4,497
215
Posts: 4,291 Likes: 4
Wow nobody wants to talk to me about this one.Did I say the wrong thing?
I remember talking about this one when I drpped it off, I reckon its the right engine but the wrong carby personally
No the engine is a 1963 model engine.There's no way that base is from 1963 maybe 1973 but not 63.It is a consul 2 engine.Should have been on the base in the picture above.
Posts: 2,738 Likes: 6
Yep, Its that consul alright, 63-64, ran in 2 and 4 stroke, along side a 2 and 4 stroke corvette, and a utility.
Should have a 3L carby.
Cheers Ty
So would that base I told it off be mid to late 70's base?
I think thats the base for a V121 from 1972-1973, basic series 70 MKII engine, zip start with a G3.
The Model name at the Victa ends was the Mayfair, but it was often called contessa, depending on what the store (in this case retravision) chose.
I believe Victa generally limited the name choices to a few different options, but enough options to make sure you could have a different mane to the guy next to you.
Cheers Ty
Yes that was the sort of thing I was thinking it was.
That contessa has the 125cc engine you have been after.
Cheers Ty
Are you sure?How the heck can you tell?
Spark plug is at an angle, on a series 70 engine, that indicates 125cc.
There is a bulb in the cowl that shows the decompression valve, making it MKII or MKIII.
The sticker is also a MKII sticker, so the serial should point to 1971-1972.
You will find the muffler clips attach to little pegs, as the head is not bolted to long bars, the cylinder is bolted direct, like earlier 125cc's, and the head is bolted into the cylinder.
Cheers Ty
Didn't write down the engine number yet,but I do know it said it was 1971.
Here is the end of a 125cc series 70 MKII/III. See the slanted plug, and the decompression bulge? ![[Linked Image]](https://www.outdoorking-forum.com.au/forum/uploads/usergals/2011/09/full-5013-3421-img_0774.jpg) ![[Linked Image]](https://www.outdoorking-forum.com.au/forum/uploads/usergals/2011/09/full-5013-3422-img_0776.jpg)
Cheers Ty
Well I guess that means I will have 2 then.
Yep, will you be keeping the Contessa as-is, becase this engine is the right age to make a 1972 MKI VC-125
Cheers Ty
No not as is I will be pulling engine of and putting on a VC base.Should I still go through with the one in Sydney? In your eyes that is.
Posts: 1,819 Likes: 6
Yep, make the Contessa into the VC-160 look-alike VC-125, as the engine as 'anatomically' and era correct.
Use the sydey one to create a VC-Sports look-alike VC-125, which is an even harder one to find, as the Sydney one's serial shows this is exactly what it came off (find out also if he by chance has the original cowl)
Cheers Ty
Sounds like the go to me.
Posts106,905
Members17,607
Most Online16,069 Sep 18th, 2025
