0 members (), 706 guests, and 1,232 robots.
#99484 25/06/19 11:42 PM
Evening all
After the recent good gumtree finds over east seeing a few really good solid mowers being saved, I have been on the lookout for a similar find.
Well, it happened on Sunday when I spotted an old victa on gumtree
It was advertised as running but smoky – which I put down to a rich fuel mix (correctly)
I picked it up on Monday, being told beforehand that it actually couldn’t be started that morning.
It was originally owned by the sellers grandfather and clearly hadn’t seen much use since.
The primer was of course hidden at the back, but turning on the tap and 3 primes, push to run, then back to start, it went 2nd go (although clearly no decomp valve), and eventually stopped when I put in near to the slow position (the idle thumbwheel was missing).
I found the idle screw on the deck when I was tearing it down. I cleaned and set the points, added a decomp valve of a scrap machine (having to take the head off to get the makeshift plug out), cleaned the exhaust port, head and piston.
The split snorkel allowed some water in during the recent rain (stored at the edge of a verandah). Fortunately it was below the intake level.
After new snorkel, carby clean and 2 cans of degreaser, I reassembled it.
It went first go, although it has stuff all throttle control. I will put a thicker washer in the carby (Bunnings brass ¼ inch washer slightly filed out) as I couldn’t get it anywhere near idle.
And I might do Norm’s carby modification on Friday.
But I am happy, it’s an absolute pearler and runs very nicely, plenty of power right up to 3640 rpm top speed (checked with tach).
I lightly slashed the side council block with it (after carefully checking for any sticks or wire) and did it easily, packing the catcher.
Here are some photos to document the find, and I actually managed to take a 15 second video as well, so will try to attach it.
Regards
Tyler
Part 2
Nice job Tyler. I like to decoke rings and exhaust port... You never know I often find a ring stuck in, so it a timebomb..
spedy
Superb machine you picked up there Tyler, still has a hundred years left in it
G'day everyone,
Great find Tyler! The tread on those wheels look like new. Also looks like a beefy larger air filter housing on that one.
I know you have probably checked this but you could check the engine top and bottom seals to make sure you don't have an air leak somewhere, also the carby inlet rubber seals might have a leak somewhere. If it all checks out then you probably need those brass washers installed in the carby as I did to my Commando years ago which fixed the fast idle problem.
With adding video's to these forums, I don't think you can add a video directly to this forum like you can add pictures here. I just upload my video's to a youtube account then just add a link from your youtube video to these forums.
Cheers!
Hi Converse, the top and bottom seals had no signs of leakage, however the inlet o-ring did have a slight age hardened spot and I would have replaced it if I could have found the ziplock with the o-rings in it. I found it this morning (I sorted 5 large boxes of spares last month and sorted them so well I couldn't remember where it was.)
I am out working on my Sunbeam Lawnkeeper 160 since I am enthused to get it going now - piston is buggered (lots of play around the gudgeon) so am swapping in another
wce Offline
Nice mower Tyler
You beat me to it by one phone call
wce
Nothing better than a bit of healthy competition I say !
wce Offline
It was a bit of a shame Bonnar_bloke, it took a little time to locate the other couple of coins to make the call and then jog the 4km to the phone box.
wce
Hello folks,
it's essentially a green VC Mustang with a top swap.
The plastic looks chalky up close but crack free to it's credit and makes for a much welcome relief from drab all over green of it's much more numerous counterpart.
Good score Tyler and dare I ask how much?
It was even closer than that Wce, I had my phone on silent and didn't hear her text, when I saw it 10 mins later, there was immediately another incoming text asking if I was still interested as someone else was.
MF - $25 smile Good score I think
I have spent the day outside putting another piston in the 1972 Sunbeam Lawnkeeper in a similar good condition, I will try to get a photo tomorrow afternoon when it will again come out of hiding
Very good Tyler for a model that is so sought after by collectors. That amounts to a cheap finder's fee to the seller.The base is nice and scrape free on the LH edge. Good work giving it attention so quickly after getting it home. You could do a RH conversion to the snorkel and flip the carby the other way so the float cap is facing out, unless it has a remote primer and you want to keep it original.
BTW, how do you test the seals?
Thanks MF
I try to at least get them running quickly after I get them, just in case of water entry or other issue that will damage if left.
