1 members (Dandare), 6,608 guests, and 1,562 robots.
by Bumps - 30/05/26 12:23 PM
Greenfield Javelin Mk2
by Beefy - 21/05/26 06:22 PM
GX25 Honda
by NormK - 21/05/26 12:33 PM
GXV160 clutch
by NormK - 11/05/26 08:45 PM
by Bumps - 09/05/26 02:09 PM
by NormK - 31/05/26 09:21 PM
by monala - 29/05/26 12:24 PM
by Bumps - 28/05/26 12:36 PM
GX25 Honda
by NormK - 22/05/26 08:25 AM
Sanli height adjustment knob
Victa Powercut design flaws
GXV160 clutch
by NormK - 15/05/26 08:25 AM
Hi All
I am new to these forums and a novice at restoring old victa mowers so please forgive me if this subject has been done to death in the past.
I have an old victa 18 that I am starting to restore - have replaced necessary parts and finally got it up and running.
Before I start stripping paint etc I am trying to fix the handle clamp so that the handle bar does not move up and down when pushing the mower. I don't want to over tighten the clamp bolts as I am afraid this will simply strip the soft threads.
So far I have cleaned and sanded both the handle bar and inside of the clamp and, filed some of the alloy away from the contacting edges to create a straight edge and a bit more gap. Both had some effect but still did not solve the problem. Do these clamps actually stretch with continual tightening?
Possibly there is a simple solution to my problem and any tips you can provide would be greatly appreciated. I have noticed on some old mowers that people have drilled holes through the clamp and handle but, this would seem to be a last resort.
Many thanks
Pete
Hi pete and welcome,i have seen new clamps ect on e-bay but have you tried wrapping insulation tape around the bar for the clamps to grab onto.if im correct the clamps have a raised part of the casting which i think you filed off and this is the part that actually grabs the lower part of the bar...ken
Thanks for the quick reply Ken.
Yes, I did try the insulation tape but handle still turns. Might try a thin double sided tape and see if this works.
The filing I did only straightened out the clamp edges on the outside of the handle bar where the threaded bolts lock the two halves together. If there was a raised section on the inside of the clamp it seems to have been worn away over time so I may have to have a look at a new set of clamps.
Many thanks
Pete
Just a quick update on the handlebar problem.
On closer inspection of the clamp and handle bar I noticed that the metal is very smooth and looks similar to metal that gets work hardened with continual use. This was evident even after I had give both surfaces a light sanding.
I decided to try a very course emery paper and rough up the handle bar plus the inside of the clamp until I noticed a good coverage of sanding marks and got back to new metal. This had an immediate positive result so I will spend a bit more time on "roughing up" both surfaces.
I am fairly sure now that once the handle bar is painted and, if I give the inside of the clamp a coat of etch primer, this will probably help add more "grip" and stop the slipping completely.
Pete
Ashgren, Ludicr0us, eguatpatto, Jared.Ashby, monala
17,979 Registered Users
Topics12,731
Posts106,685
Members17,980
