1 members (looktall), 864 guests, and 1,006 robots.
My Hyundai Mower is surging.
by aLaw13 - 20/04/26 01:29 AM
Rover height adjust plate
by Bruce - 07/04/26 03:39 PM
YardKing 4 stroke spare parts
Page 2 of 4 1 2 3 4
So even if it is a 91 or later it is still a 30+ year old mower, I don't you will see too many of the current rideons running around in 30 years or more
1 member likes this: syd666
Today i cut the grass and twice the right wheel turned outward.at 90 degrees Could straighten it out the first time, but the second time had to jack it up and straighten it out. When i finished cutting the lawn both wheels were turned outward by a couple of inches.
Is this what it has been doing since brand new or is it just worn steering components?
The tie rod is adjustable to bring the wheels so they are parallel. To prevent the wheel turning out you will have to put a bolt in the bottom of the king pin to stop the wheel going around too far. It is a common problem with them. Some had stops to prevent it some don't. They have been butchered and bashed for over 30 years so a bit of maintenance is required
Right wheel turned in twice cutting the lawn. Im going to put in a stop like you advised. It turns to the right as normal but barely turns to the left after cutting yesterday. Just about pointing straight ahead now. The first part that comes off the steering shaft has a pin attached under it going through the mower and when i turn to the left it lifts up about 2 inches. But when i put my foot on it and then turn it just about turns normally.
If it would just not move upwards so much it would be much better.The tyres rub on the king pin as well when steering is at full lock either right or left..
The wheel turns around like that is exactly what they do without a stop on it. Yes the pin through the quadrant is another primitive part that does wear . Big job to set it up with bearings, I did it on my mates 11 years ago and it is still working fine. I was talking to him this morning about it and he loves it now he doesn't have to get off and fix the wheel. Tyre rubbing on the king pin , might have to put a washer on the stub axle to space it out a bit further. To get it to turn left a bit better you may have to adjust the rod coming from the triangle quadrant to the top of the left king pin. Mate and I spent many hours earlier this year just getting the steering set up properly on his making new bushes etc, but now he is super happy with it, reacons it will see him out
Thats why i bought it. Even with the repairs its very much worth it. I checked John Deere and the rest and they were literally falling apart. Plasttic parts failing in short time and expensive to replace as well. Even near new ones. They dont make anything like they used to. Im almost 60yo so ive seen the quality reduce over the years with most things. A throwaway society were in. Even expensive cars are falling apart as they have to be retired before they get to 5 years old or else. Its a joke.
Good one. Many thanks.
Another very important thing with a lot of the later stuff has the PTO drive to the cutter belt. A new PTO costs $300/600 so that is a good reason to avoid them
Its actually a 21st anniversary model. not a 25th, so if Greenfield started in 1966 its a 1987 model.I was 21 when it came out and now im almost 60 yo. Cut through 2-3 ft grass quite well.
Thanks.
The Good old mowers like this Greenfield were used a lot by schools and councils when they were new.
The newer mowers with PTO Clutches aren't great in a dirty environment .They are made to be replaced though.
I don't think most people are going to look after the PTO clutch in newer mowers.
✅ How to Reduce Dust Damage on PTO Clutches
Blow off the deck and clutch area after every mow (compressed air works best)
Don’t engage PTO at full throttle
Avoid mowing in extremely dry/dusty conditions if possible
Check for deck seals or guards to block dust kick-up
Lubricate and inspect clutch mechanisms if applicable (some have serviceable bearings)
I replaced the PTO on a Cub Cadet earlier this year, then a spindle failed and now the steering quadrant has stripped teeth, they just aren't as tough as the old Greenies, Cox and Rovers
I was going to buy a 5hp Rover before this one. But i wanted a little more hp.
That quadrant part in the steering that slides up and down on its pin.
Is it supposed to move approx 2 inches or is it supposed to not move at all?
If its the bush has had it, i probably should replace it ya reckon?
Hi Syd,
Preference is for it not to move up and down. I can't remember what holds the shaft at the bottom, I'm guessing a split pin but It is probably 10 years ago that I rebuilt the one on my mates Greenie. That is another one of those jobs for lifting it up with a chain block or tipping it on its side so you can get at things. I can't remember but if you loosen the bolt on the quadrant you may be able to slide the shaft up through the quadrant. I know I made a new quadrant so not sure what goes on there. I do have an old greenie sitting here so if you strike trouble I could pull it out and have a look.
I stuck me hand under the quadrant pin to see if a nut was missing but couldnt feel anything. Just a bush and the quadrant pin sliding up and down in the bush when i move the steering wheel to the left and right. I cant lift it with a block and tackle, but i do have a trolley jack to have a look under it.
Thanks.
Ok so if you take the quadrant off the pin might slide out through the top or the bottom, then you can see what is going on
The pin on the quadrant is welded on. Im going to take it off to see if theres something to stop it from moving up and down so much, but theres a part with a red wire on it thats stopping the quadrant from sliding out completely. It has a bolt on the top left and another on the bottom.
I knew there was something strange about it but it is so long ago.
The pin is welded onto the quadrant. I can see the weld on top of the quadrant without removing it. I cant get it off yet as im waiting for a socket extension to arrive to remove the bolts on the piece with the red wire above it thats stoppig the quadrant from being removed from the top., as i dont have one. I had a cheap little quarter inch socket set from Supercheap auto and i clean snapped it off a while back.
Ok so that is probably why I made a new quadrant and just had it grub screwed to the shaft so it can be easily removed if it has to come out for some reason
Hello Norm,
I removed the quadrant this morning and its just a pin thats welded onto it that slides into the bushing.
Would a new bushing prevent the quadrant pin from moving up and down so much?
Page 2 of 4 1 2 3 4
Moderated by  Bruce, CyberJack, Mr Davis, prd
17,930 Registered Users
Topics13,086
Posts107,376
Members17,930
PHP: 8.3.30 Page Time: 0.060s Queries: 66 (0.051s) Memory: 0.7384 MB (Peak: 0.8673 MB) Data Comp: Zlib Server Time: 2026-04-24 11:18:39 UTC
