0 members (), 1,298 guests, and 2,438 robots.
by FiM - 12/09/26 02:12 PM
by mower1 - 05/09/26 05:51 PM
by NormK - 12/09/26 07:48 PM
by NormK - 09/09/26 05:07 PM
#3417 13/06/02 02:09 PM
I have managed to free the piston by using petrol to flush out the metal particles, but the cyclinder is scratched. how much damage can be done before I have to rebore it. Most of the scratches don't actually look to bad. I really don't want to put the money into reboring.
#3418 13/06/02 06:25 PM
Macca
I Cannot really suggest much because I cannot see the amount of damage done. However if the scratching is only minor You could avoid re - boring, By Trying to Re - Hone the cylinder with a cylinder Hone and fitting new piston rings. Check the piston to see if its scratched.
#3419 15/06/02 06:47 PM
Macca, If scratching is minor, the piston may still work fine, you must be sure to remove all metal shavings from the chamber, try using a magnet.
#3420 16/06/02 06:25 PM
Macca
Wash the whole engine block in Clean Kerosene and thoroughly dry with a dustless rag. Or if you have an air compressor blow it out until dry with compressed air. This should remove all traces of metal shavings or grindings.
[This message has been edited by Ben G (edited 16 June 2002).]
#3421 17/06/02 11:34 AM
thanks Ben. so even if the cyclinder is scratched, it will still work but just not as well, right?
#3422 19/06/02 04:48 PM
Macca, using an air commpressor is the best way to get the metal shavings out, if you do not have one you should definitely buy one, all mower mechanics need one.
#3423 06/07/02 09:06 PM
Macca, the scratches will fill up with carbon over time anyway so minor scratches should not worry you. It will get better with time.
7 8 9 10 11 12 13
14 15 16 17 18 19 20
21 22 23 24 25 26 27
28 29 30
abigliazzi, I@mthej9, zoist, Turbothrust73, rsarpal
18,114 Registered Users
Topics12,754
Posts106,797
Members18,115
