2 members (syd666, 1 invisible), 4,542 guests, and 241 robots.
The bends in the snorkel?
NormK #116788 22/11/22 10:18 PM
I don't think I've ever cut grass when it's dark or in the rain but I did see a guy down my street do both with his ride on mower .
NormK #116789 22/11/22 11:54 PM
The Rover ride on my high school got in the late 1980s had a pair of round headlights. I always wanted a drive of it.
NormK #116994 11/12/22 12:38 PM
I have a slight oil leak from the selector shaft on one of the Y560's and I need to remove the shaft so I can replace the "O" ring. What I am not sure about is what or how the end of the shaft engages to for it to select the gears. Looking at the exploded drawing I can't see what it is connected to. The shaft moves in and out to select the gears. Anybody have any thoughts?
NormK #116995 11/12/22 02:51 PM
The selector just looks like it slides the locking hub up and down the gear shaft with dog teeth that engage either gear.
A strip down of the parts must be done to replace the o ring as far as I can see.
Once the halves are apart I assume it's straight forward.
NormK #116996 11/12/22 04:32 PM
Thanks Max,
As I figured, hoped there would be an easier way. Now to see if I can find a gasket somewhere before I split the cases
NormK #117589 21/02/23 05:08 PM
I picked this one up today but it being a 10.5hp motor it is too hard to pull start. Runs fine when it does start.
I have an old 11hp electric start motor and I'm hoping that I can swap the bits across to turn this one into electric start. Anybody have any thoughts on if it will fit. I think it has the 2 bolts to bolt the starter on and the fuel tank has a cutout to fit around the starter.
NormK #117591 21/02/23 07:34 PM
Maybe Briggo should have offered wind up impulse starter for this, but that would look too old fashioned for their image wouldn't it?
NormK #117593 21/02/23 10:23 PM
Hi Norm and Mf,
Hard to pull start can be a sign of excessive valve clearance as the compression isn't released for starting ,obviously you
can't adjust the clearances on Top Dead Centre.
The 10.5 looks like a newer motor than the 11 hp motor , if there's no ring gear on the 10.5 the 11 flywheel should fit.
I don't think you will waste much time if the parts don't swap across Norm. I would think you shouldn't have a problem
changing the parts over.
NormK #117594 22/02/23 09:30 AM
Thanks Max,
I thought it should swap over without too many issues as long as the stator has the mounting points on the new motor. I don't think it is the valves leaking, it is just so heavy to get it spinning and I am just not strong enough these days to get it spinning fast enough to fire. It runs very well once you get it running. I will see how it works out.
MF,
This motor would need one very big impulse starter 10.5 hp requires big shoulders to get fired up
6 7 8 9 10 11 12
13 14 15 16 17 18 19
20 21 22 23 24 25 26
27 28 29 30 31
17,607 Registered Users
Posts106,905
Members17,607
PHP: 8.3.25 Page Time: 0.037s Queries: 35 (0.032s) Memory: 0.6672 MB (Peak: 0.7337 MB) Data Comp: Zlib Server Time: 2025-10-01 01:36:26 UTC
