1 members (JonathanH), 808 guests, and 787 robots.
Sir
[Linked Image from img385.imageshack.us]
[Linked Image from img385.imageshack.us] When i turn it upsidedown to do edges it loses power. Any clues
terrace,
Carby adjustment and if that does not work you will need to replace the diaphragms and fuel filter. cheers2
Sir
Thank You
i have parts for it if you need any unless bruce has some
Calvin
Sir
Thank You lawnmowertech but it`s a bit far to send from USA to Australia. Cheers
It will have one of two types of carby either:
1. Zama M16 part # 222405 diaphragm kit
2. Walbro WT92 part # 222756 diaphragm kit
You will need to give me all the numbers stamped on the carby that you can in order to supply the correct carby kit. cheers2
Sir
cheers2Thank You Bruce. The motor runs steady so i won`t adjust the carby. At present i`ve got the fuel filter out and am attempting to clean it in petrol, hopefully. Are the diaphrams on the carby? What would i clean the felt air filter with, kero? help2
I have the fuel filters in stock and they cost around $9.00 + postage. I would not bother trying to clean the filter because once they are blocked you are unable to clean. cheers2
Sir
aussieThanks again Bruce. I`ve blown through the fuel filter and air comes out squirting petrol out. I cleaned the air filter with kero. Now i`ll put it back together and try it and if that doesn`t work it must be the other options you mentioned. Cheers again cheers2
Sir
Have put it back together after doing all that including emptying and cleaning the petrol tank with petrol. It takes a long time to start, (a dozen pulls or more) but did start, and i adjusted the carby screws a little while it was going and i can now get good power even upside down. Would putting in a new petrol tank filter make it easier to start? aussie
Chainsaw Addict
terrace,
If your filter is partially blocked, yes it would help,
I would change it, don't try and clean it felt filters should be
replaced. Any lawnmower shop will have them.
cheers gmax
Sir
aussieThank You gmax i`ll replace it. cheers2
Sir
Yes gmax good news, i put the new petrol tank filter in and it started straight away. Thank You and Bruce and others. aussie cheers2
Lowes Hire NZ, NumbedNuts92, StewFuchs, Gib, auProspector
18,095 Registered Users
Topics12,750
Posts106,782
Members18,095
