2 members (Red Rum, leslloyd), 3,601 guests, and 367 robots.
by MikeDD - 12/02/26 09:45 AM
by NormK - 18/02/26 04:22 PM
by Bruce - 18/02/26 01:10 PM
by Bruce - 16/02/26 12:06 AM
Rover Thoroughbred Model 85
by Bruce - 15/02/26 11:59 PM
by Bruce - 15/02/26 11:49 PM
Victa Corvette 4016
by Bruce - 10/02/26 07:53 AM
Cox ride on
by NormK - 04/02/26 08:14 PM
NormK #104675 25/03/20 05:58 PM
Yes Tyler at least we now have a home for those long shaft Tornado motors once the body falls to bits
NormK #104682 25/03/20 08:27 PM
Looks excellent NormK.
Did you cut a dash for the exhaust outlet?
Love how you just moved the spring to the outside as an elegant solution to the clearance issue.
The real test will be how well it cuts through a thick patch of buffalo.
What a great way to make use of a perfectly good base.
NormK #104683 25/03/20 08:48 PM
MF,
Yes I cut a slot in the base so it all sits down properly. The PT will only fit on these bases because of the width of them allowing the height adjuster bar to just clear the head. On any other 18 inch base an offset would need to be made in the bar. I may set one up to show how it can be done
NormK #104698 26/03/20 05:01 PM
It's great that the Talon lets you skip that step though, and you get a wider cut as a bonus!
There must still be a good supply out there of Talon mowers with good bases and wheels where the engine had given up the ghost. Gardeners choice are the same aren't they?
NormK #104701 26/03/20 05:07 PM
Advantage with the Talon is that it is also drilled to suit the PT motor. Talon bases are usually in much better condition that the Victa ones I pick up and I can also fit other wheels on them
NormK #104704 26/03/20 05:46 PM
I KNEW I should have grabbed that Talon dumped out side the Mower shop!!
NormK #105316 19/04/20 02:49 AM
Hey Norm, this looks like a great project. Any more progress?
NormK #105319 19/04/20 08:10 AM
Hi Mystyler,
both finished look great and work well, very simple conversion. I will pull them out of the shed later and get some pics. Good mower now with a 500 wide cut.
NormK #105324 19/04/20 11:31 AM
That's good news as there are tonnes of good Talon bases that will otherwise end up in landfill.
The Powertorque is worth fitting as an upgrade to the rather underpowered B&S copy that's on them.
NormK #105328 19/04/20 02:39 PM
Couple of good Talon/Victa's
NormK #105330 19/04/20 02:49 PM
Nice pigeon pair NormK. My favourite tops too.
Looks better than I expected. Have you given them a road test?
You can stick a Victa label on them now.
NormK #105353 19/04/20 07:59 PM
They're monsters Norm, great job. I bet they go hard.
NormK #105735 30/04/20 01:37 AM
Hello Norm,
I came across this on a Facebook mower page. I thought you could draw some inspiration from it! crazy
NormK #105744 30/04/20 10:42 AM
Hi Mystyler,
Not something that inspires me, it is a good effort to get it on but 2 big drawbacks. Firstly the obvious tank hanging over the side and the second one is that it is a big waste of a powerful motor on such a small base. This is why the Talon is so much better because it gives a 20 inch cut
NormK #105745 30/04/20 11:01 AM
Maybe a 125 FC would work on that MS and NK.
NormK #105746 30/04/20 11:13 AM
Too hard there MF, you have to make an adapter plate but one of the north/south type would look better. You still have the problem of the shaft being 20mm shorter. I wonder if the Makita used one of the long shaft motors or the blades are sitting up inside the skirt by 20mm
NormK #105749 30/04/20 11:36 AM
Got to admit that's a pretty nifty looking fitment despite the overhanging tank.
NormK #105755 30/04/20 04:11 PM
Nifty as you say but I think those Makita are only a 16 inch base so the motor is wasted on them
NormK #105756 30/04/20 04:42 PM
Pretty sure those are 18 inch - seen a few of them. If its the long shaft PT, it would be a damn sight better than the bar blade they originally came with (some with swingbacks)
I think the model number has "461" in it - 461mm = about 18in
NormK #105757 30/04/20 05:16 PM
Hi Tyler, only ever seen front on pics of them and they always look narrow so I figured they must be 16 inch
ChrisNO, Cliff Tracy, The Todd, jtw37, Rod Browning
17,856 Registered Users
Topics13,066
Posts107,278
Members17,856
PHP: 8.3.30 Page Time: 0.061s Queries: 57 (0.040s) Memory: 0.7259 MB (Peak: 0.8526 MB) Data Comp: Zlib Server Time: 2026-02-18 08:00:33 UTC
