0 members (), 1,370 guests, and 1,865 robots.
by Gizmo - 14/05/14 04:43 AM
So I dropped in to see my parts at the Blaster’s and what a transformation! Soz pics are very rushed!!!
But he has blasted and primed the clutch cones!! Is this going to cause me a prob or will I just need to clean up and rub back bare? Or will friction sort out?
I have just been in hospital having new baby and he just got on with it without me going through what needs and what dosnt need blasting and painting!!
First off - congratulations on the new addition to your family.
Second - why are you posting when you have more important things to do!!
When you say "primed the clutch cones" are you saying the piece that looks like the space module below? If yes, then definitely get the primer off before you put it back together. It's protecting it right now but will be destructive to the cork if left in place. Friction will get rid of it but I fear it will clog the cork and reduce its usefulness.. You'll only have to remove the primer that would touch the cork - you can paint the rest so it all looks integrated.
TC.
Haha yes that piece he also blasted the cork on other side but I guess it’s lucky I left on now as I am obviously replacing it anyway!! But has left protected!!
Thanks yeah I am currently at hospital with my future bonnarfide nut asleep in my arms!!!
And thanks I was hoping it would be ok I had the thought that I would have to be splashing out on new cones!!
Cheers Ollie
Hi guys
The clutch cone has to be bare steel on the half where the cone makes contact with the cork the rest can be painted I also left the back of the cone bare metal where the thrust pad rests against so just get him to strip back the front part of the cone .
Here's some picks of mine taped up and painted.
I've got a highway to mow
Hi fellas well progress has slowed up due to the new addition to family who joined us sooner than expected!
But I was tinkering with the engines I have and I have noticed I have 2 different shaft sizes on I have 2 5/8 on 3hp Briggs and off my 14” solid I have a 2hp with 3/4 shaft! I thought that it was a cast clutch as was 1 was much heavier than the other! Would this mean the clutch would have been changed? They are at painters still so can’t check it out till next week!
Cheers Ollie
G'day Ollie
Yes, two different clutch centre sizes were used - to accommodate different
engine specifications.
Both, to my understanding, were die cast ... best guess.
The earlier Model 33 clutch was probably a sand casting.
Great images of the resto!
In regards to replacing your front roller, I have recently started manufacturing a few options. BB/Admins - please let me know if I cannot post links, etc. I’m not looking to break any rules..
Well I finally got around to getting parts back overall pretty happy with the result got to put some colour on the reel and work out what to do with rollers then the assembly once I stock take all parts!!!
Questions to follow!!
Hi Ollie,
Who did you get to do your blasting for you ? and if I may say, I noticed that you also painted the front roller frame green. Not sure if you are trying to do a faithful reproduction ? but if so the frame was originally zinc plated and wasn't ever painted until the Eagle Farm built Rovers which were then finished in black along with the reel in the same colour,
Hi BB
Yes I am trying to keep it fairly original! Not going to be 100% true to form but it is not going to be a flamboyant gaudy machine!!!
Blasting painting and welding was done by limitless blasting it was his first mower done and he charged me $450 for both mowers.
I am pretty happy with the results he painted everything even what we had spoke about leaving but I will work around that! He had to re blast reels as painted green also and overspray on rollers. One catcher has just been blasted and painted but has a few pin holes which is slightly frustrating don’t know what I’m going to do about that!
I when it comes to the rebuild does anyone use loctite or similar on nuts and bolts I’m sure I read somewhere to not but can’t find post again?
Ollie
As far as using Loctite is concerned I don't see any reason to use it at all. Nothing requires ridiculously heavy handed tension on it when doing all fasteners up.
I think you'll find that leaving the roller frames green will look really strange with the green being over bearing. I'd strip the green off and repaint them silver to make it look like it's been zinc plated, but hey !, that's me.
Hi BB
Thanks I did think I had read somewhere about not using it!!
I will prob strip one of them as want to be as original as poss but the other I may leave and see how it looks as going to be black on green!
I have read in another post about oiling pawls what do you do just soak before fitting? As I can’t see any being retained! Is this just to stop the onset of rust? Is it worth a spray with rust reno? Also he has sprayed the inside of ratchet housing I have read that it is optional to paint but will this effect operation?
Ollie
As long as the paint doesn't restrict any movement it'll be fine. Generally none of the internals of a rear roller were ever painted and as such these have lasted how long ?
I'm sure unpainted they'll last another lifetime, but just douse it all in light oil during assembly..
Well has been super slow progress due to new baby and in-laws visiting!! But on final stretch just got to get the reels off to grinders! Then decide on engines think one is going new Briggs and the other will have a reconed briggs which will be next task!! I kinda regret not doing the body work on the catchers as I just thought they are going to get bashed up but kinda spoils the whole new look! Got next 2 lined up already tho I may just tackle 1 don’t quite know why I did the 2 at once!!! 1 was supposed to be a donar but was too good! Doh
Will post some final pics soon hopefully
Looking good!
Is the paint a bit metallic? I’d love to see it in the sun.
Good on you for bringing the second machine back rather than using it as a donor. With the availability of parts, you could just about bring every model 45 back to life, regardless of the condition.
Mmmmm, crisp!
Nice one Ollie81.
Thanks guys no not metallic just a very nice green! IMO! Yes I was just going to build the solid for myself but couldn’t leave the twin to rot as I didn’t actually need much off it in end! So it joined in the fun! Will be selling the twin eventually hopefully to help fund my 17” solid which is waiting in line!!! Once I have engines sorted!
Hi All,
Just to follow up on Oliie's statement above with his intent to move his donor machine on..........................
I've got to ask the question.......................what makes the Solid Engine Deck machine so much more desirable than the twin railer ?
I know what the initial answer will be but why ?
I personally feel that the Twin Railer is certainly the better looking machine in more ways than one, but that's me personally.
I'd love to hear opinions from other members.
Hi BB
That’s a good question, personally I like the look of the solid deck, plus then there is the older more elusiveness (tho there dosnt appear to be much of a shortage) and I know that they are all prone to fractures but the solid obviously has the better strength.
I also like the fact it keeps more muck out from getting on the underside when I stripped both mowers the solid was definitely less built up whether this is due to being better maintained I don’t know but it makes sense that less oil and grass crud is going to get underneath.
Other than that there is really little difference they are just as good as one another.
Hi Ollie,
Personally I have always felt that with the bent lower handle bar and the twin rail appearance that the Series II machine was the better looker. It just looks far more modern while the Series I machine looks far more dated like the Model 33 does.
Yes the Series I is far stronger in the engine deck department but now with these newer style engines out there there will be absolutely no problem in the twin rail design if any fractures are just conventionally repaired as the gusset method isn't really required for those when repaired correctly.
The gusset repair method will really only be required on machines with catastrophic rail failure.
The one thing the early units have over the later and that is torsional strength in the larger two formats, that being the 17 and 20 inch variants. There should be nothing in it for the two 14 inch models.
Hi bb
Sorry for the absence I have been a little under the weather and hiding from the cold!!!
Well I have atleast had some progress! Got reels back and fitted and now have 2 new power plants ready to be fit! Will put up some pics once fitted then will need to fine adjust the reels! Watch this space
18,089 Registered Users
Topics12,748
Posts106,775
Members18,090
