0 members (), 655 guests, and 1,057 robots.
by NormK - 01/12/25 05:15 PM
by NormK - 09/12/25 09:14 AM
Victa 24 with PT fitted
by NormK - 05/12/25 09:55 PM
Lectron Generator Fuel Pump
Page 3 of 7 1 2 3 4 5 6 7
Hi GTX,
Black catchers were "GENUINE" replacement spare part catchers from Scott Bonnar / Rover. The catchers on the wrinkle black machines were all finished in Alpine Green.
This was also the era of the first logo change going from the script written "Scott Bonnar" to the first Pentagon decal which was originally in Red and White but soon after when the black chain case finished was altered to Black and White.
Personally I wished they stayed with the Red and White, but being a North Adelaide / Sydney Swans supporter has absolutely nothing to do with it.
Hi GTX, BB is correct my catcher is green and my chain case logo has the script Scott Bonnar with the red/white 45 underneath. I would be guessing mines a late 74' or early 75' model as it has the double brass id plates, I have seen some models similar to mine with the black chain case that have the brass top plate and aluminium bottom plate.
I wonder if the wrinkle paint rusted through as there was no primer underneath, suposably hammer paint doesn't require to be primed if applied to bare steel. I hit mine with the engine enamel primer before the wrinkle finish, but as BB said funny how the inside stayed good after 45 years.
I've got a highway to mow
Can anyone recommend a reputable place anywhere from Sydney to Newcastle who does a good job at sharpening the reel and bed knife?
I'm at that stage where I can't do anymore until the blade and reel goes in, and handle bars get chromed.
All there is to do is the last of the chains when reel goes in, grass deflector and engine then adjust the cables.
I'm like a kid waiting for Christmas.
Christmas is coming wink
Sorry BS but I don't know anyone up that neck of the woods to recommend.
Ok I got a couple of places in Sydney to grind the reel so hoping to get that done this week or early next, but I dident note down which way the end bearing washers go on when I stripped the reel down. Does the outer curve face the bearing and inner curve cup face the reel? Or other way around.
Hi BS,
The outer edge of the washer leans towards the reel as you have it appearing in the second photo in the above post of yours.
My 304 stainless steel roller arrived today and I can say that I'm more than pleased with the outcome.
I took a stab in the dark with the measurements described online and what do you know exact size and only set me back $29.00+ free shipping (600mm long).
The best part was I custom made it myself and didn't have to buy a reproduction online for $150.00 that takes away the original vintage look, I might order some new end caps but for now I will use the old ones until I pay for all the expensive stuff ahead of me.
I also took the handlebars down yesterday for re-chroming so they should be back in about a week's time, starting to look shiny now.
Hi BS,
Can you give us a link to where you bought it from ?
As I could do with a new one to replace my aging old girl.
Guessing no one's been able to find a pipe the same size as the original in SS as I searched everywhere and came up empty.
Stumbled across an intercooler pipe for turbo performance cars, which you could probably find from a high performance vehicle store or just order it on E-bay as I did. Just make sure you order the SS 1.5mm and not the ally 2.0mm
Size to buy is 2.75" 1.5mm wall intercooler straight mandrel pipe SS.
The guy at the chrome plating shop quoted me $60.00 to chrome the original rusty roller yesterday, glad I took the gamble on the SS pipe.
https://www.ebay.com.au/itm/2-75-qu...?txnId=1840469990005&redirect=mobile
I've just bought one for myself. My only issue is cutting it off absolutely square as my cut off saw which is identical to BS's Makita seems to always cut with a slight deflection in it no matter how gently I allow the disc to cut. What annoys me even worse tis that this Makita is nearly brand new. I've been told that it was always a bit hit and miss with these saws as to whether they cut straight or with a slight lean to them.
BB, what you can do to get the cut straight is to not clamp it up tight, just so you can rotate it, hold down on it cut in about a third of the way and rotate it slowly. Just be careful and take it slowly. You can also clamp it, cut in a third, unclamp it rotate, cut and repeat. You can also, if the cut is off square, lock the blade down and with the saw running push the tube up against the blade and rotate slowly and you will be able to see once it has squared up. Be aware that this will shorten the length so if you do this make sure the original cut gives you enough length to grind back
Mine does the same at the end slightly tappers off, but I then square it 90 degrees on my linisher and sand it flat. I also gave it a few extra mm for squaring it off
Although the cut off saw isent accurate it's the easiest and cleanest cut I could get doing it at home as stainless is damn hard. Beats cutting it with a hack saw.
