2 members (AMP, Dandare), 2,528 guests, and 484 robots.
by MikeDD - 12/02/26 09:45 AM
by Bruce - 16/02/26 12:06 AM
Rover Thoroughbred Model 85
by Bruce - 15/02/26 11:59 PM
by Bruce - 15/02/26 11:49 PM
by Bruce - 15/02/26 11:42 PM
by MowingManiac - 15/02/26 12:40 PM
Victa Corvette 4016
by Bruce - 10/02/26 07:53 AM
Cox ride on
by NormK - 04/02/26 08:14 PM
Page 1 of 3 1 2 3
#3186 28/04/06 10:57 AM
Hi Bruce,
I am planning on servicing my grandfather?s victa, it has not been started for about 5 years. My father had the motor rebuilt about 6 years ago. From what I remember it still had the following problems:
* It seemed to starve for fuel. From my earliest memory of this mower (25 odd years ago) the fuel system/carby has been temperamental ... it seems to have the original setup from the pictures I have seen on the victa site 'http://www.victa.com.au/files/a18a19.pdf'
* The metal fuel tank weeps at the seam (top and bottom part join).
* The fuel tap cork no longer seals
* The starter bowl on the flywheel (I think that is the name of it?) was slipping stopping the ripcord from turning it over.
Any hints suggestions before I embark would be much appreciated.
James
#3187 28/04/06 12:40 PM
Jamesl,
Can you put up or PM a picture on the board so that I can see the motor. What I am looking for is dust collection around the bottom seal and around the join in the crankcase plus where the cylinder bolts to the casing. confused
You could have a leaking top or bottom seal. If it is the top seal the machine will rev high and if it is the bottom seal it will be hard to start. smile
The starter cup on the flwheel is the nut molded into it? If not I can supply or you can get from your local mower shop but you will also need to replace the pawls that grip onto the cup. wink
The tap cork I have in stock for that machine.
As to the tank you can only get second hand. I should be able to locate one.
Please explain how the machine runs as I need this info to give you correct answer. yay
#3188 29/04/06 08:05 PM
Hi Bruce,
I got your manual on the 3F/3L carby and the float lever was about 7/16" so I bent it back to 3/16" as required. Where the cylinder bolts to the crankcase is clean, the bottom seal had a small amount of dust, so I have cleaned it down and will check it again after it has been run again (the motor has only done about 5 hours of work since all these seals were replaced).
The motor started after about 5 pulls and it ran like a charm, stopped for 30 seconds to re-fuel and started again ok. I then stopped the engine while I took it to the front yard and started it about 5 minutes later ... no joy .. I kept turning it over and it would fire with a puff of smoke here and there and stop .. at one stage it ran for 15 seconds at really low revs making a choof ... choof ... choof sound at each firing with a puff of smoke. I let it cool completly down and it started and ran fine again and mowed the front? I then stopped it again, waited 5 minutes and it would not start again until it cooled completely.
I will check the cup to see what type. If I can get it to behave itself I will order the pawls & cup and fuel tap as I would like to use it and it is an airloom. Do you think I could run a tiny bead of red loctite fuel/oil tolerent silicone around the join of the fuel tank to seal it?
Your help is much appreciated.
Thankyou
James
#3189 30/04/06 01:00 AM
jamesl,
1.Can you take out the plug and just check if the white insulator has carbon on it.
2. Did they replace the points and condensor when they did the overhall? rolleyes
3. Did you replace the spark plug (if it is a champion replace it with either NGK or KLG).
If the mower has had a full overhaul it should start by the second pull not taking 5 pulls. When you go to start it do you hold down then brass primer on the carby till fuel flows out before you pull the rope or do you keep pressing it up and down like everyone else? :p
Did you check that the cylinder bolts are tight where it bolts on to the crancase?
Also check the nut that holds the blade plate on and see if you have any shinny part behind the washer.
When it stops on you I want you to take the plug out straight away and check for spark.
#3190 30/04/06 01:03 AM
Jamesl,
As to the tank don't use silicone as most of the time it ends up blocking the carby jets and it doesn't tak much. cool
#3191 02/05/06 09:58 AM
Hi Bruce,
Yes it has carbon coating it.
Well considering I am having a bugger of a time getting the bowl off I think it is unlikely ... do you have some tips on removing the bowl? It has a steel nut that seems to go into the bowl casing .. I will send you some pics.
It is a champion N21, I will get a replacement.
he he .. no I hold it down until it flows from the overflow
Not yet .. will check
No shinny part ... however the blade plate washer was cracked through but it was still holding fast.
Bowl and paws finally completely slipping ... can no longer start. Will do this as soon as I can start it again.
I think it is time to order some parts. I will send you an email to get some pricing on parts.
Mower Pics
James
#3192 02/05/06 06:20 PM
jamesl,
The starter cup (bowl) is no longer available but I have been able to track down a good second hand one that has been machined out. The starter pawls I can supply as well.
Looking at the flywheel you should get away with it at this time. I will snd you prices on the bits and pieces tomorrow.
