2 members (Koii, AMP), 936 guests, and 392 robots.
by Koii - 12/01/26 12:06 PM
Rover Thoroughbred Model 85
by Damon - 07/01/26 07:01 PM
Briggs CD's
by Bruce - 07/01/26 08:34 AM
by Koii - 15/01/26 09:04 AM
by AVB - 12/01/26 08:30 AM
Scott Bonnar ID
by Damon - 10/01/26 06:22 PM
Briggs CD's
Suzuki Rover 2-stroke (M122X)
by maxwestern - 04/01/26 09:06 PM
Hi everyone. My Bushranger line trimmer bogs down when on full throttle. The only way I can get my line timer on atlest about 70% power is when I have the throttle about half way open. Please I need advice on how I can get it sitting on full throttle putting out full power.
Pull the muffler off and check the exhaust port,it is probably half the size it should be. Make sure the piston is up before you start digging the carbon out and blow it out before you move the piston
1 member likes this: Koii
Norm,
I just wondering if you tried ever soaking these engine ports and the cylinder chamber with de-carbonizing fluid? I know it works on Stihl handhelds that are completely seized up by carbon. On several hours and application refills those engines start to free up to where they will start. At first they start and run poorly belching lots smoke as the carbon then burns off. This smoking will start to clear and engine operation will start to improve until all the carbon and de-carbonizing fluid burned off.
Here the Stihl de-carbonizing fluid is hard to get so I use the AC Delco vehicle de-carbonizing fluid.
On stuck engines you do have to make sure they weren't straight gassed first.
Hi AVB,
No I have never tried soaking them to remove the carbon, I usually have the bloke standing beside me wanting his machine back as quickly as possible
Hi Koii ,Norm ,AVB
If the exhaust isn't blocked.
It may just need a tune.Mixture screw adjusted ( the H screw)
After checking the basics
Air filter: clean or replace if dirty.
Fuel: fresh petrol, correct 2-stroke oil ratio.
Fuel lines & filter: no cracks or blockages.
Spark plug: clean, correct gap
Then adjust the High-speed screw (H) → controls full throttle mixture turn anti clockwise to make the mixture richer
How to use it:
Focus on the H screw to fix bogging at full throttle.
Adjust in 1/8 turn increments.
Check engine response at full RPM after each adjustment.
Once smooth at full throttle, fine-tune L screw for idle and low speed.
If that doesn't fix it ,sometimes as you try to rev out the motor with air filter off you can spay a little extra fuel or
starter fluid int the carby if it revs out you know it's starving for fuel.
There is a test here to check fuel filter , primer and fuel line problems here https://www.outdoorking-forum.com.a...l-fs36-died-at-full-revs.html#Post122085
If that doesn't work it may need a carby clean and kit or new carby.
Max/
Max, I do forget that some posters are not knowledgeable about equipment.
And Norm those types of customers here pay more if they are that big of rush. But in your area some has to drive a long way if I understand the area correctly.
Hi AVB,
Yes I do get some people from a fair distance away. Last week I had a bloke drop a Deutscher ride on here he wanted me to repair. He is from QLD 1700ks away. Sure he didn't drive all that way for me to fix it , he had other things he had to do down here and he hopes to get back here to pick it up at Easter. I said to him he was insane but that didn't phase him. Time will tell if he ever comes back. I have put a new motor on his ride on so no problems selling it
Hi everyoneone. Thanyou all for the suggestions. Ill take into consideration and try them all.
Superdad, Bill Back, Mephistopheles, Tigger, HiomeAgain
17,795 Registered Users
Topics13,055
Posts107,213
Members17,795
PHP: 8.3.28 Page Time: 0.058s Queries: 33 (0.051s) Memory: 0.6580 MB (Peak: 0.7006 MB) Data Comp: Zlib Server Time: 2026-01-14 23:45:00 UTC
