4 members (leslloyd, Dandare, duaneuren_01, Actionman), 384 guests, and 538 robots.
by NormK - 01/12/25 05:15 PM
by MowingManiac - 17/12/25 10:42 AM
by NormK - 16/12/25 08:41 PM
by maxwestern - 16/12/25 06:50 PM
by NormK - 16/12/25 04:18 PM
Victa 24 with PT fitted
by NormK - 05/12/25 09:55 PM
Have above generator in quite good condition apart from badly rusted fuel tank and damaged needle valve. Needle valve was firmly stuck with a lot of grunge and I couldn't take off the float to get to the needle valve without wrecking the wire which the float pulls on to drop the needle down when the bowl is filling.
All the passages are full of gooey rust and crud. It's a 2012 model gennie and previous owner said it was only started twice and stored all these years without draining the tank.
Anyway might be able to get away with just a new needle valve and a bit of micro-cleaning but suspect if a replacment carb can be found it would be better option.Of course there's no numbers anywhere to be seen except "4" inside the float bowl.
Distance between centres of mounting bolt holes is 42.5 mm.
Photos attached, hoping someone can tell me it's a XYZhangWang and is identical to a GXYZ Honda carb.
My main concern it has an automatic rpm system and would be great to not have to rejig that to suit replacement carb with a slightly different throttle lever.
Hi MM,
There is a carby doctor site you could ask them if no one here recognizes that carby carbydoctor.com.au
I usually just find a carby that is close enough and modify the linkage.
Max
Thanks Max,
That first one looks close enough. I have cobbled up non-original carbs onto many cars, motorbikes, mowers, mulchers - just a matter of the right spacing between the mounting bolt holes, the right inlet bore and getting the jets right but with a 2000W genie I'm wanting to have the auto governing system working spot on as it will be mostly running unattended.
Dunno if you ever saw in my Introduction posts to ODK what abominations I do with my mower carb controls, usually getting rid of any governance altogether and converting them to manual -
https://outdoorking-forum.com.au/fo...re-than-one-mower-or-two.html#Post115811
This time I need a bit of finesse:-)
Allan_WA, Jessca4, TravrAtco61, Wayne1957, MRMR
17,727 Registered Users
Topics13,035
Posts107,126
Members17,728
PHP: 8.3.27 Page Time: 0.051s Queries: 23 (0.042s) Memory: 0.6263 MB (Peak: 0.6652 MB) Data Comp: Zlib Server Time: 2025-12-17 02:39:27 UTC
