1 members (AussieHJ), 838 guests, and 1,796 robots.
Masport Shitemaster 720 blade
Can anyone suggest a supplier for a new big end bearing for VC 160 2-stroke late 1970's?
The size data is shown on the accompanying photos.
I've looked everywhere but the only bearing that I can find is a fully encapsulated roller bearing which seems quite different to the separate roller system that I found once I slit the crank shaft.
KIND REGARDS TO ALL
- Bumps
Hi Bumps ,
You can use HK1616F - NTN or just get an old power torque motor and use the power torque alloy conrod and big end bearing.
https://outdoorking-forum.com.au/forum/ubbthreads.php/topics/119997/victa-full-crank-engines.html
I did see one in Aus for $11. but was just one of the first ones I looked at. https://au.rs-online.com/web/p/roller-bearings/0454749
Try your local bearing shop or just google online sales for HK1616F - NTN
Dear Max thx for your rapid reply but I cannot possibly see how the proposed bearing (HK1616F) would fit my application?
1. Bearing OD from your literature is quoted at 22 mm whilst the bore size on my con-rod is 27.61 mm - see attached photo
IE. Bearing OD is 4.4 mm undersize.
Q: Are you implying that I need to machine a sleeve and fit it to the con-rod big end bore to take up the gap?
2. Additionally, bearing diameter under the rollers from your literature is quoted at 16 mm whilst my crankpin diameter is 19.63 mm - see attached photo.
IE. Bearing is 3.6 mm undersize so the crank pin cant slide under the rollers.
Unless I'm missing something, I see cannot how the HK 1616F bearing would work in the big end application.
Any other ideas would be appreciated.
CHEERS+BEERS
- Bumps
Plenty of motors here if you want to grab a crank out of one
Been a while since I have needed to source bearings for obsolete machinery but suggest you take whatever bits you have to a bearings supply joint, and if they don't seem interested try another place.
One thing I discovered decades ago is that most bearing manufacturers may only make so-called sealed bearings and the part number may differ from the unsealed original but you can just get a sharp knife or pick and remove the seal/s.
Yes Bumps that bearing must fit the 125 cc and earlier 160 cc Victa, if yours is the later crank I would just use a second hand crank
that's has a good big end or swap a PT alloy rod and bearing. I wouldn't even get $40. these day for a serviced Victa PT mower.
I've seen Victa 2 strokes advertised for 2 years for $60. and they still can't sell them.
You are right there Max, all the stuff I have here will probably go to scrap, just not worth the effort
Thanks Chaps for your replies.
I would like to explore the viability of using a P.T rod in my old VC160 engine.
If one of you happens to have "on the shelf" access to an old P.T rod and big end bearing, I wonder if you would kindly measure and advise a couple of sizes for me?
1. Big end bearing inside diameter? ........... it must suit my my crank pin whose OD is 0.775 inches
2. Big bearing width (or conrod width)? ............ it be the same as my bearing width which is 0.500 inches so that the PT conrod fits between the crankshaft lobes and its thrust washers
ALTERNATIVELY, if anyone has an old P.T engine rod and bearing for sale or for giveaway, I'd be very pleased to receive it. Naturally, postage costs would be borne by me.
CHEERS+BEERS
- Bumps
Where are you Bumps?
37 William Hovell Drive
Endeavour Hills, Vic, 3802
Well there you go I am in Hampton Park
Yes Norm even Aldi had problems lately selling new mowers and had dropped the price $50. and still had a pile of mowers in stock.
Years ago you had people lined up outside waiting for the store to open so they didn't miss out.
ok I did have a quick check online just to see what Power Torque rod works as I don't have one out to measure but
as far as I can tell the later Power Torque may have the big end bearing for a crank pin whose OD is 0.775 inches.
So I wouldn't try using an early one.
From memory.
The transition from imperial to metric machining happened within the Power Torque generation itself.When Victa launched the Power Torque engine in late 1983, they initially carried over the exact same imperial toolings they used on the final full-crank engines—meaning early 1983/1984 Power Torques used the smaller imperial 0.750{ inch}big-end pin.As the Power Torque engine evolved Victa modernized the crank tooling to go fully metric, stepping the pin size up to that heavier-duty 19.68{ mm} (0.775{ inch} size to suit standard metric caged rollers.
I'd definitely check that first to make sure it's correct , I'm sure you could look it up in some manuals.
Plenty of powertorque motors here to check rods and bearings if you want to, probably a hundred here
I googled a bit more to see what part number to use for a power torque rod to fit the full crank and got EN02081A which
will fit mid seventies full crank but you may need to use the power torque piston as Gudgeon pin in different.
The 1978 to 1984 full crank Gudgeon pin I think is same size as power torque.
For a Power Torque conrod I think they are all the same possibly it's just a metric thread instead of imperial on the later PT big end pin.
So early Power Torque conrod should fit the 160 but the easiest way is to measure the PT parts as there are a few different part numbers on the conrods.
Big thx Norm,
Can you send me or sms your address to come over and pick up one.
My phone number is 0401 143922
P.S: I have a feeling that you came over to my house some years ago and helped me out on the LM / G4 carbie rebuild issue I was having?
I remember you saying to me at the time that the victa plastic carbies either work or they don't work AND if they don't work then there's nothing much you can do about it ...... that is if my 74 YO memory serves me right ... Ha!
Best regards
Bumps
Oh, forgot to add a big thanks to Maxwestern for his help with his dilligiant literature searches.
Just confirming that my crank pin diameter is 0.775 inches and not 0.75 inches
Well there you go Bumps that is correct quite a few years ago when we started modifying the cams so we could control the revs. I still fight those carbs because the float needles cause me so much greif. But when they work they are fantastic, but when they don't they kill me
I will pm you
18,062 Registered Users
Topics12,746
Posts106,765
Members18,062