I just look at the seals - if there is lots of grease/grime at either end of the crank, there might be a leak. Can dump some 2 stroke mix into the crank and see if it leaks out/weeps as well
I must just quickly apologise to wce - I was wondering if the other party interested was a local ODK member. If any good ones come up south of the river wce, I will be sure to let you know.
By the way, is ODK nearing its 100,000 post?
wce Offline
Hi Tyler
No apology required mate, It's the quick and the dead and I think I must be starting to smell ! It's gone to the best of homes. I'm glad the seller did the right thing by holding it for the first person as plenty don't.
wce
Thanks wce - I couldn't ascertain if you were joking with the phone box - now we have the NBN roll out it is quite a likely occurrence haha
If its any consolation, I missed out on a 125 Victa edger by no time at all, free and 150m away from home.
I have a spare g4/lm parts carby next to me right now, and remembering how Norm's G4 carby mod looks
Regards
Tyler
G'day everyone,
I also did miss out on 2 other nice Victa 2 strokes some weeks back during hard rubbish travels. I saw a pile of hard rubbish with what I thought was a cheapo mower from far away. When I saw it up closer it was an old Victa Sunbeam FC of some sort. It had a yellow coloured top cowl and I think yellow coloured plastic wheel centres. Yep you guessed it, I went home and went back to pick it up about 20 minutes later and it was gone!
Another one I missed was one of those blue coloured Victa Tornado powertorque 2 stroke mowers, it was complete with catcher sitting on top. It was on a busy main road. Another one I went back for and was gone! Oh well can't get them all.
Cheers!
Hi Guys,
As Mowerfreak exposed I actually thought that most of the VC Sports were that striking Red colour, I think there was a Purple and also maybe something else but not that particular Green.
I actually have access to a few more of those VC's here in Adelaide but as I discussed with Norm it's just not financially viable to ship mowers around the country unless they were totally mint examples that required no work or parts.
wce Offline
Hi all
Who have the members found to be the cheapest for shipping mowers ?
wce
Probably not Fastway
If you sent a mower, you would somehow probably end up with a whipper snipper, or a damaged vintage mower (a new mower might be vintage by the time you get it) if the package arrives at all laugh
Ha good one Tyler,
Or maybe you could try shipping it with Toll, I think they have even better online reviews than Fastway! LOL! I'm sure if they haven't misplaced or lost your mower in transit then they will be using it to mow the nature strips at their depot for months or even years!
Then again speaking of items taking a while to get delivered. I ordered a Victa 2 stroke fuel tap through Bunnings online special orders on the 15th of May and I only just received an email today which is the 27th June that it's ready for pickup from my local store. After about 5 emails during that period I was told the item was delayed, the supplier was doing a "stocktake" and this also delayed delivery by 5 more days. Oh well I guess I can finally pick it up later today...lol
Cheers!
What a joke Converse regards the fuel tap. It better be the better one after that wait -but I don't think it will be.
Hi Guys,
Hello B_B,
Victa did indeed introduce a green VC Sports after the G4 plastic carburettor came out. Not sure about the red one but no purple VC Sports got G4s. Tyler's mower is original, evidenced by no screw holes visible for the VC Mustang cover.
What I was meaning is this model amounts to little more than a re-covered VC Mustang as the base is the same colour, unlike the red and purple ones. One reason I do like the green one though, is the white cover combined with the green base offers a welcome alternative to the all pervasive green of the Mustang model.
Hi MF,
Yes I'll have to agree with you on that horrid looking Green Mustang that just looks like a horrible lump on a set of wheels. The VC Sports was a much sleeker looking machine and then the 500 Twin looked even sleeker with the longer cover on the top.
Must admit I'm still interested in picking up that twin when I'm next at that location with around 400~500 mowers all in one place.
If nothing else, just to look at in the man cave. Who really cares if it works or not?
G'day everyone,
Just an update on that Victa fuel tap that I ordered from Bunnings special orders. Well after a 6 week wait to receive the item they supplied me with the same latest new style one that are sold everywhere now. Oh well at least it was only $8.90 and not as much as the one I got from the local mower shop a while ago which cost me something like $12.
I thought there may have been a slight chance they might still have some old stock left in a warehouse somewhere of the older style taps. I wonder what they done with all those older taps that got sent back from Bunnings stores? Probably ended up in the dumpster at Victa (Briggs and Stratton)?
Cheers!
Reddy, Nick Stefano, MeMyself&I, hughyy, Shehdhhe
18,064 Registered Users
Topics12,746
Posts106,765
Members18,065
