0 members (), 1,468 guests, and 1,142 robots.
GMC 750W Generator
Suring problems
Viking MT 423
by Bumps - 30/05/26 12:23 PM
GMC 750W Generator
Suring problems
Viking MT 423
by Bruce - 15/06/26 08:59 PM
Deutscher 360
by Bruce - 07/06/26 10:21 AM
by NormK - 04/06/26 02:09 PM
by maxwestern - 03/06/26 05:27 PM
by monala - 29/05/26 12:24 PM
#10117 11/11/08 06:11 AM
Chainsaw Addict
Hi Bruce,
I wanted to remove the flywheel on a pioneer 3270, I just assumed the
thread would be right hand, put the rattle gun on then stripped the thread in the nut banghead .
Are pioneer the only ones to use left hand thread on the flywheel side?,
Bruce would you have a left hand thread nut to suit this, the thread is 9.4mm in diameter.
I also want the set the timing but there's no timing marks on the flywheel.
Could I get TDC then set the correct points gap?
cheers2 gmax
PICT0004 (Small).JPG (0 Bytes, 86 downloads)
PICT0003 (Large).JPG (0 Bytes, 86 downloads)
Hi Wayne, from what I can see in the pic, the thread on the shaft doesn't look too brilliant either mate....does it need dressing? A engineering workshop may have a die with a left-hand thread which run up and down a couple of times may do the trick...a new nut can sometimes do the same, but it all depends on the metal hardness of the nut....if the nut is softer than the shaft,the shaft thread distortion will ruin the new nut. wink
Moderated by  Bruce, Mr Davis
Little_Nauvoo, Donsmowers, Tony1985, Flyingicarus, Nollzy01
18,001 Registered Users
Topics12,736
Posts106,718
Members18,002
