1 members (AussieHJ), 838 guests, and 1,796 robots.
Masport Shitemaster 720 blade
#16572 08/03/10 12:32 PM
Hi guys i got a full 2 storke key starter set up for 20 bux and i need to know what power torque that will go and how to put one on
http://www.oztion.com.au/buy/auction.aspx?itemid=9563468
there is the url for the item
cheers VD
PS i know its a nice buy smile
VD,
It depends on the cylinder block because it needs a cut out (about 2") on the casting for the starter to fit as well as a special flywheel in order to work. cheers2
Bruce #16583 09/03/10 04:01 AM
ok ill check mine out how much the the flywheel worth
If you can find a "victa sports" mower, generally painted in red the flywheel is already fitted smile
#16670 19/03/10 02:07 AM
Hi bruce i also need thw wiring dirgame fot the start it i dont want cook it the starter motor
Hi all i need a bit more help on this one i have a engin with the cut out in it but no drilled n taped mounting hole tha i can see with removing the small covers
Q1) are the mounting hole under the cover
Q2) if not does any one know the dirll size n tap ill need to drill and tap the engin my self
cheers VD
Dont know the size of the drill needed, etc,
I have 3 victa keystarts, looking closely at them you would need to get the bolt holes you drill perfectly straight to avoid chewing out the plastic starter gear.
as for the wiring, its pretty straight forward apart from the charge circuit, one wire directly to the starter the other goes via the switch.
#16780 26/03/10 12:21 PM
If this project does not end up going ahead I would be happy to buy the parts off you for the price you paid, it would be good to have some spares around smile
#16783 26/03/10 12:37 PM
It sounds as if the position of the mounting holes for the keystart controls the center distance between the flywheel gear and the starter gear (which is plastic). If that is right, the center distance would need to be correct within a few thousandths of an inch (unless you wanted to use up a lot of starter gears). It sounds more practical to somehow find a base engine that already has the holes in it (it may not need to be in good condition in other respects). Otherwise you would need very accurate dimensions for the hole positions, and the drilling job would need to be done on a milling machine. This seems well beyond the normal scope of home conversions.
18,062 Registered Users
Topics12,746
Posts106,765
Members18,062
