2 members (looktall, DeanVR4), 6,028 guests, and 1,194 robots.
Hi, i am new to this forum, have been following it for ages and have now joined as a member.
I have a Scott Bonnar 45 that starts up fine but after a few minutes of mowing, its seems to start running rough and stalls until it is not running anymore.
It starts up ok not long after but will do the same again.
I have down the following in terms of maintenance:
- removed carby and replaced gasket between the fuel tank and the carby.
- replaced the diaphragm
- replaced the spark plug
- checked the air filter, it is not brand new but still look relatively clean
- drained and replaced with fresh fuel
- replaced the engine oil
- sprayed carby cleaner into the carby whilst running to try and clean the internals out
- the choke seems to correctly operate
I have tried adjusting the mixture needle to a point where i think i can hear a slight difference with its tune but still stalls moments later when i engage clutch.
This has been puzzling me for a while and keen for any advice?
The below details are on the actual mower frame:
The model Number is: 45058
The Serial Number is: 371092
Its a Briggs and Stratton Engine
The below details are on the actual engine:
Model Number: 80202
Type: 2324 01
Code: 90100303
Attached a photo of the mower
Hi Miloboy welcome here from wherever Mount Louisa is. What I would do is remove the air filter, start the motor, rev it up by moving the governor arm and jam your thumb down on the top of the carby inlet, hold it there till the motor nearly stops then release your thumb, allow the motor to come up to revs again and then repeat the process. Do this maybe half a dozen times and see if that solves the problem, it often does,but sucking a bit of rubbish/gunk inside the carby. Worth a try and nothing to loose.
Thanks i will give this a try. Is there any way i can thoroughly clear out the carby if i pull it back off completely to flush?
This sounds like a classic case of fuel starvation.
I'd say it's got a blockage in the fuel supply tube that picks up the fuel from the tank up into the carby or as Norm suggests a bit of gunk that's being pulled up and gradually block the supply. After it stops and sits for a while the blockage reseeds downwards and again the process is repeated after it's been restarted.
I'd follow Norm's advice and see if that solves the issue, if not then its a carby off and blown out all holes with compressed air.
Thanks heaps BB will certainly give it a go.
Tried the suggestion from NormK with revving and temporarily blocking the carby inlet and i was able to mow without any dramas. Will see how i go again next time i mow as this seems too good to be true
Glad it helped Miloboy an old trick I learned over 50 years ago.
G'day all
Yep, always great advise from the pros.
My suggestion - long term - is to replace the carby diaphragm.
You have a pulsa-jet - and diaphragm condition is critical.
They deteriorate with age.
Apart from tube blockage, air leaks, and fuel quality, the diaphragm
is the critical link in fuel starvation. The pulsa-jets had a small
fuel pump to lift fuel from the bigger tanks.
https://www.outdoorking-forum.com.au/forum/u...riggs-stratton-pulsa-jet-diaphragms.html
Thanks CyberJack, i forgot to mention i already replaced the carby diaphagm not too long ago (~2 months ago). I will double check it though to make sure its sitting correctly
Went to mow this arvo and after about 10min of mowing it started to run rough and almost stalling again. Looks like this issue is still haunting me. I pulled the carby off and blasted air through the following holes (see attached photos). Pulled the diaphragm off to inspect and it seems fine, its only 2 months old. Still using fresh fuel and clean air filter. Will put together and run on daylight hours otherwise will annoy neighbours. Any advise will be much appreciated as its getting me down
Hi Mb,
Is that diaphragm one of those Chinese eBay units ?
I purchased it directly from a local mower repair shop, not exactly sure where their supplier is but i assume they would use reasonable parts
It was still a struggle to start, pull started about 15 times with spraying carby cleaner into the carby inlet to fire it up. Checked gasket between fuel tank and carby is sealed tight. I disconnected the fuel rod (incoming from fuel tank) and air blasted and rinsed it both ways. Hoping to give it a go soon to see if this works.
Hi Mb,
If you pour a small amount of fuel straight down the throat will it initially fire up easily ? If it does then the most likely culprit will be that diaphragm is made of cheap neoprene and is not working as it's meant to.
Many of the mower shops are starting to cheat by buying really cheap eBay parts just like back yard operators are doing now and still charging like they're using "GA spares" componentry. It's a price war between the internet and normal suppliers.
Thanks BB. I will try sourcing another diaphragm from another supplier just to be sure.
After thoroughly cleaning carby and fuel line, ran the mower for good 25min and no issues with stalling. See how i go next mow.
I noticed i have no more travel on the screw adjustment for the cylinder reel and she is now not cutting well. Have ordered another bedknife as the old one may of been sharpened over the years to a point where it is too short for the reel to contact. Will send the reel and new bedknife to the sharpeners. If i am missing something or havent considered other options, please let me know.
Has anyone had this issue before where the bedknife needs replacing because it has become shorter with the sharpening over the years?
Hi Mb,
If it's become shorter is because someone has been grinding two surfaces and taken too much off the leading edge to try and true it up.
At this point I would simply put a new one on and then have it ground up.
Let your engineer do that part of the job as he may need to shim it or do other things to get it dead straight. Some Sole Plates have been known to develop a slight curve over many years or were not ground perfectly in the first instance.
While doing this get the reel done at the same time as you don't only do one half of the whole job. This way you'll have a good mating pair of scissor blades.
Thanks BB very much appreciate your advice. Have ordered a new heavy duty Bed Knife blade and will take it along with my reel to get it professionally sharpened.
Just a question with assembling the diaphram, apart from lining it up 100% and screwing it diagonally is there anything else i should be aware of? Its still struggling to start and think it is something with the diaphram... the spring sits correct to me.
Hi Mb,
You can't do any better than how you've described it.
I'm just wondering if you've blown out all the various holes and the supply tubes back and forth to ensure ease of fuel passage.
I'm only saying this because when I do any carburettor work you won't see any grass stuff floating around the place. I will always practice being Dr Shaun Murphy (The Good Doctor) when doing any carby work. wink
just a question as still having an issue with starting, would the mower continue running if there was a blockage in the carby still or issue with the diaphragm? It seems to be an issue with starting it if left for over a day or so... it still seems to me it would be from the diaphragm to pump the initial fuel into it???
wce Offline
Hi Miloboy
Looks the same model as my friend over the road has and he was having trouble starting from cold. What I found was when the throttle lever was set in the start position the cable wasn't traveling far enough to activate the choke butterfly. I adjusted the cable and his starts fine now, maybe worth a look at. Of course this only effects a cold start. The screen on the end of the fuel pick up needs to be very clean also.
wce
That's a valid point about the choking method.
Is yours a chok-o-matic which in other words it pulls the choking mechanism out when the cable is pushed fully forward ?
Yes when the lever is in the choke position, the choke butterfly is closed all the way. It opens up completely when the lever is adusted to full revs.
For a cold start, when pulling the cord, does the diaphram acts as a pump to draw fuel up into the carby and into the combustion chamber?? Its like there is no pumping effect to get that initial spray of fuel on a cold start....
Hi Mb,
So if you leave the the air cleaner off and tip a small amount of fuel down the throat does it start well and then continue running ok or does it soon after falter and stall ?
Some years ago I looked at trying to fit a primer bulb from a whipper snipper to these because they usually only need a sniff of fuel to get them to fire, but then it all got too hard and I gave up
Yes the later Briggs had one fitted on the vertical shaft engines and that helped them immensely, why they never did it on the horizontal shaft engines I don't know.
18,159 Registered Users
Topics12,760
Posts106,815
Members18,160
