverse direction from there (I only went half a turn anti clockwise). But it won't go past the hard stop again, when turning clockwise again.
I'm assuming its a 2 stroke here as a lot of commandos were (and when the starter is removed the crankcase is exposed, I would be removing the head as well, something is causing it not to spin, some photos would help greatly
Thanks I'll probably need to find a video instruction for that. What about some RP7 in the plug hole overnight?
Posts: 289 Likes: 2
Assuming it's a 2 stroke power torque... (and pics would definitely help)
Make sure the fuel tap is off, disconnect the fuel line from the carb, undo the 3 bolts/screws in the top plastic cowling and remove it. Then undo the 3 bolts securing the starter to the engine block snd remove it. Should take 5 mins max. The head has the spark plug and decompressor screwed into it, just undo the 4 bolts to remove it.
Can do that.It's 2-stroke.
photos: ![[Linked Image]](https://www.outdoorking-forum.com.au/forum/uploads/usergals/2013/11/full-7328-13083-victacylinder.jpg) ![[Linked Image]](https://www.outdoorking-forum.com.au/forum/uploads/usergals/2013/11/full-7328-13084-crank.jpg)
update: crank now turns piston easily (head is off).
all good (so far,)re-assembled, changed fuel - started 2nd pull.
After pressure washing, noticed big fuel leak from carby(G4)/primer. Next step, replace seals & float?
Sorry I havent been online, chances are nothing was badly stuck, perhaps even a large chunk of carbon had dislodged in the exhaust port and landed in the cylinder. Either way.
If the primer wasnt leaking before but now is, I would carefullly remove the white cap (dont lose the float or the tiny needle) clean it all, and use a new O ring to reassemble.
took the white plate off - unscrewed the screw (jet?), and when removing it, it had tiny bits of disintergrated black plastic in the thread. Cleaned everything and reassembled (but haven't got the new O Ring yet). It now only seems to leak when pumping the primer - however did get it started & briefly used. Still to get the new parts, but not sure about the screw/jet - replace everything?.
Posts106,905
Members17,607
Most Online16,069 Sep 18th, 2025
