2 members (Buckets, Bruce), 7,123 guests, and 221 robots.
Ok, So my twin starts easy, but then if i go past idle it dies.
If i wait a few seconds to warm her, then accelerate carefully, it get there fine.
at this point it will idle well, run well, and move well through the throttle.
When i push it forward, it loses revs, and starts to die, but not always.
Occasionally it will cut through thick grass, but usually, it will weaken and eventually die, if it is moving, even on a flat, cement verandah, with no grass.
i thought water in the carby, but i have now fully re-done the carby, and still the same issue, it does it with the kill wires isolated too, and it only takes a gentle push, on a flat, load free (or in grass too) surface, and after an inch or so, the revs drop out.
Help???
Sorry man as I said the other day that problem has me stumped too.The only thing I can come up with,(Like if was on a car)would be a lose wire.I have noticed on my Twin I have a wire that goes up under the flywheel.I'm assuming that goes to some sort of ignition chip. Perhaps that has come a little lose.It would take much to come lose,and cause a Similar problem. Have you checked all the wiring.I'm just throwing ideas out there.
I though that may be the issue, but after isolating the wires, it still has the same issue, and its to sensitive to be a lose coil, it's such a light effort that causes it!
Wow, That's post 500! smile
Have you checked the state of the crankshaft seals?
They seemed alright, but i have not given them a thorough inspection (just a good looking at!)
I have never heard of them causing an issue like this, but then again, i have heard of them causing all sorts of strange issues!!
They are a weird machine, I had a lot of trouble getting all mines teething problems sorted out.
I pulled both my twin and compact out of the shed for the first time in 2 years today and went mowing! here is a pic for you
EDIT: I do remember having big troubles from the inlet manifold seal as well... had to find a suitable O ring as I got dumb looks from the local mower place.
[Linked Image from i269.photobucket.com]
I'll have a look at the seals and inlet, hopefully i will get some ideas there.
That's a great pair Joe, seem to be in really goo nick.
I'm hoping to one day get my hands on all 4 (Twin/Supreme/Lightweight/Compact)
If I'm lucky, they will look that good!
(My twin is in similar nick, but the catcher could be better... oh, and it could work too!)
I Brew The Beer I Drink
is it electronic ignition? if so id drill the module off and pop rivet another one on. they can give you the sh*ts trying to work out what is wrong
if it has points double check everything or swap everything for a known good set and try again.
Cheers, Emmo
is it beer-o-clock yet
The twin is points...
...As for finding a known good set... that may take a while!
yes i see the problem getting known good ones, depends though might give you an excuse to hunt another one down on ebay.......
Cheers, Emmo
...Hmm, I like your thinking, seems a good bypass with the missus.
Will have to wait though, i am currently saving for this:
thats an interesting machine is that self propelled, or is that cable for some kind of brake?
ive never seen a rotary mower with a roller on the back similar to cylinder mowers
and last what is it?
Cheers, Emmo
I Believe it is self propelled, its an English machine called a Rotoscythe!
I see a chain there so it would have to be self propelled
I'm looking forwart to getting it, definatly an odd looker!
Points can be filed smooth, but check the condenser first. On the old cars we often had problems with them breaking down under load. My father allways kept the old set of points & condenser in the boot for this reason.
That's the thing that has me, this is irrespective of load, as soon as i move the mower forward, even slowly, on a cement path, it will still do it!
I will have to get that video together this weekend!
confused mmmm I see you have rebuilt the carby....When it dies whip the plug and see if it is wet or dry. My thinking is along the lines of a dodgy float level or sticky needle & seat...as soon as you move it it dies; suggesting fuel level?
Another good way to check the spark is with one of those cheap in line timing lights....(or a expensive inductive one if you have a 12V battery handy) these faults do tend to send a sane man a little crazy....
That they do, though i might try yet another float bowl set, just to feel better, and have another look through the carby.
Plus a look at the plugs as you said.
I doubt it would die out if it was the float. It would lean out but it would still run.
What i get from what you have said is that its most likely a spark problem. Something loose.
I could be something to do with the stop wires.
Have you tried it with the cross pin removed from the carb??
Yep, pulled them out and used electrical tape to fully isolate them!
Hi Ty did you ever work out what the problem with this old girl was?
Not yet Jeffery, this mower is on the waiting list for a full restore, so when i get the chance,I will be giving the engine a compleate overhaul and service, and then i may find what is causing the issue.
That could work.
Hi Mr Davis just wondering if you still have the twin victa and keen to sell, if so please contact teamunscene at gmail.com , more than keen to buy from you, many thanx
All the Twins Ty (Mr Davis) had were stolen from him (long story).I don't know if he has anymore.Last I herd that he wasn't collecting at the moment.As he had other things (family) in his life to take care of.He hasn't been on this site since may last year 2015. Doesn't even talk to me anymore (which I think is very strange).So if your looking for a Twin best to just keep an eye out on eBay and Gumtree.They do come up from time to time.
18,225 Registered Users
Topics12,776
Posts106,878
Members18,226
