2 members (Olqualcast, Bruce), 5,995 guests, and 1,344 robots.
#119754 20/09/24 11:11 PM
The oldish thread below gives a parts listing for the above mower - THANK YOU Cyber Jack. Where would I find a piston assembly p/n 7500-201-704?
https://outdoorking-forum.com.au/fo...203-the-deluxe-pope-c1972.html#Post89461
I've had this mower for half a century and managed to keep it going. I don't want the good old thing to go to the tip.
TIA
Hi Freddy,
I doubt it will be easy to get your hands on a new piston for an old Pope 2 stroke and probably cost a lot
more than a good second hand engine.
I've bought a few old Pope 2 stroke mowers and the sellers are lucky to get $30. for a complete mower as there
is very little interest in these old mowers.
People can advertise them as much as they like but unless they are like new ,these mowers don't sell for much.
If you look on eBay or start ringing every mower shop you can find, then you may get lucky and find one but
sometimes you just have to get one made from a piston manufacturer like JP Pistons if you don't care about the cost.
Gee, thanks Max. I see they have the piston listed. I'll contact them.
JPO371 Pope 125cc 1 54 2.1250 1.1810 2.5620 2 x 3/32" 0 0.5000 P C5 0.8750 1A flat top
Unbelievable!!! JP Pistons have oversize piston assemblies in stock - 0.020" & 0.040" for $100 plus postage.
I finally got back to the old Pope yesdy to get it back together and going. Thanks again Max.
Hi Freddy,
This Pope should last another 50 years now ,except by then there will be Electric Sheep
cutting the grass.
ha ha ha.. Yeah, one of them would be nice. It takes a coupla days to get over the aches & pains of pushing the old Pope round the yard for half an hour, but I'd hafta get my grandson to programme it - or do the mowing for me, but he can't stop long enuff from doing that gaming thing they all seem so addicted to these days.
1 member likes this: maxwestern
Hi folks - me again.
Just done the winter weeds and have decided that I need to invest in a muffler for the old thing. Any hints on where I might get one?
p/n 7525-3-710
Or one that'll do the job?
Hi Freddy,
The easiest way would be to buy another mower with muffler for $10. to $30. ,the most expensive way would be to get
a custom muffler made .
Thanks for the reply Max.
I think I'll try one of these below. I know it has a thread and the original is slip on but I should be able to make an adapter hopefully.
https://www.ebay.com.au/itm/297307234196?_trksid=p4375194.c101967.m162920
Hi Freddy, what motor are you talking about, that round muffler is for a Briggs, the thread on that muffler is 3/4 BSP Should be able to find an old Briggs motor on the side of the road somewhere. I have plenty here but the postage is just stupid money
G'day Freddy and Norm,
The 4 stroke muffler will be no good, the original 2 stroke muffler has a large expansion chamber compared with that Briggs 4
stroke exhaust.
Adapting the Briggs & Stratton muffler to your 2-stroke Pope mower will not work effectively and will likely cause a significant loss of power. The design of a 4-stroke muffler is fundamentally different from that of a 2-stroke muffler, especially one with an expansion chamber.
Why It Won't Work
The main reason for the incompatibility is the expansion chamber, which is a crucial component of a 2-stroke engine's exhaust system. Unlike a 4-stroke engine, which uses valves to control the flow of exhaust and intake gases, a 2-stroke engine relies on a carefully tuned exhaust system to create a pressure wave. This wave travels back up the pipe and helps "push" unburnt fuel mixture back into the cylinder before the exhaust port closes. The expansion chamber is specifically designed to generate this pressure wave.
A Briggs & Stratton 4-stroke muffler is a simple baffle muffler that's designed to reduce noise by slowing down and cooling exhaust gases. It does not generate the necessary pressure waves for a 2-stroke engine to operate correctly.
If you were to install the 4-stroke muffler on your 2-stroke Pope mower, you would likely experience:
Significant Power Loss: The engine will not be able to generate the correct pressure waves, leading to a loss of the scavenging effect and a poor combustion cycle.
Poor Engine Performance: The engine may run poorly, stall, or be difficult to start.
Increased Risk of Damage: The engine may run too hot, which can lead to premature wear or even catastrophic failure.
You may be able to adapt another 2 stroke muffler to fit even a Victa 2 stroke muffler would be better.I'd say the victa cylinder outlet
will be smaller that the Pope but you may be able to open the fitting on the muffler a little to fit the Pope.
18,195 Registered Users
Posts106,839
Members18,196
