0 members (), 1,402 guests, and 1,188 robots.
by Bruce - 07/04/26 03:39 PM
Atom Spare Parts For Sale
by Bruce - 07/04/26 03:24 PM
Ryobi Spare Parts
by Bruce - 07/04/26 12:00 PM
by Bumps - 19/03/26 10:57 AM
Ryobi Spare Parts
Royal Enfield Mower
by Bruce - 05/04/26 03:47 PM
by Bumps - 01/04/26 04:37 PM
Mower wheel ID.
Eaton Model 6/7
#9333 03/09/08 07:41 AM
ptg
Offline
HI have been given a Homelite UT70131A,( 03 model ) will start but wont run much longer than 5 seconds, have not taken to anyone yet, would like to try fix mayself. Haven't any manual.
Have cleaned exhaust outlet, primer bubble has fuel,does blow much smoke while it runs.
Any sujestions on what to do?
Where to get parts (Newcastle,NSW)?
Manuals?
ptg #9335 03/09/08 12:58 PM
ptg,
It sounds like you have a fuel problem and what I would be doing is the following;
1. Check the filter in the fuel tank.
2. Check the filter screen in the carby(especially if the carby was made in Mexico) as it is a very tight mesh.
Check what I have suggested first and we will go from there. cheers2
Bruce #9339 03/09/08 11:18 PM
ptg
Offline
Thanks will do.
ptg #9362 06/09/08 09:08 AM
ptg
Offline
hi Bruce I did what you said and shes of and running, a little hard to start ( about 6 to 12 pulls ). Once going its good.
the plug is a champion RCJ6Y, Should i change it to a ( going of your post about plugs)
DJ8J
DJ6J
DJ7Y
Thanks very much for your help
ptg #9369 06/09/08 03:56 PM
Sorry ptg,
Did you check the screen in the carby as it has a very tight mesh and any dirt will block it making it hard to start.
Also check the screws holding the mounting block to the cylinder because if they are loose you will also have prob's starting.
As to the plugs I prefer to use NGK as I have found them to be reliable.
Another thing would be the carby settings on the high and low mixture screws.
Let us know how you go after checking the above as well as the mixture settings. cheers2
Bruce #9393 09/09/08 11:29 AM
ptg
Offline
HI Bruce, yes i cleaned the screen and it had some crap in it, its now clean.
Checked all other bolts and screws, and adjusted the carby, I used it in the vacant block next door and it went like a ripper.
Low needle about 1&1/2 turns Hi needle about 1&1/8 turn and I will get a new plug for it.
Thanks for all your help.
Paul
ptg #9398 10/09/08 12:39 AM
Paul,
Glad to see that all is well with your machine. cheers2
mowersam, Ess, Greg1402, archernar, The Grasscutter
17,925 Registered Users
Topics13,081
Posts107,357
Members17,925
PHP: 8.3.30 Page Time: 0.032s Queries: 29 (0.026s) Memory: 0.6501 MB (Peak: 0.6873 MB) Data Comp: Zlib Server Time: 2026-04-18 09:31:53 UTC
