3 members (Hillman, KevinJP, 1 invisible), 1,363 guests, and 755 robots.
by Bruce - 07/04/26 03:39 PM
Atom Spare Parts For Sale
by Bruce - 07/04/26 03:24 PM
Ryobi Spare Parts
by Bruce - 07/04/26 12:00 PM
by Bumps - 19/03/26 10:57 AM
Mower wheel ID.
Ryobi Spare Parts
Royal Enfield Mower
by Bruce - 05/04/26 03:47 PM
by Bumps - 01/04/26 04:37 PM
Mower wheel ID.
Eaton Model 6/7
Page 2 of 3 1 2 3
#3206 13/05/06 10:09 PM
James,
Have a real close look at the bottom seal because some time I have been caught with them. If you end up having to take the cylinder I would be checking by putting fuel in the crankcase to see if you get bubbles (this shows a leak).
From your reply before I am assuming that the rings are either worn or the cylinder is scored. You can also check this by looking in the exhaust port after taking the muffler off.
Let me know what you find. yay
#3207 14/05/06 09:04 AM
Hi James Looking at your pics I see one of the flywheel fins is broken . .I think you should consider breaking off the opposite fin to help balance the engine once you get it running . Did you get a Tank yet?/ Regards Joe
Joe
#3208 15/05/06 08:07 AM
Hi Joe,
No Tank yet, however Bruce is still looking.
Actually two fins are broken ... if I balance them up will it affect cooling?
James
#3209 15/05/06 08:24 AM
Nasty ... time for a new piston and rebore I think? One of the rings has broken up some time ago and banged up the piston ... can hear a few bits of ring rattling in the exhaust ... no bits remain in the ring recess or in the cylinder (should all the bits have gone out the exhaust?).
Can you still get a piston for these models? I will check the bottom seal like you suggested ... should I just replace it now we have come this far?
BTW if I replace the bottom seal, there is lump of round steel on the bottom of the crank (below the bottom seal) that the blade plate backs on to ... is this on a spline or is this yet another nut I am going to fight with? rolleyes
  • [Linked Image from i56.photobucket.com]
#3210 15/05/06 05:21 PM
James,
I would be doing the following now you have taken the cylinder off.
Go to the parts list and repair manuals and open up the forum for Victa motor manual (you will need password which I will PM you) and click on Victa early model 125cc & 160cc Motors. You will be able to print off and do your repair.
Note:
I would recommend that you replace all bearing and seal, cylinder & piston to do a full reco. woot
Once you have done it you will have a machine that will start on the first pull every time and outlast the motors that they are`producing these days.
#3211 15/05/06 05:26 PM
James,
The washer on the shaft is to protect the oil seal. It is just a push fit on the crankshaft. yay
#3212 16/05/06 09:40 AM
Hi Bruce,
Can you please send pricing on parts for full reco.
James
#3213 16/05/06 07:30 PM
Hi James the lack of 2 fins would not greatly affect the cooling. It will afect it slighly but not really worth worrying over Regards Joe
Joe
#3214 18/05/06 06:31 PM
James,
I have sent the parts today express post, you should get them tomorrow.
Note that I have also put in the bearings as well bday so that you can do a full reco on the mower.
If you have any questions on the reco just post it on the board and I will do my best to help. cheers
#3215 18/05/06 10:47 PM
Hi Bruce,
THANKS!!
Hopefully get some mowing done this weekend!!
Cheers laugh
James
#3216 19/05/06 03:22 PM
James,
Make sure you give the cylinder that I sent a good clean before you install it.
#3217 20/05/06 08:12 AM
Hi Bruce,
Can you please confirm the ring order on the piston ... I have one with white steel layer on black, one black and one thin kinked one. I am assuming like so:
top groove: kinked on then black ring on top
bottom groove: white steel layered ring
James
#3218 20/05/06 10:08 AM
James,
The piston ring that has a silver colour is the top ring and the black coloured is the bottom (one nearest the skirt of piston). yay
#3219 22/05/06 10:18 PM
Hi Bruce,
How do you get the top bearings out? The cam that the points ride on (top of crank) does not look as though it will fit through the top alloy casing of the crank case. There seems to be a shaped hole in the alloy casing, but I dont think it is big enough??? (about 1mm too small)
I had no trouble replacing the bottom bearing and seal.
James
#3220 22/05/06 11:35 PM
James,
Do you have the crankshaft out of the top housing(point side)?
The top crank side should be 20mm shaft and if so the top bearing will be correct.
As to getting out the top bearing you need the crankshaft out then you get a drift to drive the bearing towards the centre as you will see in this drawing.
[Linked Image from i65.photobucket.com]
#3221 28/05/06 07:04 PM
Hi Bruce,
All good now!!
rockband
Thanks!!!
James
#3222 28/05/06 08:13 PM
James,
Does it start easy now?
Suggestion:
I would move the starter around so that is facing towards the back wheel. bigshock
Reason:
When you start the mower it is always advisable that you place your foot on the back of the rear wheel because if you fall over or the compression is high you will push the mower away from your feet. The way it is at the moment you could pull the mower onto your self and cause a lot of hospital bills. chainsaw
#3223 29/05/06 07:57 AM
Hi Bruce,
I moved starter as you suggested. It now starts from cold 1-2 pulls, and hot 2 pulls. It seems to be getting easier to start as I use it more.
James
#3224 29/05/06 10:31 AM
James,
Did you clean the carby jets and did you check the float level (it should be 3/16").
The mower should start 1st pull when hot if it the settings are correct.
You should only have to pull the rope about 1 1/2 foot when hot starting it sounds like an air leak or a carby problem now.
Which side did you put the ring gap on the exhaust side or the inlet side? confused
#3225 29/05/06 03:05 PM
Hi Bruce,
The manual said gaps to exhaust side in my model (hope this was correct). I will re check the float, I calibrated a few weeks ago. The bottom seal is now dry (no dust). I have flushed the carby but not cleaned the jets specifically by dissasembling the emulsion chamber.
James
Page 2 of 3 1 2 3
Greg1402, archernar, The Grasscutter, Bob Jensen, Zee
17,923 Registered Users
Topics13,080
Posts107,356
Members17,923
PHP: 8.3.30 Page Time: 0.602s Queries: 54 (0.460s) Memory: 0.7335 MB (Peak: 0.8492 MB) Data Comp: Zlib Server Time: 2026-04-16 06:05:02 UTC
