0 members (), 3,015 guests, and 390 robots.
by Bumps - 19/03/26 11:57 AM
Mower wheel ID.
Shout Box
by geobee - 14/03/26 08:36 PM
Victa Super 24/600
by Doug - 07/03/26 07:07 PM
Eaton Model 6/7
by Bumps - 01/04/26 05:37 PM
Mower wheel ID.
Eaton Model 6/7
by Bruce - 20/03/26 09:50 AM
by Bruce - 19/03/26 11:52 AM
Shout Box
by Bruce - 16/03/26 08:10 AM
Early Morrison rotary mower
#23709 25/05/11 11:42 AM
Hi. I'm back. I haven't got a photo yet of the Victa but the info I found is 130902 0439 - 01 77063010 Serial No:11 003 - 0368, model 5 - 26 Series 7. I hope this will help in putting a manufacturing date to her. Thanks Glen.
Glen D. #23752 26/05/11 03:23 AM
Glen, that engine was manufactured on 30 June 1977, so the mower was probably made later the same year or early in 1978. The engine is 13 cubic inches (213 cc), first design series, vertical crankshaft, plain main bearings, rewind starter.
This is the engine Operator's Manual:
http://bsintek.basco.com/BriggsDocumentDisplay/default.aspx?filename=msotJO-K_ny7tH217FzoPu
This is the engine's Illustrated Parts List:
http://bsintek.basco.com/BriggsDocumentDisplay/default.aspx?filename=Z6kpuBVJ1DajI
grumpy #23754 26/05/11 04:54 AM
Hi. Thanks Grumpy for the information. It is much appreciated. The old girl is much older than I thought. Still starts 2 / 3 pull. I'll do some searching for the info I am after and, if I have trouble locating it I'll come back. Thanks again. Glen.
Glen D. #24072 09/06/11 11:02 AM
Hi. I've just been tightening some nuts and bolts on the Victa 5 - 26. The chain is extremely loose and I need to adjust / tighten it before I can put the old girl to use. I've had here up in the air, front, back and sides and there is no adjustment set -up. Can someone please help on how to adjust same? Thanks, Glen D.
Glen D. #24100 10/06/11 04:42 AM
mower man said it is supposed to have an adjustable idler to take up the chain slack - see this thread:
https://www.outdoorking-forum.com.au/forum/ubbthreads.php?ubb=showflat&Number=20141
I can't find the adjuster in the illustrated parts list, which is in the parts and manuals section of this site.
grumpy #24101 10/06/11 05:13 AM
Hi grumpy, Thanks for your reply. Does anyone know the part number for the adjustable idler for the Victa 5 - 26 or/and does anyone have a photo of same? It must have been taken off the mower at some time in the past. Anyone know where I could source one and approximate cost, please? Thanks Glen D,
Glen D. #24104 10/06/11 06:14 AM
Hi Ken, I notice in one of the posts you may have an idler to adjust the chain on a Victa 5 26 rideon mower. Is this correct and how much are you asking for it? As this is my first rideon, I didn't know it was missing as I am just a learner. Thanks Glen D.
Glen D. #24119 10/06/11 12:43 PM
Hi GgordanN, Sorry if I got your title wrong. I have read that you have Victa 5 26 gearbox etca and was wondering if you had the idler/ adjustment for the drive chain as mine went missing before I purchased same. Do you happen to have any photos of the idler and how it is Fitted ? Thank you, Glen.
Glen D. #24121 10/06/11 01:48 PM
Glen, you may have to get the model and series etc exactly right. Ive had a few 8/34 victas here and they have subtle differences. Gear train, deck spindle brakes, brakes, steering.
It may be easier to work out what pitch chain, or style of bearing centred roller you need and buy it from a bearing supplier/farm supply/machinery supply and make it fit the machine yourself.
Most of the machines are made with componants like this anyway.
Cheers, Bob.
Rodeobob #24122 10/06/11 02:03 PM
Hi Bob. Thanks for your message. Is the info I supplied short of what is needed? It sounds a bit like a Mitsubishi Sigma I had. They had 9 different difs in the same models. As I know very little about machinery I am lost with pitch of chain, style of bearing centred roller etc. Where do I go to learn about this? Thanks Glen D.
Glen D. #24133 10/06/11 07:14 PM
Google the chain pitch thing.
Visit a mower shop and get a bit nosey in and around and under some rideons. Theres a few different ways they do things.
Im not sure about how good your info would be to someone who had what you were looking for. Probably good enough i would guess. I was just making an observation.
Short of buying a parts mower, you might be waiting a while before someone shows up with the bit you want but then you just never know.
You can buy sprockets with bearings in the centre.
And you can buy pulleys (Vee belt, flat belt) with bearings in the centre. Some have straight holes some have offset holes, they are designed to work as tensioners. Cars use them for fan belts and air con compressors etc.
Obviously a belt pulley will not work very well with a chain. It will be noisy and wont last long.
Glen D. #24134 11/06/11 02:33 AM
According to the parts list, the 5-26 uses Number 41 chain, half inch pitch, 71 links long.
grumpy #24137 11/06/11 05:36 AM
Hi Rodeobob and grumpy, I'll follow up on your info and see what I can come up with. Thanks Glen D.
Glen D. #34221 28/02/12 12:39 PM
hey mate im new to this site and dont really know how to use it yet, but i have a victa 5-26 and the gearbox is plaing up and i noticed in this thread that you are talking to "GgordanN" about one, but i couldnt find his profile. any help from anyone about this problem would be greatly appreciated.
chum #34224 28/02/12 01:05 PM
Hi Chum, and a warm welcome to the OutdoorKing forum. grin
I see that you have correctly posted in the "Wanted" forum for a gearbox, However, I hope that one of our members may be able to help you with some info on fixing the problem.
Once again, :welcome: Chum,
BTW, GgordonN has not posted on this forum for a long time, unfortunately.
Glen D. #34301 02/03/12 02:24 PM
thanks deejay, i have started a post about my problem and have had a great response already(even with my severe lack of info smile
i'd also like to commend those involved with starting and continuing this site, as good info and help with old mowers is hard to come by at most mower shops.
Glen D. #118184 04/05/23 02:43 PM
Hi do you have any photos and/or dimensions of the two engine pulleys? I need to know these since mine is missing these, the part numbers dont exist but I can likely get and MTD one if I know the dimensions. Basically the spacing between the two pulleys and the diameters. Thanks
17,902 Registered Users
Topics13,076
Posts107,348
Members17,903
PHP: 8.3.30 Page Time: 0.054s Queries: 49 (0.047s) Memory: 0.7053 MB (Peak: 0.7885 MB) Data Comp: Zlib Server Time: 2026-04-03 01:21:44 UTC
