1 members (AMP), 1,429 guests, and 242 robots.
Eaton Model 6/7
Early Morrison rotary mower
by MikeDD - 12/02/26 09:45 AM
Eaton Model 6/7
by Bruce - 02/03/26 09:37 PM
by Hawkeye - 02/03/26 02:58 PM
by MowingManiac - 25/02/26 07:19 PM
by NormK - 22/02/26 02:31 PM
by Bruce - 20/02/26 12:02 AM
Page 4 of 7 1 2 3 4 5 6 7
If you do get super bored you only need to bring the black wire up from the carby inside the snorkel tube and you can set it up so that when you pull the throttle back to the stop position the lever contacts the wire and earths the ignition out as it is earthed to the handle already
Never thought of that, might look in to it
I had a carby that I modified yesterday that I could not get to come back to idle. I had fitted 5 washers under the cam , this was reducing it but it was still way to high. Got another carby body, swapped all the internals, 3 washers under the cam and it works perfectly. Out of all the carbs I have modified I only have 3 bodies that won't work for some reason, the one yesterday an 2 previous ones that would not start. Remove the internals to another body and no problems. Why I have no idea
^ air must be seeping in somehow. Probably requires examination with a sophisticated scanner of some sort to find it. Fortunately it doesn't often afflict them and there are still tonnes of the things around. Into Mr Sulo with them.
I was doing a later PT the other week (Chinese block) had the exact same problem. Changed the carby body, then no issues. I noted that the cam was easy to turn part of the way, but became harder as it went back to what would be the idle position, then became easy as it went back to the cold start and stop position.
It was as though the cam 'legs' were snagging up on the carby body (maybe the plastic had age expanded), then suddenly letting go. Perhaps with the lifter, and diaphragm with springs, the resistance meant the throttle cable just twisted/moved in the snorkel without changing cam position in these difficult spots.
Just a theory, I don't know exactly why either.
Can't remember if these are the "O" rings I got for the primer caps but they are cheap enough
https://www.ebay.com.au/itm/10-Piec...-39-Mm-X-43-Mm-X-2-Mm-G9V5/264065839030?
How's this for a modification?
Hi MF,
How fast do you think he'll burn out his bearings? :-/
Don't get me wrong, the modification looks awesome, and kudos to them for getting it done.
I just see the mower overheating, wearing parts, etc. But it'd be a fun project... how much power can you get from your PowerTorque?! I'd enter that contest... haha :-)
That is not overworking a Victa 2 stroke, they are easily capable of that work, be a bit better if it had the fan shroud to get some cooling over the motor. Also the motor does not have a lot of compression because as you can see when starting it shows little resistance on when he pulls on it without a decomp valve in it. The other thing that will kill it is the use of a pod filter down there, they are only good for keeping out rocks and quails. Another thing that makes it a lot easier on the motor when chewing through that sort of grass is having the rear flap lifted a bit so the grass can be ejected out, not getting bound up inside the mower. Then the will really get through that stuff easily
Just as an update on the carby mods I am no longer fitting the external kill switch, on probably the last 10 I have done I run a wire up the inside of the snorkel and use the throttle stop screw I fit to earth the ignition out, much better idea
G-day NormK,
can you post a pic of that set up?
I'm doing one right now but it is a bit hard to take a pic while I am doing it and at the end there is nothing much to see. I drill a 1/8th inch hole in the underside of the rubber hose near the carby, feed the wire up the inside, drill another 1/8th hole just below where the throttle cable goes into the filter chamber and the wire is connected to the button head screw I use in the throttle stop. This is how Victa should have done it in the first place and not used that abomination of their long lunch, we are smarter than the rest of the world, kill switch.
Lol pictures please Norm. smirk
Ok MF if you insist, not a lot you can see
That helps -me to stick with the existing kill switch or the spring button.
I'm finding it easier and better that fitting a switch
Yes Norm,
That is a better idea. I will go that way on the next one whenever that is. I'm just about Victa'd out at the moment after finishing the 24.
Its hard to get a durable kill switch at a reasonable price. I have been using an ATV/motorcycle/gokart kill switch. Its about $5.00. It looks durable but I have to remark the "Stop" & "Run" signs on it and its easy to try to start without switching to run and then of course nothing happens.I also have to remark the throttle with a "Start" at the "Run" position and "Idle" at the other end.Otherwise my machanically challenged extended family can not get them to go. By the way I also have to put "Oil" pn the fuel cap and highlight the 25:! words as well. The other day I got a call that one would not go. Trying to start at trhe Idle position of course but just as well it would not go, the tank was filled with straight petrol.
All the best
Jeff
I'm open to anything. What sort of screw is that in the throttle slot? Can you tell me which wire goes where?
MF, the screw is just a button head screw, I use those because they have a big head and won't fall through the slot. I cut a small square piece of metal for the inside so the screw can sandwich the wire eyelet between it and the plastic housing. The wire that needs connecting is the black wire, I just cut the other one off
Wish I had kept some record on the number of these caps I have modified over the time, seem to be always making up a batch of them
17,870 Registered Users
Topics13,070
Posts107,301
Members17,870
PHP: 8.3.30 Page Time: 0.130s Queries: 58 (0.111s) Memory: 0.7340 MB (Peak: 0.8636 MB) Data Comp: Zlib Server Time: 2026-03-06 02:10:05 UTC
