#95082 21/12/18 05:20 PM
Hello to all ODK members,
Have got a Villager �badge� which has a fair bit of corrosion and rusted in screws
Would appreciate any ideas/advise on how best to clean this up.
Thank you
Phil
Hi Seafordphil,
Just hit it with a wire brush or wire wheel on a bench grinder.
Thank You Paul C
Thanks for your comment, I was thinking can this be sealed to stop future corrosion
Phil
Phil once you have removed the screws, not sure if you have achieved that yet, once you have cleaned it up you can just spray it with a pressure pack clear. Is there any colour meant to be on the badge, if so do that before the clear
Thanks Norm
Screws still in at the moment.
Worried about breaking it.
PHIL.
Have you had some penetrene on the screws
NormK #95124 23/12/18 05:15 PM
Thanks again Norm
Will go and do that right now.
Phil
Phil I bet if you brought it over here they would fall out as you arrived LOL
Hi Seafordphil and all,
I would not use a steel wire brush on the Villager side of the badge as it will remove base material from the badge (gouging ,scratching)
Use a brass brush for cleaning the badge but sometimes the brushes that are listed as brass are brass plated steel so check
with a magnet if you have any doubts .
Brass wire is softer than steel wire or stainless steel wire, and offers a brushing action that will not scratch harder metals.Good for cleaning metal parts without removing any of the base material also good for Satin finishing aluminum extrusions or sheet.
Max
Thanks Max.
Taken on board
Phil
I agree with Max. Steel wool is another option, will give it a nice shiny look.
Thanks for reading!
18,154 Registered Users
Members18,156