What you can maybe try BB with an off cut to see if it makes a difference is take the folding guard off, I know it's not safe but I notice that when the guard hits the work piece it tends to push the saw handle to one side. Maybe with out the guard the blade will run it's true coarse and not have the pressure of the guard steering it off coarse. I may give it a try next time I use it to see if it makes any difference, NormK idea will work to just use a brick or something solid with a flat surface as an end stop behind the open pipe end so you can push back against it as a jig then rotate the pipe around with the saw in the down position.
Hi BS and Norm,
I removed that guard quite a few years ago as it's nothing more than a PITA and always gets in your way. Pretty much like I thought, I'm not the only one experiencing this issue of un-square cutting.
As Norm suggested and I've done in the past and that's take a few different bites at it and then use the side of the blade as a disc sander. I've always gotten there in the end I guess but just wondered if there was just something that was uniquely wrong with mine of if it was just me.
BBthe frame only has to be half a degree out of square and over the diameter of the pipe it can end up a mm or two out of square. You also get heat distortion that makes the blade warp slightly as well
Decided to get stuck into the catcher as everything is done I'm now just waiting for the handlebars to come back from the electro plater.
Holes in the catcher filled in quiet well, I wasn't game enough to try welding it as I haven't welded anything that thin before and I'm sure I would of made the holes bigger if I tried.
Also gave some of the dings a bit of a bash, its not perfect still has hail damage look at the nose but it's in the correct shape.
Still have to paint the inside of the catcher as I had a bad batch of paint and have to take it back and get it replaced.
G'day Bon-Scott
I remember to this day the first dent I put in my SB 14" catcher.
I hit the clothes line mad
As a teen, I blamed my parents for putting it there. Was that wrong?
After that, I was more careful - but that never helped the metal wound heal.
I was ashamed with myself. My beloved 45 ...
Many thanks for your wound dressing.
That's a great job! I wish I had your skills.
Hi BS and Mod CJ,
My best advise would be to keep an eye out for an Electric Model 45 as many of those are found to be still in really good shape and their catchers are generally near perfect. (also they sell dirt cheap at around $50) I see them consistently and that's how I got my perfect 14 inch catcher for my original 14 inch Series 1 machine..............................that I now never use LOL due to using nothing less than a 20 inch mower nowadays.
I totally understand how Jack felt when he pole axed his catcher as they are never the same afterwards. Sadly it's the nature of the beast the way most reel mowers are designed and that was part of the reasoning behind the concept of the ill-fated Diplomat machine with the rear mounted catcher that one could get up closer to trees etc. without bending them up.
I thought about putting more work into the catcher but figured the same thing, will just keep an eye out for another catcher later on if one pops up. I also figured the same thing that it's basically a bumper bar and most likely a tree or clothes line will jump out in front of me first time I use it. The design should of used a solid steel frame around the side folded edges and across the front point of the nose for re-inforcment considering the weight of the mower behind it.
For record I used selleys knead it (steel) to patch all the holes, this stuff is easy to use works like play doh so you can work it into the holes and shape it but dries rock hard with in 3-5mins and can then be sanded. I have used the aqua version to patch small holes under the water line of my boat and it's still holding up. Cheap fix for $20.00
Hi BS,
I really feel that the Model 45 was the beginning of a major cut back in steel usage to lighten up the machine as it was never intended to be a greens mower like the Supercut was with all it's cast iron side plates, thus why many folks that get a Supercut and think this is going to set their world on fire soon find that it's just way too heavy and cumbersome to manoeuvre around a domestic garden and also the drive system was basically an in or out system, thus why the hair trigger drive on the 45 was such a hit with the domestic market .............and still is to this day.
17,714 Registered Users
Topics13,031
Posts107,112
Members17,715
PHP: 8.3.27 Page Time: 0.070s Queries: 60 (0.060s) Memory: 0.7470 MB (Peak: 0.8657 MB) Data Comp: Zlib Server Time: 2025-12-10 19:36:18 UTC
