1 members (Dandare), 2,979 guests, and 347 robots.
by NormK - 01/12/25 05:15 PM
Victa 24 with PT fitted
by NormK - 05/12/25 09:55 PM
by NormK - 05/12/25 10:14 AM
Lectron Generator Fuel Pump
#96157 11/02/19 07:16 PM
I started playing with a couple of Chondas today fitting new carby on each one that I had bought from different suppliers. I couldn't get the first one to work because when running the governor was pulling the throttle wide open, gave up and moved onto the second one. Fitted it and ended up with exactly the same problem. Sat there looking at it for some time and looking at one of the original carbs I noticed that the plastic piece the governor rod clips into was operating from the opposite side of the butterfly. I removed the butterfly and fitted the original shaft and they both now work fine. As these carbs require the governor to operate in the opposite direction I can't see what motor they could fit except something where the governor was on the right hand side of the motor. Anybody come across this before ?
NormK #96160 11/02/19 08:29 PM
I can’t say I’ve seen this before as I’ve only played with 3 horizontal shaft chondas. I assume your talking about vertical shaft motors? I did have great luck pulling the carbs down and giving them a clean in my ultrasonic cleaner though. Not sure if you’re replacing them because they’re so hard to clean, or just broken. I’m sure the replacement carbs are cheap enough to justify buying new ones off eBay or wherever.
John
NormK #96164 11/02/19 09:18 PM
Hi John yes these are Vertical shaft ones that have had ethanol in them so the carbs are all rusted up so replacement was the only option and at about $12 each well worth the risk. I have both of them working now, so at least in the future I know what has to be done. There was also choke issues but I won't go into that at the moment. BB should be happy I have a couple more Lawn Beetles up and running
NormK #96166 11/02/19 09:49 PM
I tried cleaning a Tecumseh carb off a victa (don’t know the model) but the emulsion tube wouldn’t come out. Long story short bought an eBay carb for about $12, worked a treat. I feel the same, definitely worth the risk.
John
NormK #96168 12/02/19 12:02 AM
Maybe the butterfly got installed wrong. I have done it a few times here on Briggs carburetors but have always caught myself before install. And now pay closer attention to install of the butterfly if I pull it to work on or replace the shaft.
As side note some butterflies have a beveled edge for better sealing so be careful on re-installs.
NormK #96176 12/02/19 08:13 AM
Hi AVB, it isn't installed incorrectly, the top with the stops is completely wrong, it is designed to operate in the opposite direction. For some reason I had to file both butterflies in the same area to allow them to close. Anyway it ended a happy day.
NormK #96191 12/02/19 05:23 PM
Hi Norm ,I have swapped throttle shafts around before on these carbys and the choke.
The Scott Bonner and Billy Goat (Miller Falls) throttle shafts work in different directions to each other.
NormK #96192 12/02/19 05:30 PM
Then it sounds someone got their wires crossed and is superseding to the wrong part.
Now I had one case where the OEM was sending out a carburetor with the wrong choke butterflies. I had a fail leaf blower carburetor that had a main nozzle failure that required replacing the whole carburetor. The carburetor choke bleed hole was way too small and cause immediate flooding upon starting and old butterfly was not restrictive enough. I ended enlarging the new butterfly bleed hole halfway between the new one and old one. Ryobi insisted the new carburetor setup was correct. With Ruixing 2 cycle carbs here we not able to get part for them.
Anyway it sounds like you lucked out finding a solution that worked.
NormK #96193 12/02/19 05:55 PM
Hi Max, that is interesting, I wonder how they have done that, looks like I will have to hunt down one of those Scott Bonners just to see how it works. Both those carbs are on the left side of the motor the same as all Chondas I have seen. How can they get the governor to operate in the opposite direction?
NormK #96196 12/02/19 06:31 PM
Hi Norm, that Miller Falls mower in the pic has been messed around with a lot,it had a Honda starter so I checked a complete original Miller Falls mower
and the carbys are the same as the Scott Bonnar.
I checked an Aldi mower carby and it was the same as the one on the incomplete Miller Falls mower , so someone has fitted the wrong carby on that one.
The governor will work in the same direction but depending on what side of the throttle shaft the linkage is attached to,one way the
shaft turns clockwise and when the linkage is on the other side of the throttle shaft the shaft turns anticlockwise .
NormK #96197 12/02/19 07:09 PM
Here is a better pic of a Honda carby showing the reverse direction of the throttle shaft compared with the other carby.
NormK #96198 12/02/19 08:19 PM
One carby the butterfly is open and the other is closed ,not sure what it came off Norm.
Not sure if the governor works in the opposite direction or they just add some linkage ,would have to look at a mower.
NormK #96200 12/02/19 08:43 PM
Hi Max the one in the last pic on the right is what they were and I had to convert them to like the one on the left, all seems a bit odd. I fitted a new carb on a Honda self propelled over Christmas but I didn't take any notice of the way the butterfly worked, I just fitted it and it worked no problems. I have a couple of Hondas here so I will look at those carbs tomorrow
NormK #96207 13/02/19 03:07 AM
Now Max that makes sense as those are considered two different carburetors setup-wise and are not consider interchangeable; unless, you make mods.
NormK #96215 13/02/19 02:28 PM
I get a lot of mowers AVB where people have a go at fixing them but just fit any part they can find , like
this briggs 3.75hp with a Stihl coil.
The Ryobi chain saw in the briggs pic someone put the chain on backwards so they threw it out.
Found that carby you mentioned Norm on a horizontal crank shaft, Chonda pressure washer motor (6.5 hp) and
this 5.5 hp horizontal shaft Chonda in the pic below.
NormK #96218 13/02/19 06:20 PM
So there you go Max, these carbys must be for horizontal shaft motors, not what the sellers claim them to be. Did the Briggs run? if so I must give them a lot of credit for that.
NormK #96225 13/02/19 09:05 PM
Yelp Max I see a lot of this mismatch stuff too. I still get kick out the out that came in with the bar blade duct taped on. Things like this is why it takes so extra time to straigthen out a piece of equipment.
Norm Briggs have used them I have seen it yet but all I get normally is the older stuff and I don't see many chondas as most here are avoiding them except the Harbor Freight ones. Even those I can't get many parts for. More of use it until broken and replace the whole engine.
NormK #96226 13/02/19 09:28 PM
AVB, we don't have Harbor Freight, we have Aldi and for a while we had Masters, their cheap mowers are a use and throw away type. The ones I have a little more respect for now are the Sanli Chondas, no idea who is bringing those in, they seem a lot more robust than the other stuff.The Sanli Beetle was a bit stupid with the plastic body that to adjust the height you had to remove the wheels, but I have got a bit more respect for the motors now, I used to just stack the mowers up in the corner. Some of the other cheap ones are really appalling and small cc stuff
NormK #96228 13/02/19 11:47 PM
Haven't seen blades stuck on with duct tape before AVB, had plenty of mowers where the owner decided it was a good idea to weld the blades on.
No Norm the Briggs will never run with a coil that does not have the same dimensions as the original coil, even if it had a spark the
timing would be out.
NormK #96231 14/02/19 02:21 AM
But somebody on U-tube said it would work. lol even though we techs know better.
17,712 Registered Users
Topics13,031
Posts107,110
Members17,712
PHP: 8.3.26 Page Time: 0.063s Queries: 62 (0.054s) Memory: 0.7346 MB (Peak: 0.8658 MB) Data Comp: Zlib Server Time: 2025-12-08 16:42:18 UTC
