2 members (BeardedBiker55, Bruce), 2,065 guests, and 1,539 robots.
#121685 19/08/25 03:53 PM
Hi all you knowledgeable Tecumseh folks.
I have a 13.5hp OHV that needs some TLC.
But first... can some tell me how to remove the ring and
cup screen on top of the flywheel please?
goldnomads #121688 20/08/25 03:16 PM
Hi goldnomads if you can put up a pick of what you are having trouble with we should be able to help, the bigger Tecumesh are not often seen here
goldnomads #121691 20/08/25 06:24 PM
Hi goldnomads,
It may be different to the image below but If it's like in the image below just undo the flywheel nut and remove the starter cup.
the screen should slide off the cup once the cup is removed , it can slide off the smaller end of the cup.
goldnomads #121695 21/08/25 12:25 PM
Hi Norm, Max,
Thanks for answering me.
As I can't yet post a picture, can you have a look at post number 11 from Paul Foot to Grumpy showing a picture of the motor.
It is exactly the same as my motor.
Here's the link to the thread.
https://outdoorking-forum.com.au/forum/ubbthreads.php/topics/59915/tecumseh-13-5-hp.html
Rob
goldnomads #121696 21/08/25 03:29 PM
Hi Rob,
I'm not sure but I am thinking the cap is just pressed in. I would think a screwdriver under the cap and see if it will prise up.
NormK #121699 22/08/25 09:59 AM
Thanks Norm. I was thinking along that line too.
Rob
goldnomads #121700 22/08/25 03:00 PM
Hi Norm, Max,
I worked out how to get to the flywheel nut but ...
Here's another tricky one for you.
I need to buy a socket to remove the flywheel nut but nowhere on the net can I find what size it should be.
Any help would be very much appreciated.
Rob
P.S. This has all come about due to the darned decompression not working so I'm trying to get to the camshaft.
goldnomads #121708 23/08/25 12:23 PM
Hi Rob,
You could measure the two flat sides of the nut to get the size right for a socket or buy a socket set.
You can bend a bit of metal to fit on both sides then use a ruler or cut out some cardboard and measure that.
Norm had this problem and instead of spending money and time on a rebuild just put a Victa 2 stroke de compressor in.
If you replace the camshaft to fix the decomp problem there is no guarantee it won't just break again.
maxwestern #121719 24/08/25 03:54 PM
Hi Max.
Yeah. Did that. It's a 1-1/8" socket.
I've got the flywheel off.
I have to take the motor off the mower to get to the crankcase BUGGER!
The last thing I want to do is replace the camshaft. I probably couldn't get one anyway!
Thanks for you help and suggestions mate.
I'll post my results when it's sorted.
Rob
goldnomads #121720 24/08/25 06:02 PM
Yes Max,
I did 2 of those one on a flathead and one on an OHV. That one was more difficult because I had to make sure I missed the valve seats and the inlet tunnel across the head. Anyway in the end both run fine
Hi Rob, do you have any history on this motor? Did it run fine, just couldn't start it because of the decomp? Being Tecumesh I'm not sure what parts are available. If the motor runs fine when started I think the Victa decomp valve may be the best option
goldnomads #121721 25/08/25 12:28 PM
Yeah, the motor ran fine. I do like the idea of the Victa decomp valve. Do you have any idea which one would suit the 13.5hp Tecumseh?
Also, any help on where and how to fit the valve would be greatly appreciated.
Rob
goldnomads #121722 25/08/25 03:44 PM
Hi Rob,
I used a decomp off a full crank Victa but I also had to make an extension piece as well so I could get out far enough to clear the rocker cover, can't remember exactly how I did it . I guess if you made the extension piece long enough you could use a Powertorque decomp valve. I it one of those things you have to suck and see but it can be done. The one I did was on a Briggs OHV but the Tecumesh would be similar I think. Wherein Vic is Raywood, I haven't looked it up? Ok looked it up it is the otherside of Bendigo so that is going to make it difficult
18,085 Registered Users
Topics12,748
Posts106,774
Members18,086