Just one question about the full overhaul did they replace the piston, rings and cylinder? confused
#3193 03/05/06 08:48 AM
Hi Bruce,
No .. I guess I made a mistake in saying full overhall frown .. it was just the rings, bearings and seals.
Cheers & thanks for chasing the cup down.
James
#3194 03/05/06 09:37 PM
James,
Now we`are getting somewhere. The bet is that they only replaced the bottom seal as the top seal is internal and the crankcase has to be pulled apart.
Did you get a receipt showing what parts that they replaced? Did they give you back the old parts? confused
1.The corks for the fuel tap I have in stock.
2. The starter cup is now in stock.
3. The points and condensor are in stock.
4. The blade plate washer you can use a later model one which is in stock.
5. The tank I am still chasing down but looking good at this stage.
6. The plug is in stock.
7. I will bet my bottom dollar that the ring gap is over 10 thow or the cylinder is slightly scored or the points and condensor are faulty and that is why the plug is getting carbon on it. bigshock
#3195 05/05/06 09:22 AM
Hi Bruce,
Had to get a rattle gun to get the cup off ... it has been on there a looonnnggg time! Now trying to get the flywheel off, it must be on a taper? I can see a key ... but it isn't moving. Any tips? I am soaking in diesel to see if I can get some oil penetration. The flywheel seems to have some provisions for a puller? If this is the case can you use a conventional puller?
James
#3196 05/05/06 08:54 PM
James,
I have the starter cup in stock as well as the fuel tap cork, spark plug, blade plate washer, starter pawls. The tank I am hoping to find out tomorrow. yay
Here is a picture of the cup:
#3197 08/05/06 09:30 AM
Hi Bruce,
I am trying to get hold of a flywheel puller (3 holding bolt with centre bolt type) however the holding bolt provisions in the flywheel don't seem to have threads unless the threads are deeper down than I can see? Do you think there should be threads?
James
#3198 08/05/06 01:37 PM
James,
You will have to tap threads in the holes if it has not been done before. Also make sure that you let it soak with WD40 prior to taking it off. The shaft does not have a taper. :Wavey:
Having trouble locating the tank but I am talking with another friend that has a lot of old stuff and he said that he will let me know shortly. rolleyes
#3199 09/05/06 02:51 PM
Hi Bruce,
I need to get a cleaning die for the thread that the cup will screw onto, do you know the thread and size so that I get the correct one.
James
#3200 10/05/06 12:22 AM
James,
The thread type both ends (Crankshaft) is 1/2" BSF. woot
#3201 12/05/06 08:51 AM
Wow, BSF ... that one was hard to chase down .. hopefully get it today.
I noticed that there is no air filter cartridge in the air filter housing, instead just a fine mesh on the housing itself ... does it require a cartridge or is this standard for these models?
James
#3202 12/05/06 12:49 PM
James,
That air filter is standard. No cartridge is required. yay
#3203 13/05/06 08:49 PM
Hi Bruce,
After cleaning up the threads, new points + condenser, plug, paws and bowl fitted I was excited when it started first go ... there is a hell of a lot more spark now and it sounds much better ... but again after stopping it wont start frown . I pulled the plug at this time as you suggested and it has lots of spark but just wont go.
I checked the bolts that bolt the cylinder to the crankcase and they were tight. What is the next step? I am guessing pulling the cylinder head off and inspecting it? If I do this will the gaskets be buggered during dissasembly? If so I will wait to see if I need rings before ordering replacement gaskets. If I go this far should I replace the bottom seal just to be sure?
Will I need to pull the flywheel off again to perform any of this work?
Thanks ... we will win this one yet ;-)
James
#3204 13/05/06 09:16 PM
James,
You are running the machine with the blade plate on are you?
Have you checked your petrol container for water?
Did you flush out the tank?
Did you clean the carby and the main jet in the centre?
The spark you have is it blue?
Did you check the bottom seal for leaks?
If you check these first and it still doesn't go then move to the next thing to check.
Undo the four bolts holding the cylinder to the crank case and remove the cylinder.
Then take the piston ring off and put it in the cylinder to see what ring gap you have also look for scoring in the cylinder. :Wavey:
Let me know what you find.
#3205 13/05/06 10:42 PM
>You are running the machine with the blade plate >on are you?
Yes
Was completely cleaned - no water
Yes
>Did you clean the carby and the main jet in the >centre?
Cleaned the carby however did not remove main jet to clean the emulsion chamber.
Yes. bright blue
I will check ... am I just looking for weeping?
>If you check these first and it still doesn't go >then move to the next thing to check.
>Undo the four bolts holding the cylinder to the >crank case and remove the cylinder.
>Then take the piston ring off and put it in the >cylinder to see what ring gap you have also look >for scoring in the cylinder. [Wave]
Will let you know
Thankyou
James
Page 1 of 3 1 2 3
Rod Browning, whodat76, HVP, alfie350, Goughy783
17,852 Registered Users
Topics13,065
Posts107,271
Members17,853
PHP: 8.3.30 Page Time: 0.053s Queries: 54 (0.043s) Memory: 0.7391 MB (Peak: 0.8608 MB) Data Comp: Zlib Server Time: 2026-02-16 05:27:23 UTC
