4 members (MowingManiac, Dandare, Red Rum, 1 invisible), 3,245 guests, and 362 robots.
by Bumps - 19/03/26 10:57 AM
Mower wheel ID.
Shout Box
by mice_elf - 15/03/26 09:12 PM
by geobee - 14/03/26 07:36 PM
Victa Super 24/600
by Doug - 07/03/26 06:07 PM
by Bruce - 05/04/26 03:47 PM
by Bumps - 01/04/26 04:37 PM
Mower wheel ID.
Eaton Model 6/7
by maolizi - 20/03/26 12:48 PM
by Bruce - 20/03/26 08:50 AM
by Bruce - 19/03/26 10:52 AM
Shout Box
by Bruce - 16/03/26 07:10 AM
#34916 19/03/12 09:07 AM
gday guys can anyone help with a cutter deck belt size for a cub cadet series 2500 model 2518 i would be most appreciative regards and thanks
Id think a dealer could tell you that easily over the phone.
thanks rodeobob for your reply i could get the part number but not the physical size its a pricey belt and i was trying to source it from an industrial supply i think they probley gathered this again thanks and regards
You have to be careful.
Sure some of the genuine belts are pricey. But they are worth every cent.
My old man has a 40" ariens. A regular 'A' section belt will last less than a day on the cutter deck on it. It gets hot, deforms and once its thrown itself off once you have no hope, it will end up in little bits.
I got him a kevlar wrapped belt but havent been able to test it much as the grass isnt growing (no rain in south west vic for more than 4 months).
Google the belt part number they gave you. Thats how i got the belt sizes for the ariens. You should be able to refference it to a stens part or similar and that will give you the measurement in inches.
Say its a 30" belt it will be A30 when you are at the shop to order it ask them for an AK30, or A30K that should get you a kevlar belt. They are blue in colour and theres is no exposed rubber on the sides of the belt.
On dads 1440H Airens it is so easy to change the belts for the deck that a kid could do it. You can drop the deck off in a bout 2 mins. So its not so bad for us to mess about with finding a cheaper belt that will go the distance.
But with your cub cadet, if its not easy to swap the belts the real deal could be worth the money.
The belt on dads Rover Ranger gave up the ghost. I got a new one for it and it took over half a day to fit it. You need to unbolt all sorts of stuff under the machine to get the belt on. Stuff right in the middle with nut and bolt so you are hugging the motor skinning knuckles, a job i would rather not do again. I imagine a rancher would be just as bad.
thanks rodeobob for your imput the mowers are my fathers and has since new been hard on deck belts he has two of them and are both the same
i finally found the belt size and its an odd size i was thinking the same as you about the kevlar belt but i think one of the problems is that there is no adjustment on the belt a slight amount of stretch and the problem starts
so what i have done is make an eccentric shaft for the idlers that change the belt direction from horizontal to vertical and that solves two problems so i can use a standard size belt and keep it tensioned
Pazzaboy, mgman, Drennie, RobNich, JLAU
17,905 Registered Users
Topics13,077
Posts107,351
Members17,906
PHP: 8.3.30 Page Time: 0.035s Queries: 25 (0.030s) Memory: 0.6360 MB (Peak: 0.6684 MB) Data Comp: Zlib Server Time: 2026-04-05 06:40:29 UTC
