0 members (), 6,214 guests, and 2,437 robots.
#3417 13/06/02 03:09 PM
I have managed to free the piston by using petrol to flush out the metal particles, but the cyclinder is scratched. how much damage can be done before I have to rebore it. Most of the scratches don't actually look to bad. I really don't want to put the money into reboring.
#3418 13/06/02 07:25 PM
Macca
I Cannot really suggest much because I cannot see the amount of damage done. However if the scratching is only minor You could avoid re - boring, By Trying to Re - Hone the cylinder with a cylinder Hone and fitting new piston rings. Check the piston to see if its scratched.
#3419 15/06/02 07:47 PM
Macca, If scratching is minor, the piston may still work fine, you must be sure to remove all metal shavings from the chamber, try using a magnet.
#3420 16/06/02 07:25 PM
Macca
Wash the whole engine block in Clean Kerosene and thoroughly dry with a dustless rag. Or if you have an air compressor blow it out until dry with compressed air. This should remove all traces of metal shavings or grindings.
[This message has been edited by Ben G (edited 16 June 2002).]
#3421 17/06/02 12:34 PM
thanks Ben. so even if the cyclinder is scratched, it will still work but just not as well, right?
#3422 19/06/02 05:48 PM
Macca, using an air commpressor is the best way to get the metal shavings out, if you do not have one you should definitely buy one, all mower mechanics need one.
#3423 06/07/02 10:06 PM
Macca, the scratches will fill up with carbon over time anyway so minor scratches should not worry you. It will get better with time.
18,197 Registered Users
Posts106,846
Members18,197
