1,904
1,887
Hi all i have a briggs with a carby problem ... starts first time n runs for a while n then cuts out have pulled carby down cleaned and guessed the float level setting and screw settings ... does anyone know the settings ?? its model L type E and number is 1917025838 0184010609 any help u can give would be much appreciated cheers arthur
Hi Grumpy and many thanks have been trying to upload fotos as the mower is a doozy having help to upload
To post pictures it is usually easiest to use the fifth icon from the left in the line of icons right above the quick reply window. Just follow Bruce's directions in this thread: https://www.outdoorking-forum.com.au/forum/ubbthreads.php?ubb=showflat&Number=45852&Searchpage=1&Main=8258&Words=%22quick+reply%22&Search=true#Post45852
We need the pictures because there are several things that could be causing the problem, in your fuel system. Unfortunately each of those things involves either having or not having an optional feature on your engine. We need to see the whole fuel system from the tank to the carburetor, to see if it has the optional fuel pump and/or the in-line fuel filter, and which type of fuel tap it has. If it has the pump, we need to know which configuration of hoses it uses and where it is mounted.
Thanks Arthur, so far we know you have a large one-piece Flo-Jet carburetor and you have the multi-turn fuel tap, not the quarter-turn one. Now we need pictures back along the fuel hose shown in your second picture to find out if it has a fuel filter, and if it goes to a fuel pump.
morning Grumpy !! hi all nope dont think there is a filter or a pump ... have cleaned out the tank and carby n guessed setting by ear and does run well lots of power low in revs and smooth thru acceleration i used the info on the link u gave grumpy and worked very well ...dunno why thay call you grumpy ??? seem like a nice bloke to me !!! cheers p.s. what do yer think of the mower chassis ??
 does anyone recognise the mower chassis as a manufactured one or is it home built u think ... ???
Its a rover colt 8, be very gentle on that gearbox, otherwise a pretty solid unit.
It's very simple, which hopefully means less to go wrong and less to fix. However as Joe said, using a gearbox means there is one rather vulnerable item that is expensive to repair. I don't like slipping-belt clutches either, because they wear out belts and pulleys fairly quickly. For a ride-on to keep using when it is 20+ years old, with only home repairs, I like the Greenfield design best of the ones I've seen. That isn't because it is marvellously reliable, it is because it is easy to fix, year after year.
Many thanks Grumpy n Joe yeah i reckon its a great little design did thay make some with bigger cuts and motors??? cheers arthur
In the colt range there was a 5hp variant, while it sounds quite underpowered, I have personally used both and both go quote well, the 8hp was pretty unstoppable in heavy growth, where the 5hp was great for a maintained lawn or dry tall grass.
Topics12,748
Posts106,775
Members18,090
