0 members (), 3,045 guests, and 2,329 robots.
Sir
I took the carby etc., off and subnerged it in kerosene then put it back together and it started immediately, run for a short while, then it stopped now it won`t start at all. I now have it off again submerged in petrol. Any suggestions? cheers2[Linked Image from img98.imageshack.us]
Need more info like:
1. Did you pull the carby apart or did you just put the whole carby in kero?
2. Did you replace the fuel tank filter?
3. If you pulled it apart did you replace the diaphrams & filter in carby?
Answer these question along with more information as to what you have done and then we can move on to help. cheers2
Sir
Thank You. 1. I just put the carby in kero.2. Fuel tank filter-no i`m unsure how to do that. Does the start pull cord cover have to come off.3. No
Ok try this first:
1. Get some wire and bend it at the end to make a small hook.
2. Remove fuel cap and put wire into the tank and hook the fuel line.
3. Then pull the line out and it will have the fuel filter on the end of it and if it looks dirty replace it.
4. Return the fuel line with new fuel filter on it and see if that fixes your problem before we go onto carby repair. cheers2
Sir
Thank You Bruce i will try that. I have already taken out two screws on the carby and removed the plate and that reveals other bits. Do i have to go further to clean it if neccessary? ( I`m trying to send a photo of it to you from "my pictures" but not sure on this forum. It asks for a URL )
Sir
I just noticed my photo did go through to you. Here`s one of the carby opened.
[Linked Image from img230.imageshack.us]
Sir
I`ve got the the petrol filter out it seems to be a bit furry. Should i attempt to clean it?
That is the metering side of the carby, the filter is on the other side.
No replace it with a McCulloch filter the same as this one below:
McCulloch Fuel Filter
Sir
Thank You. Yes i can see that filter on the carby as well as the one in the petrol tank? Also, the part under the primer bubble, in photo, how is that cleaned? I`ll see if i can buy a new petrol tank filter tommorrow, the MC CULLOCH parts are hard to find. cheers2
[Linked Image from img233.imageshack.us]
Just print the picture that I put up as it is an after market filter and any mower shop should be able to get it if not we have them in stock.
As to cleaning the part under the primer I would not worry about it at the moment unless the primer is not working.
Sir
I`ve noticed the primer bubble doesn`t fill with petrol and stay full. cheers2
Does fuel go back into the tank when you prime it? cheers2
Sir
I`ll look for a petrol tank filter and put the carby back on and check for petrol going back into the tank. i suppose i could see it running back down the plastic petrol line? Probably hard to see for the dark color. Another thought, maybe it would be easier to buy another carby. Do you have it and how much cost + freight to Brisbane also the petrol tank filter? Where are you? cheers2
Sir
After checking i see your in Sydney. aussie
You should not need a carby at this stage. What you need is the fuel filter first to see if that will fix the problem. The cost $9.50 and postage would be about $5.00. cheers2
Sir
Thank You Bruce. Good news, found a new fuel filter and put it in and it started after a while. When priming for starting how many times should the bubble be pushed approximately? yay cheers2
terrace,
I assume that the picture that I posted help a bit with getting the filter.
As to priming all you need to do is prime until the primer bulb feels firm (about 6 times). cheers2
Sir
Yes a big Thanks to you Bruce. good1
Glad that I was of some help with your machine. cheers2
18,145 Registered Users
Members18,145
